Question about Dell Dimension 8200 PC Desktop
Plug & Play Configuration Error
I installed an ethernet card into my computer. I followed all the istructions that came with it. Now everytime I restart the computer I get this message: Plug & Play Configuration Error Strike the F1 key to continue F2 to run utility setup I have looked at the setup utility but don't really know what to change. Can you help?
  • 1 more comment
  • Anonymous Dec 06, 2008
    is the same
  • Anonymous Jan 30, 2009
    chkdsk /r
    chkdsk /p
    fixboot C:
    also:
    1 - Power down computer
    2 - Unplug power cord
    3 - Disconnect all peripherals except for keyboard, mouse, and monitor.
    4 - Restart system
    found addt'l info online:
    Plug and Play configuration error
    This error manifests itself on the newer Dell computers, such as the Dell 8200, Optiplex G-240, etc. The error seems to stem from the Nvidia graphics card and the Dell BIOS, which is included with the computer. Here is what we have found:
    -If the Nvidia card is present, no other PCI graphics or video card can be used (the plug and play configuration error will appear). We tested this theory by inserting an ATI PCI graphics card and we received the same error by the Dell system. As well, we tried with a Matrox graphics card (PCI G450), to no avail. There was no RT2500 in the system while we tested.
    If the Nvidia AGP graphics card is substituted for a Matrox or ATI AGP graphics card, then there are no longer any errors when booting up the system.
    So, if you plan to use one of these systems, you cannot use the Nvidia graphics with the RT2500
  • Rudisos May 11, 2010
    I have a Dell Optiplex GX260 and have started encountering the same config error on boot up. Tried the solution sugggested by sandrew and replaced the battery with a new one but the problem persists. Any suggestions?
    President:
  • 2,961 Answers
This may not be your ethernet card that is causing the fault, it is probably a flat cmos battery (CR2032) disc shaped battery normally close to the memory slots. This will need to be replaced, it's a simple job, just remove side panel of tower and flip the battery out and replace, probably cost $3.00. You will then be prompted on the next boot up to press f2 to set the date and time and then save and exit again for a reboot
Posted on May 29, 2007
I had the same problem except on a bare metal reinstall of XP Pro. I did a remove and reinstall of the battery and the problem went away!
Posted on Nov 29, 2008
Had the same problem. The PCI Ethernet card came in conflict with the Plug&Play Bios. In safe it looked that I had an andress conflict with the AGP card.
I tried many things till this solution helped me.
However the battery was ok. It guess that by removing and replacing the battery it delete the CMOS of the BIOS and force the BIOS to reinitiate and allocate all addresses from scratch.
Posted on Dec 26, 2007
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
hope this helps
Nov 30, 2011 | Dell Dimension 8200 PC Desktop
How do i install?
This device is a plug and play device and doesnt need any configuration before installation.
You need CAT6 ethernet ( copper LAN cables) to connect the switch to the other device from where you want to extend/expand your ethernet.
Best Regards
Dec 31, 2010 | Dynex DXESW5 5Port Ethernet Switch
How to instal printer on dilink dir-888
i 1 D-Link DIR-855 User Manual 0
Section 2 - Installation
If you are connecting the router to a cable/DSL/satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the Internet port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.
5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router to boot.
7. Turn on your computer.
These instruction are on the CD that came with the router
Here is the start:
D-Link DIR-855 User Manual 13
The DIR-855 includes a Quick Router Setup Wizard CD. Follow the simple steps below to run the Setup Wizard to
guide you quickly through the installation process.
Insert the Quick Router Setup Wizard CD in the CD-ROM drive. The step-by-step instructions that follow are shown
in Windows® XP. The steps and screens are similar for the other Windows operating systems.
If the CD Autorun function does not automatically start on your computer, go to Start > Run. In the run box type
“D:\DIR855.exe” (where D: represents the drive letter of your CD-ROM drive).
When the autorun screen appears, click Install Router.
Section 3 - Configuration
Configuration
This section will show you how to configure your new D-Link wireless router using the web-based configuration utility.
Web-based Configuration Utility
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default.
If you get a Page Cannot be Displayed error, please refer to the Troubleshooting section for assistance
Click Launch Internet Connection Setup Wizard to begin.
If you want to enter your settings without running the wizard, click Manual Configuration and skip to page 19.
follow the prompts.
You also can go to D-Iink.com for setup instructions
Apr 20, 2010 | D-Link DIR-855 Wireless Router
Trying to install a logitech rj45 network adapter (ethernet card). I have xp. BUT (a) the computer does not list it under network adapters (i already have one which i think is integrated on the motherboard...
Dear sir,
Welcome to once again Fixya support
According your problem it seems to be your try to install faulty Network card. So better is check with new good card.another possibility is some time pci slots fail to recognise a hardware, so try it with another pci slots of mother board.According to you onboard network card is dead, means motherboard fails to work when connect to a network,after successfull installation of network card also the possibility of motheboard not allow you to work with new network card ,same situation may arise,i am also managed same problems in several customer place while working as an computer hardware engineer.So try with new network card it may solve your problem
good luck
Jul 23, 2009 | Computers & Internet
Plug and play configuration error
reconnect all cables device to cpu .remove usb device if ther eis connect then asfter loading the operting system connect again.
Jan 29, 2009 | Dell Dimension 4500S PC Desktop
I installed 4gb of memory 4x1GB 240 pin and when booting up the computer recieved the decomplilation or disassembly prohibited.  What do I do?
HI there,
If you have installed the memory module correctly and are the right ones, than go into your bois and in there should be overwrite o clear this message.
Its only an alert message when you pc has been opened.
Regards,
Philip
Dec 06, 2008 | Dell Optiplex GX280 (99301) Motherboard
Compaq desktop presario w98SE
If there is no power when inserting the ethernet card. Then the problem is card related. If you plug the card in with no other devices except the keyboard and the mouse. Then the computer should go through a Power on self test. Look at the keyboard lights and make sure they light up. If they dont then your computer is not posting due to a hardware error. Therefore I would first look at the first possible cause the ethernet card.Make sure it is seated properly. Try another PCI slot. You should have more than one.Try another ethernet card and see if the problem persist. For detailed instructions on installation try this website for your model. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07111&lc=en&cc=us&dlc=en&product=92867&lang=en
May 13, 2008 | Compaq Presario 5000 PC Desktop
Bad direct drivers.
Dear sir,
I ahve problem like My laptop is C700 series of compaq(C772TU) I ahve changed it OS from vista to XP and now there is no audio output whenever I try to play a song it gives msg like " Please installproper device or select another device in configuration Error code: 88780078"
please suggest me proper solution
Mar 22, 2008 | Computers & Internet
What should I do after "Easy Software Setup"?
just unplug the Ethernet cable from the computer and plug it into the router and put the other end of Ethernet cable in to the wan port of WA840G
Oct 25, 2007 | Arris WA840G 802.11g/b (49832000100)...
Dell Dimension 8200 PC Desktop Logo
7,371 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
