Question about HP Officejet 4355 All-In-One InkJet Printer
My printor hp 4355 all in one to scanner unit A 4 document scan to scanner and output print is micro size copy and scanner speed to very fast to scan
I dont have CD now how can i install it
Posted on Jan 09, 2009
My printor hp 4355 all in one to scanner unit A 4 document scan to scanner and output print is micro size copy and scanner speed to very fast to scan your sugget for my printor problam quiqly for mail to my id thanks chetan
I need to know the settings on the hp photosmart c7200 printer I should be set for me to get the absolute clearest scans of docs and also my drivers license
Hi. Here are the specs of your printer or simply follow this link to know more.. http://www.shopping.hp.com/shopping/data_sheet/cc567a.html
Print specifications -Up to 1200 x 1200 rendered dpi black when printing from a computer -Up to 4800 x 1200 optimized dpi color when printing from a computer and 1200-input dpi -Print speeds vary according to the complexity of the document -Panorama-size printing -Method: drop-on-demand thermal inkjet -Language: PCL3 GUI -Duty cycle: Up to 3000 printed pages per month
Copy specifications -Copy resolution up to 4800 x 4800 -Digital image processing -Up to 99 copies from original (varies by model) -Zoom to 400%, fit to page (varies by model) -Copy speeds vary according to the complexity of the document.
Scan specifications -Image editor included -Integrated OCR software automatically converts scanned text to editable text (if installed) -Twain-compliant interface -Resolution: up to 4800 x 9600 dpi optical (varies by model); 19200 dpi enhanced (software) -Color: 48-bit color, 8-bit grayscale (256 levels of gray) -Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
May 06, 2011 | Office Equipment & Supplies
When scanning with the native scanning software, the scanner runs very fast but file size is huge. When I use Adobe 9 to scan, my files size is much smaller but the scanner pauses after each page. I need...
I would expect the problem with the Capture perfect fike size is down to the compression chosen for the output file. Ideally black and white inahes should be Group 4 TIFFs and Colour or Greyscale should be JPEG. Alternatively you may want to check the scanner is set to 'scan ahead' in the twain settings in Acrobat. If it is set to anything else the scanner will slow down to allow the PC to process every image. With 'Scan Ahead' turned on the scanners memeory buffer the PC speed a little giving you faster scanning.
Jan 25, 2011 | Canon DR-5010C Path-Through Scanner
IseMY Hp all in one 4355 printer is unable to scan
The HP Officejet 4355 can print, scan, copy and fax.
You need to install the printer software to print and scan. Copy and faxing does not required software installation.
Regards,
Rizwan
Feb 11, 2010 | HP Officejet 4355 All-In-One InkJet...
My scanner blinks on and off not scanning the document
Check for print if printer is working ok , try the copy option and if its works ok need to check for software and if copy is not working then Scanner may have dust on the glass and reflection roller clean it’s from the scanner area where you find lamp is glowing to scan paper
pls do check the message on panel which could give better information for problem
Nov 07, 2009 | HP Officejet 4355 All-In-One InkJet...
Print cartridge prob [tri-color] refer to ... doc to troubleshoot
HP Officejt J4680 - All in one Printer from HP, whcih will have Printing, Fax, Scanner and Copier facilities.
Normal catridges recommened by HP are given below :
01. HP 901 - Black which will print 200 Pages.
02. HP 901 - Tri Colour which will print 200 Pages.
03. HP 901 XL Black which is a bigger one that will print 900 pages regulary.
This printer is most rugged one used by Home as well as in offices.
The follwoing message regarding this Printer taken from HP Website which gives information about the printer quality.
Enjoy the convenience of wireless connectivity with our Officejet J4680 All-in-One. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with our Officejet inks, you'll get high-quality printing at a lower cost per page than with a laser printer. Reliable and versatile
  • Print, copy, scan and fax with a single machine
  • Print fast, at up to 28 pages/minute black, 22 color##
  • Fax at speeds up to 33.6kpbs
  • Streamline big tasks with the 20-page automatic document feeder and 100-sheet paper tray
  • Preserve important documents for decades without fading1
Solution:
Please use the originai catridges for this printer and there will not be any issues.
In spite of this, the problem continues, please call the local HP Authorized Printer vendor to solve this problem.
If the Printer is under warranty, you will get a replacement printer with same or the higher configuration which is available in the market.
Jul 21, 2009 | HP Officejet J4680 InkJet Printer
My psc 1610 scanner function is not working, the output was totally in black while scanning a document
My HP Psc 1610 all in one can print & copy but can't scan. I already installed the driver for Windows 7
Jul 09, 2009 | HP PSC 1610 All-In-One InkJet Printer
I can't print scanned material to full size.
You can try the freeware at the link below:
http://www.bestsoftware4download.com/software/t-free-freekapture-download-npbskbaz.html
The description states: "You can also use FreeKapture as an 'ad hoc' copy machine (by using your printer drivers 'how many copies to print' option)."
It works with all twain compliant scanners. Download and install and then point it to your scanner.
Good luck, and please let me know how it works out for you.
Mar 19, 2009 | BenQ Scan to Web 4300U Flatbed Scanner
Hp officejet 4355 scanner problem
don't on prints..super clean scan glass, slit of glass where originals are fed.
Nov 21, 2007 | HP Officejet 4355 All-In-One InkJet...
HP Officejet 4355 All-In-One InkJet Printer Logo
105 people viewed this question
Seeker5211
Seeker5211
