Question about Kirby Generation 3 Bagged Upright Vacuum
Kirby G3 won't run
Kirby G3 has stopped running. It used to work with a good kick, now the light flickers for a microsecond, the shaft turns a quarter turn, and then nothing. I took it apart, cleaned and inspected everything, and then it worked smoother than ever, but only one time. Now it won't run at all. It now has a new cord, the fan is OK, and poking the nozzle and bag safety switches with a screwdriver makes no difference, so apparently it is not them. Is the problem with the power switch? or The brushes? or something else? Is there some place I can find a wiring diagram, so I know all the wires inside are in the right place?
  • 883 Answers
Sounds like brushes not being pressed down to the commutator shaft. pull out brushes and clean the brass brush guides and then apply a light coat of grease to brushes. however, what exactly do you mean by "the fan is OK"?
Posted on May 29, 2007
My Kirby vacuum won't turn on the light flickers but the motor doesn't run
Check the cord. If it is not carrying enough voltage the motor will not run.
Feb 08, 2017 | Kirby Vacuums
Kirby G3 vacuum shampooer is not picking up water.
Belt may be slipping or wore out. Are you running the brush too low to the carpet. That will prevent it to work.also you have to take the cap off the container when sucking the water up.
Sep 01, 2016 | Kirby Vacuums
The brush roller will not turn.The roller is about a year old and was working fine. The ends turn
If the roller ends turn (are not jammed by hair etc.), then there are tthree things to look at:
1. Is the belt that drives the roller in good shape?
2. Is the belt engaged on the motor shaft
3. Is the motor turning?
Dec 16, 2015 | Kirby G3, G4, G5, G6, Ultimate, Diamond,...
Kirby Vacuum Cleaner on/off switch won't stay switched on
If the motor turns on turns off in the course of the vacuuming, check the cord or the switch This is how you replace your cord on a Sentria vaxuum.
Jan 15, 2013 | Kirby Vacuum Cleaner Switch For G3-Sentria...
My Kirby G3 diamond series won't turn on
Hi There, The most common problem by far is that the cord is faulty. This is a pretty easy repair to do at home. If your machine was randomly cutting out before it stopped altogether then the cord is likely the culprit. If however it stopped all of a sudden with no warning then it is possibly a switch or motor issue which is a much harder repair to achieve for a novice.
The kirby cords are not terribly expensive (and I have linked a how to video showing how its done) so if you need a new one I would say DIY is the go, otherwise spend the $25 get a pro to take a look.
May 22, 2012 | Kirby Generation 3 Bagged Upright Vacuum
Our Gen3 Kirby still works but is extremely loud not - I am currently only using with the wood floor attachment (no brush) - thoughts?
this could be the impeller fan next to the motor shaft under your attachment hose connection.
to determine this, remove the hose from the unit, and turn the fan shaft with your hand looking down inside the unit. You should see blades on the impeller fan, and they should all look squared off and curved. If any of them are broken or worn, it will make the unit louder than normal.
Also, the hose attchment has an increased noise more than using the brush attchment anyway because it increases the suction for the hose more than on the carpet. IE the motor runs faster giving you more suction.
An Impeller fan for the G3 Kirby will run about 18-39$ for the fan. More for labour.
Good luck,
Mark
Nov 07, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G3, no manual & would like to shampoo
I have the same issue...just got a used G3...but no manual. If you go to the Kirby website, there are videos on several issues...may help.
Mar 15, 2009 | Vacuums
Replacing brush roller on my KIrby g6 limited edition
You need a new belt. When the green light goes out, that means your brushroll has stopped spinning. Here's how to change it....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Even if you just replaced the belt, this guide will help you make sure that you got the brushroll back in the right way.
Hope it helps....
Marci
Dec 08, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
551 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
