Question about HP Officejet 5780 Printer
On print command - the document does not open or print
I have a HP Office jet 5780 all in one . whenever i give a print command, the document just hangs.
please can you help
Nisha Brown
SET IT AS YOUR DEFAULT PRINTER
Posted on Jan 07, 2009
HP LaserJet 3330 will not print multiple copies
Does this happen only with some documents/software? I have a different HP printer (a LaserJet) that does the same thing only with PDFs printed from another program. (This happens with PaperPort and browsers using the Adobe Reader plug-in, for example.) If I open Adobe Reader and then open the document in question, I can print multiple copies correctly.
I hope this helps.
Jun 14, 2012 | HP LaserJet 3330 All-In-One Printer
Am having difficulty removing Black (96) print cartridge from an HP 7210 All-in-one printer/scanner to enable installation of a new (96) cartridge and need help!
on the software on your PC there was a option in the printer setting>> preferencess>> maintenance, which you can select the ink/cartridge replacement..
Jun 25, 2008 | Office Equipment & Supplies
My hp office jet 7210 takes several minutes to
I suspect that you are looking at a flow control issue and not a printer failure.
You can check the printer driver and make sure your printer options for background printing.
Also, make sure that your document is not too busy. I've had customers complain about slow printing documents and when I examined the documents, I discovered that there were multiple images overlay ed. The data still had to be sent, but only the top image printed.
Don
Nov 05, 2009 | HP Officejet 7210 All-In-One InkJet...
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
I am not print from tally software it is getting failed
please check that u select the proper printer before preceeding for print command. Also check that the printer connected to ur system is ur default printer.
Jan 10, 2009 | HP LaserJet M1522nf Multifunction Printer...
Hp laser jet 1010
Dr.M.subrahmanyam
1. This printer is not specifically a postript printer. It uses HP PCL printer control language, according to HP it does not support Postcript, see the table on page 15 of this pdf file: http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00442162/c00442162.pdf page
2 Screen prints are not directly sent to the printer. They are copied to the Clipboard - you must open up another application which can access graphics - WordPad , Word, Excel. E.G from wordpage paste the screen print (using Control + V or Edit-> Paste) and the contents of the clip board will appear in the document - use the print option from wordpad to print this graph to your HP 1010 printer.
Feb 21, 2008 | HP LaserJet 1010 Printer
Open Questions:
See all HP Officejet 5780 Printer Questions
HP Officejet 5780 Printer Logo
89 people viewed this question
Ben Johnson
