Question about Epson LX-300 Matrix Printer
Tally Voucher printing
Hello Sir, I print Voucher on 12x9 inch paper in continue form My voucher size is 6x9 inch. Sir whenever i print the voucher first voucher print at the start of the page but the second print on next page instant of same page. As a result after each voucher print one voucher print space goes blank. Sir i would also like to know how i can increase the font size. Thanks for your assistance. Regards, Hardik
  • 2 more comments
  • alshi Nov 25, 2007
    On Epson Lx300+II printer 6 inch perforation size is not available in the default dropdown list and also not a custom size then how to select the size of 9X6 in it. As per the solution given in properties there is no new form option anywhere in properties of printer . Please give the solution at the earliest as my work is heldup
    ----Sachin
  • wiltshireo Mar 09, 2009
    epson lx 300, is printing the page sent to print but still sends a second page which is blank.
  • Anonymous Apr 13, 2009
  • uday383 Apr 13, 2009
    President:
  • Epson Master
  • 2,022 Answers
See just go start setting and printer in printer right click go to server properties in that you will get option of creating form choose new form and give the sige of voucher so whenever you printing voucher select this paper size. bye
Posted on Sep 28, 2007
Ms word does not print properly on tally 2250 printer
you need to create a forms for your specified paper size.
1.open printer and faxes in win xp.
2.file...server properties...create a new form(check)
3.type a name for forms
4.type a size in below boxes...(like 10 x 12 paper , width is 10 inch, height is 12 inch)
5.save it
6.close
7.rht click the printer...device setting tab... select a form name in the tray .
8.it will work
Feb 26, 2010 | Tally T2250 Matrix Printer
My tally 9 not accepting voucher date other than 1st and 2nd
Aug 27, 2009 | Tally T2250 Matrix Printer
Voucher checks not printing correctly HP C7280 AIO
The front of your voucher check is smoother than normal paper or the rear of thr voucher. Cleaning the feed rollers should fix this problem. If you do not know how to clean the rollers, you need to take the printer for a service.
Aug 04, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Tally 6212 - Landscape Documents Printed Vertically
You do indeed have problem-- the printer is doing what you are telling it to do changing the print from Portrait to Landscape on a dot matrix printer has the same effect as that on a Laser printer, it rotates the print by 90 degrees.
The correct solution of to define a custom size of paper which is the same size as the paper you are printing on.
If you are using Windows 2000, XP, 2003 etc you can create a Custom Size paper in the following way;
  • Ensure you are logged in with administrtor rights
  • Open the Printers Folder
  • Go to the FILE DROP DOWN MENU
  • Select SERVER PROPERTIES
  • Ensure the FORMS tab is selected
  • Tick the CREATE FORM button
  • Enter a NAME for the form
  • Enter the dimensions (be careful of the units you are using --- best results use inches)
  • Do NOT set margins printable areas etc
  • Click on the SAVE button
One you have created the custom size form you should be able to select this by name in the printer driver properties and the software package you are using.
Jul 28, 2009 | Tally Line Matrix T6050 Printer
In tally 7.2 when we enter the voucher the Cr or Dr is not seen
hello user of tally,
you are getting ur voucher in single entry mode so when u entered in to a payment/receipt/contra press F12 and say NO to the following option
"Use Single Entry mode for Payment/Rcpt/Contra" :- No
Jul 01, 2009 | Tally T6218 Matrix Printer
How to find tally 9 short-cut keys
Tally 9 short-cut keys appear on the right-side of the tally screen. see the button names in the button bar.
few short-cuts:
Keys
Functions
Alt + 2
To Duplicate a voucher
Alt + A
To Add a voucher
To Alter the column in columnar report
Alt + C
To create a master at a voucher screen (if it has not been already assigned a different function, as in reports like Balance Sheet, where it adds a new column to the report)
To access Auto Value Calculator in the amount field during voucher entry
Alt + D
To delete a voucher
To delete a master
To delete a column in any columnar report
Alt + E
To export the report in ASCII, HTML OR XML format
Alt + I
To insert a voucher
To toggle between Item and Accounting invoice
Alt + N
To view the report in automatic columns
Alt + P
To print the report
Alt + R
To remove a line in a report
Alt + S
To bring back a line you removed using ALT + R
Alt + U
To retrieve the last line which is deleted using Alt + R
Alt + W
To view the Tally Web browser.
Alt + X
To cancel a voucher in Day Book/List of Vouchers
Alt + Y
To Register Tally
Ctrl + A
To accept a form – wherever you use this key combination, that screen or report gets accepted as it is.
Ctrl + Alt + B
To check the Company Statutory details
Ctrl + G
To select the Group
Ctrl + Alt + I
To import statutory masters
Ctrl + Q
To abandon a form – wherever you use this key combination, it quits that screen without making any changes to it.
Ctrl + R
To repeat narration in the same voucher type
Ctrl + Alt + R
Rewrite data for a Company
May 30, 2009 | Computers & Internet
Printing Quickbooks voucher checks with HP 6500 officejet printer
i have nearly the same problem and I'm going to continue to search and write 6500 voucher printing problem
May 18, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
ERROR ! EXITING TALLY!
Error! Exiting Tally! File Name C:\tally\data\004\Tr01320.500 Size 196608 Position 196608 Chars 128 (Done 0).
Apr 21, 2009 | Computers & Internet
Sub : TALLY 7.2 error
exiting tally! \r\ninternal error
software exception c0000005
(memory access violation)
Apr 20, 2009 | Tally T2250 Matrix Printer
How to take tally voucher print with date & time?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
When we saw preview of tally and print it both time getting like this way...
Qty no
1 pc
1pc
Mar 21, 2009 | Tally T9114 Laser Printer
Epson LX-300 Matrix Printer Logo
1,591 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
