Question about Panasonic PT-53WX42 53" Rear Projection Television
Convergence problem on rear projection Panasonic PT53WX42?
Hello, I have a 5-year old rear projection Panasonic PT53WX42 TV. The TV was working great until the other night. I put the TV on and it appeared that it was out of convergence. I can see red, blue & green images of everything that is on the screen. I tried to adjust the convergence but with no luck. The problem appears worse on the right side of the screen (the red image is more prevalent there). Nothing was changed with my set-up (i.e. speakers, lamps and other items around the TV). Does anyone have an idea of what the problem might be? I don't have any experience with TV repair, but I want to know if I need to contact a service provider to repair the TV or can i repair it with a little bit of guidance. Thanks for all your help. Anthony
  • sanderella Mar 13, 2008
    Panasonic Projection
    Television … Ongoing Convergence Problem
Chris Palmer gives detailed instruction on how to replace the convergence IC's. Go to his blog at: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Sep 26, 2007
  • 1,476 Answers
If you do not have any electronic experience I would doubt that I could talk you through the repair. You have bad convergence ICs. This is a common problem. I sometimes do a set a day. They are not expensive and not hard to replace if you have done it or have an electronics background. Cost should be between $100 and $200 US. Call a reputable repair shop and you should have it working fine in no time. Good luck.
Posted on Jun 07, 2007
  • Nicoduv4 Jan 05, 2012
    We just Changed the convergence. Chips n now no power at all any suggestions
Hello, I have a 5 year old 47" projection tv that has worked perfectly until recently. It was running fine one night and I turned it off for the night. The next night when I turned it on, there were...
laskey66,
You have a bad convergence circuit. You will need to replace the convergence ICs minimum and could have a problem with the digital convergence box. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, where to get the parts at the best price and how to complete the repair.
Thanks for using FixYa and for the great rating.
hardrocko
Oct 06, 2010 | Hitachi Televison & Video
NO PICTURE OR SOUND
Most likely the Li-Fi lamp is bad. If it is and your TV is less than 5 years old the lamp is covered under warranty by Panasonic but must be replaced by a Panasonic dealer. If its less than 2 years the labor is also covered. If its less than 5 years old and it appears the lamp isn't firing I would contact Panasonic to have a technician look it.
Sep 10, 2010 | Panasonic PT-61LCZ70 Television
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have an 8 years old rear projection TV. Try to
May be a short. Contact tvrepairkits.com and see if they help diagnose it further.
Feb 19, 2010 | Televison & Video
REAR PROJECTION HDTV ISSUE
Decoding the number of beeps may be possible with the owner's guide but this type of problem is normally due to a failed power supply.
These are often mounted on separate boards located in the bottom of your set and can be identified by the much larger parts you see on the board and possibly its relationship to the AC cord coming in. While these can be repaired, the cost of that will approach the cost of a new assembly.
Unfortunately, modern, more energy-efficient power supplies have some critical components that if bought cheap, don't last very long and frankly, 5 years isn't bad, I read of many dead within the first year.
Jul 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Red and blue
convergence amp ic going bad.
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Wavy horizontal picture
the vertical IC outpt needs to be replace
Dec 29, 2006 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
3,415 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
