Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Error Code E000732-001
When I power on the screen it gives me the error code E000732-001, it tells me to turn the power off and on again, however upon restarting the machine I receive the same error.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
Dec 04, 2014 | Konica Minolta bizhub Office Equipment &...
Motherboard Error Code 62
first replace your ram,if problem occur,then check your c.p.u
Jan 26, 2014 | Biostar Computers & Internet
I keep getting an error code on my wii can you please tell me what it means 51030
Not only will I tell you what it means, Kyle(can I call you Kyle? Good), but I will offer a solution to this problem AND give you something that will help you out with any future Wii errors. Brace for HELPFUL.
Error code 51030 means that you're unable to connect to your wireless network. Woah woah woah! Easy there Kyle, don't throw out your Wii just yet; wii can fix it! (I do puns too)
Check out your router. Is it on? It should be. Now turn it off. Is it plugged in? Unplug it. Now do a little dance. Finished? Great. Plug it back in.turn it back on. Fire up the Wii and give it another go.
Still no good? That's no good! Let's try messing with some settings on the Wii. I know I know, settings are scary. Everything should just be automatic these days. Well don't worry, I'm going to walk you through it.
Turn the Wii on and at the main screen (the one with the channels) point to the bottom left. With your wiimote, I mean. C'mon Kyle, that'd be awkward if you were just pointing at your screen. Anyways, click it, then navigate to Wii Settings > Internet (it's on page 2). Click on a new connection, or delete an old one and then click on it. Go through and re-set-up your connection.
Everything should be awesome now. But if you recall, I said I'd help out with FUTURE Wii error codes as well. Am I magic, you ask? Yes, but that's irrelephant (not pertaining to elephants) and irrelevant.
So now, Kyle, I bequeath upon you this link. Use it wisely.
Notice on the left side there's a little box labelled "Error Code Lookup"? I think you can figure out what goes there.
It's.... it's the error codes, just so ya know.
RECAP TIME:
-Error Code 51030: Unable to connect to your wireless network
-To fix it, unplug and replug in your router. If problems persist, set-up a new wireless connection on the Wii. (Guide for that here)
-Future Error Codes can be check out here (box labelled "Error Code Lookup" on the left side)
I feel like we've learned so much today. The moral of the story? Anything is possible through teamwork.
Hope everything works out!
Mar 23, 2011 | Nintendo Wii Console
We have an error code E000004-10 and the machine will not turn on.
This is a problem with the fuser not getting hot enough. Try resetting the error code by going into service mode. Press additional functions key, then the 2 & 8 keys at the same time, then the additional functions key again. Select copier, then function, clear, then err, press OK. Power down the copier and power back on. If the error returns record the numbers after the dash. This is an important sub-code that tell you exactly what the problem is. The 0010 code says that the copier was turned of and back on without clearing the code first. The indicates that there may be a problem with the heater, DC controller, the heater power supply, or connectors on the rear of the fuser drawer. Hope this gives you some ideas of what to do.
Feb 02, 2011 | Canon imageRUNNER 5570 Copier
We have error code E000001-004 upon turning it on, then the screen goes black and no copies can be made.
You have a faulty fuser unit that needs replacing. The fuser unit is the unit that gets VERY HOT in the left drawer section. Two screws either end of it removes it. Check that there is no paper caught inside it causing it to overheat and then, when you put the machine back on you will have to reset the error code in engineers mode. Resetting the code may get you out of trouble for a while. To do this press the following buttons in this order:
the 'head' (a head with a star symbol inside) then hold down the '2' and '8' keys at the same time - then press the 'head' key again quickly - this will get you into service mode - press 'COPIER' then 'FUNCTION' then 'CLEAR' - now press the top selection 'ERR' followed by the 'OK' on the bottom left of the screen. Now turn the machine of by the power switch and wait 10 seconds. Power up now and if you're a lucky one, you'll be back up and running but for how long I don't know. Maybe 5 mins maybe 5 months.
Good Luck
Nov 04, 2009 | Canon imageRUNNER C3220 Color Copier
Installing error code -106
I suggest go to Start/Settings/Control Panel/Add remove programs.
Check and see if the program is in list and remove it. While in control panel go to system/Device Drivers check non have a yellow mark on them if so reinstall drivers or upgrade Reboot and try again.
Jul 22, 2008 | Computers & Internet
Canon ir 6570 error
Im new to this forum. I have an IR6570 giving me an error code E808-001, please help,
May 15, 2008 | Canon imageRUNNER 5570 Copier
Error code no. E00004-0000
the fuser has a bad
thermistor or
thermofuse or
lamp
Dec 20, 2007 | Canon imageRUNNER 5020 Copier
Xbox360 error code
Here is how you interpret the LEDs to get the code number:
  • All four lights flashing - 0
  • One light flashing - 1
  • Two Lights flashing - 2
  • Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
0023 (not yet known)
0101 (not yet known)
0102 unknown error
Oct 12, 2007 | Microsoft Xbox 360 Console
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
3,753 people viewed this question
old marine
old marine
