Question about Cameras
How to zoom and take photos using nikon dx 40 slr camera with 18-55 mm lens
    Novelist:
  • 121 Answers
Raju70us,
If you are new to DSLR camreras then this should work for you, you will have to rotate the ring on the lens, look through the viewfinder while trying it and you will notice the camera zooming in, the lens will be autofoucing as it is held on the subject in automatic mode. There are other settings you will like to try once you are used to the functions. That will come to you as you are developing your skills. Enjoy your new camera!
randy320sgi
Posted on Jan 07, 2009
Camera body/lens
Almost all newer Nikon Slr and Dslr cams use the F-mount, So properly yeah
Sep 09, 2015 | Nikon Cameras
Clean inside lens fungus
Whatever you do, do not open the lens. You will never be able to reassemble it. If the fungus is adversely affecting your images, you need to take it to a qualified camera repair man or send it to a Nikon repair depot found on the Nikon website. If it is not affecting your pictures, I would just live with it.
Oct 05, 2013 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
What lens can I use the the Nikon N6006 35 mm SLR Camera?
The Nikon N6006 will use just about any Nikon F-mount lens made in the past 55 years. About the only exceptions are some rare (and very expensive) fisheye lenses and the newer DX lenses specifically designed for digital cameras.
Jan 11, 2013 | Nikon N6006 35mm SLR Camera
My Nikon 18-55 mm lens turns easy when zooming in, but is stiff when zooming out. There is no roughness in the movement that would suggest dirt.
hi there,
the zoom-rubber might have been loosen, so it moved too easy while you use it
you can fix it by contacting nikon representative technical support
thanks
Dec 12, 2010 | Nikon D60 + AF-S DX VR NIKKOR 18-55 mm...
Replacement rubber zoom band nikkor 17-55 2.8
yes...check with Nikon or I have seen replacement rings on ebay even...I'd check with nikon or a local nikon repair facility for parts..
Jan 25, 2010 | Nikon Zoom-Nikkor 17-55mm f/2.8G ED-IF...
My nikon 55-200 zoom lens is stuck at full zoom
Don't force it.
Did you get dust or dirt in it?
The only solution is to bring it in for service or send it to Nikon if it is a USA model.
Nikon USA will NOT repair any gray market items.
Jul 12, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Squeaking when try to focus. will not focus
My lens is also doing that same thing... and I just posted pretty much the exact thing you said...Mine squeaks and goes in and out really fast.. I do know that you can put the camera on manual mode and focus manually on mine, but would like to have the auto focus sometimes too. If I dont get an answer soon, I may send it in... I believe its a motor problem in the lens....
May 28, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Focal length equivalents
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}I believe it is equivalent to a 35 to 210mm lens on a 35mmcamera. If you are considering a Nikon such as the D60, D80, D90, etc.,the standard lens sold with the camera is 18-135mm. This is not the sameas an 18-135mm on a 35mm film camera. The equivalent 35mm film cameralens would be 27-202mm (you multiply by 1.5), about the same as what youhave now. If I were planning to do wildlife photography, I would buy a usedNikkor ED 70-300mm AF lens on E-bay. You should be able to get one for$200 or less (the new price is $550+). This lens is designed for a 35mmfilm camera and is the equivalent of a 105-450mm when used on a Nikon digital cameras. Additionally, it is compadable with the automatic features of the Nikon digital camera bodies. This would give you an excellent portrait lens at 105mm and extra long reachfor wildlife. The fast shutter speed and stabilization circuit on thedigital camera should make it usable in daylight without a tripod. I havethis lens on a Nikon film camera and it is a superior lens. At a 1/1000second or faster shutter speed, I get sharp hand held photos.
Nov 17, 2008 | Fuji Cameras
Nikon dx swm 18-55 mm
This is a very common problem. It sometimes happens without cause, sometimes by tightening or removing a filter. There are a couple of keys that keep the front lens from rotating while zooming that are very thin and easily bent. They have to be removed and straightened, and the rear piece you see floating has to be reinserted. It's about a $40 job and half-an-hour by a local independent repair shop. Expect to pay Nikon twice that.
Aug 04, 2008 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
The Zoom ring is stuck between 24 mm and aprox 40 mm. What can I do to fix this? Any hints would be appreciated. Charlie
My lens started catching as I zoomed in and out and would not go wider than ~24mm. The problem is one or more of the screws holding the zoom mechanism comes loose and jams. Follow this link for the fix; took me ~20 min to repair (I went very slowly)! Much easier than taking it apart from the rear.
http://photo.net/nikon-camera-forum/00Pegi
Good luck...
-David
Feb 16, 2008 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Cameras Logo
56 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
