Question about Ducane Grilling
Erratic flame on gas grill
After cleaning burners on Ducane 5004 the flame is wanting to kick back through air adjustment holes behind the control knobs
2 Suggested Answers
SOURCE: removed burners for cleaning, flame erratic
I don't think you "seated" the burners correctly where they go into the knobs. Get up under the knobs, look up and you'll see what I mean.
Posted on May 18, 2009
Does conversion from LP gs to Natural gas on Ducane 30400040 (essentially makes it a model 30400041) require changing the inlet orofice on the IR burner ? I purchased conversion kit that included all new...
Did the conversion kit give you an LP orifice for every new gas valve? LP gas orifices have smaller holes than Nat gas orifices. Can you smell gas when you turn on the IR burner by itself? Some burners styles have an air adjustment on the end that fits over the orifice. Make sure it's getting enough air. Also make sure your ignitor sparker is positioned where the spark can ark against the top of the burner. Ducane grills have rotary ignitors, so turn it (with gas off) and see if you can actually see where it's sparking. If it's not sparking in the right place, it will be difficult to light.
May 14, 2010 | Ducane 30400040 Stainless Steel Grill
Side burner on my Ducane 30400040 LP gas grill has a tall yellow/orange flame. How do I adjust?
Try blowing the burner out with compressed air. They're not adjustable but can get clogged up and change the air to gas mix.
Apr 25, 2010 | Ducane 30400040 Stainless Steel Grill
One burner on the Ducane gas grill lights only weakly. Gas is coming through but only some of the holes ignite. The other side is uniformly lit, but the flame only goes maybe 1/4" high. Clues?
try opening the tank really slowly. the tank has an overfill protection devise built inside and if it is opened too quickly it can restrict the gas flow to the burners. hope this helps.
Sep 14, 2009 | Ducane Grilling
Bright yellow flame, can't adjust
Check your burner tubes for spider nests. Clean the burner assembly and check all the holes. Eric
Aug 08, 2009 | Holland Grill Legacy (NG)
I have a ducane stainless steel ducane 30400042. Weber has sent me new burner bars since the old ones rusted but you do I install them?
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Jun 20, 2009 | Ducane 30400040 Stainless Steel Grill
Need to replace burner tubes on a Ducane grill. How do you do this? How do you get the old one off? I don't have a manual anymore.
First call Weber to receive the Warrenty burners for free. Have model and serial numbers ready. They can be found on one of the doors. Here is what I did for my Ducane model 30400042.
Jun 07, 2009 | Ducane 30400042 (LP)
The burners sounds like a jet plane.
make sure the burners are clean, each and every little hole must be clean. It sounds as though the flame is burning near the inlet of the burner which can occur if the holes are restricted too much.
May 26, 2009 | Ducane 455 inch 2 - 3 Burner with...
Lighting Problem/2 year-Old Ducane Grill
Do you have enough gas pressure coming out of the regulator and gas valve? You'll need a pressure guage for this.
If yes, try taking out the burners and cleaning them with a wire brush, especially the flame spreading sections.
Sep 15, 2008 | Ducane 30400040 Stainless Steel Grill
Burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Jul 04, 2008 | Ducane 30400040 Stainless Steel Grill
Grilling Logo
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
