Question about Panasonic Home Theater System System
Fult 61 do you no how to fix this
  • jades09 Jan 07, 2009
    it turns on then displays f61 then turns off
  • 2,071 Answers
Yes what is the problem of this unit?
Posted on Jan 07, 2009
Engin management light is on how to fix?
It needs to have a diagnostic tool hooked up and fult Codes read after this the technicians can fix fult and clear code this will turn light off
codes are logged when a problem occurs within the engine management system this turns the warning light on.
Feb 14, 2015 | Cars & Trucks
Tire pressure sensor fult 2004 ford explorer
Tire Store
They will fix the tire or
replace the sensor
Aug 09, 2014 | Cars & Trucks
My 2003 jaguar has the ABS lite one and it says park brake fult.
Emergency brake handles or pedals on most vehicles should be locked on about half of it's throw, approx. 8 to 12 clicks if it' s a clicking type.
Apr 27, 2012 | 2003 Jaguar S-Type
My jeep will start for approximately 3 seconds and then just turn off. I dont know what it is but i have been told that it was the crankshaft position sensor but i want to get another opinion. If this is...
oh please!!!! there are so many sensers on your jeep,, any one could cause this fult,,,,,
if its a sensor hook the jeep up to the computer and it will give you the fult coads its easy to fix it with them,,,,and you will be saving money,, if you just hook up a new sensor the computer will still see the old fult coad and may still not let the engine run right, so your running around in rings or nothing,,,get the coads read,
Nov 28, 2010 | 1999 Jeep Cherokee
Big problem with sprag clutch
if the clutch sprag is giving fult the gearbox must be removed to fix it
Nov 21, 2010 | 1993 BMW K 1100 RS
My Junk Electric Artica refrig drops to 28 degrees on frig side. It is set at 44. It does stay around 34 90% of the time. The freezer side set at 6 will drop some at the same time. The ice maker doesn't...
its one of three fults,,,
it could be the thermostat playing up,,,fit a new one
it could be it needs a re-gas,,so re-gas it
or the compresor could be playing up,,
if the compresor is at fult it needs a new compresor and a re-gas to fix the problem,,,
the compresor is a pricy part to replace,,
how old is it??? would it be cheaper to just buy a new unit insted of patching up the old one? as its only likely to brake down again at a later date!!!
so it could be cheaper to buy new in the long run
Jun 26, 2010 | GE Profile PFS22 33" Artica French Door...
Car died and now runs in high idle for ten mins or so then goes from high to low idel and runs really ruff
this sounds like its the car's CPU playing up,,,if there is a fult coad it can put you in "get you home mode" the car will still run but very very badly check out the fult coads
Nov 15, 2009 | 1998 Nissan Altima
Expolosions when engine to 3,000 rpm
its an ignishion fult its back fireing on you, and may split the exhaust pipe if you dont sort it out it wont do the "cat" any good as well
could be any number of fults here!
Oct 22, 2009 | 1987 GMC R3500
I WHAT IS FULT OF F61 IN SA-AK177
HELLO
F61 means a protection code which normally means there is a fault with the audio output IC. Check all your cables for shorts etc, and try hooking it back up. If the error is still there you'll have to put it in for service.
ALL THE BEST!
Sep 01, 2009 | Panasonic Audio Players & Recorders
Panasonic Home Theater System System Logo
37 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
