Asus power supply problems
Hiya, thanks for the follow up.
Nope initial 'boot up' screen opens up as normal, then windows (XP) screen starts and then the machine dies...
The first time i thought all was ok.. sigh..
Am i right in assuming the new 650w supply should not make a difference? as the original was only 350w. It should just provide more capacity i think and not affect the boot up of the CPU.?
tob
  • tobes
    tobes Jan 08, 2009
    hiya, thanks, Just out of curiosity on the overclocking point. how hot would be 'normal' for the CPU to run? (tis pentium). It is not doing anything clever besides running 16 cctv cameras and saving images on a HHD.? warm enough to touch? or too hot to touch?
    I'll recheck the connections you suggest but my (slow) progress is that it now boots up 'normally' and lasts about 5 minutes before switching itself off again.mutter. I then have to wait about 2 minutes before it will switch on again.
    ta
    tob
    Scholar:
  • 111 Answers
It sounds to me like the power is being distributed incorrectly go into your bios and go to "restore defaults" or "return to defaults" something along those lines.
I do a descent amount of over clocking and that is a sign of too much/too little voltage reaching hardware hopefully my suggestion helps out
Regards,
Blazamane
Posted on Jan 07, 2009
  • Curtis Tuendemann Jan 08, 2009
    Ok did you make certain that the power supply is connected to the Mother Board correctly?
    Assure all peripherals have power
    Mains power is connected and the 4-pin ATX12V connector if applicable
    Overclocking is an advanced user technique and has to be applied by the computer owner so don't worry about that
    DO NOT touch the cpu you will get a nasty burn as they generally sit around the 60-70 degree celcius mark I do however suggest making sure there is good air flow to around your computer and that the fans are clean
    On a side note thankyou very much for the rating it is good to see people not just taking the information and running;
    Blazamane
My asus PC1005HA will not re boot after I upgraded BIOS
closed the unit down
now press the start button and hold down the delete button to get it to start in bios
check the boot sequence there
adjust as required and save
Aug 17, 2017 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Hi Running WIN XP (32bit) Have just replaced the Motherboard with an ASUS P5E3 Upon boot up, Windows XP dooes not recognise the USB mouse. The mouse is plugged directly into the MoBO's USB port. I...
Method 1: Initiate recognition of the USB device by using Device Manager----To initiate recognition of the USB device by using Device Manager, follow these steps:---
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Managerwindow opens.
  2. Click to select your computer as the location for the scan.
  3. On the Action menu, click Scan for hardware changes.
    Windows XP recognizes the new device.
  4. Close the Device Manager window.
If this method resolves the issue, you are finished.
If this method does not resolve the issue, go to method 2. Method 2: Disable power management of the USB hub---Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps:===
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
  8. Close the Device Manager window.--
If this method does not resolve the issue, go to method 3--- Method 3: Restart the computer---To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
If this method does not resolve the issue, you might want to review the articles in the "Similar Problems and Solutions" section, or contact Support. For information about how to contact Support, visit the following Microsoft Web site:---- http://support.microsoft.com/contactus
--- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 02, 2010 | ASUS P5E3 Deluxe Motherboard - Intel X38,...
Infected pc boots up intermittently
Microsoft does not "shut down" computers. If the PC is not booting every time it is because of the viruses or the power supply. If you press the power button and nothing happens I suspect the power supply. If you see the start-up screen every time you press the power button, but the computer does not finish booting go ahead and install your legal copy of Windows and that will fix the problem. Make sure you have the drivers for your motherboard, you'll need them to install things like chipset, nic, video, and sound drivers.
May 18, 2009 | ASUS P5S800-VM Motherboard
Repair start up failure
Well it depends on how severe is your start up problem, if the OS still loads lets say on Windows XP more or less you just have to repair the boot.ini, if you have your Windows XP CD load it to your computer(make sure that on the BIOS setup the intial boot devce must be your CD ROM) When the initialization finished press R to open the command prompt the type the following;
bootcfg /rebuild
The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
The first prompt asks Add installation to boot list? (Yes/No/All).
Type Y in response to this question and press Enter.
The next prompt asks you to Enter Load Identifier:.
This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
The final prompt asks you to Enter OS Load options:.
Type /Fastdetect here and press Enter.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Oct 04, 2008 | Computers & Internet
Windows fail to boot
How much power is the power supply? Could be the power supply not having enough power for your rig.
Sep 23, 2008 | ASUS P5QC Motherboard - Intel P45, Socket...
Emachine T2682 boots then dies
Nope, if the fan on any of the equipment stops, then its a power problem. Hightly suspect the motherboard is at fault loading down the power supply and even possibly burning out the power supply. I've seen it happen to many times.
Feb 23, 2008 | E-Machines T2682 (000002965) PC Desktop
Error - The Hard Disk Was Not Found
Boot into the BIOS, I think you hit the Delete key on Dell's to get into the BIOS, but I'm not sure. You should see some type of message at boot that says "To enter setup press XXX" Where XXX is the Delete key or some other key.
Once you're in the BIOS setup see if your HDD is listed. You may also find the option to reset the BIOS to default. Generally speaking this will not hurt anything and may be worth a try.
Dec 19, 2007 | Dell Precision M60 Notebook
No Power to PC
When your pc starts to boot up do you get two beeps one then another, although not two together, if not and only one beep occurs this could mean a memory problem, two beeps together normally a cmos bios problem.(Only part you've not changed was your ram) Do you get as far as the bios screen?, if so look for a line in advanced cmos settings, saying 'halt on all errors' dissable this and sometimes on boot up the problem will show itself in the initial dos screen. Keep diggin.
Oct 11, 2006 | ASUS A7N8X-E Deluxe Motherboard
Computers & Internet Logo
David Payne
David Payne
