Question about Solis Palazzo Espresso Machine
After descaling the machine and rinsing it, the clean button and temperature and descale indicators flash and no other functions work. Any advise?
The machine is still stuck in the descaling cycle. You must open the steam valve and let all the liquid drain from the tank. This takes approx. 45 min. because it comes out intermittenly. After this is complete all the front buttons will flash. Close the steam valve, rinse the tank, then fill it with fresh water. Open the valve again and let all the water drain from the tank again. This time it will only take a couple of minutes. After it has completed close the valve and the machine will return to normal operation.
Posted on Jul 05, 2007
My machine requires a much longer descaling cycle. So during the cycle I add another 2 quarts of water. This takes much longer, but seems to work for me.
Posted on Jan 11, 2008
Water temp and descaling lights flashing
you need to descale the machine as per instruction
Oct 15, 2012 | Solis Palazzo Espresso Machine
I am trying to descale my solis palazzo, I did as instructed, opened the nozzle to let water out, light is flashing but nothing is happening, waited 45 minutes, the only button lit up is the one with the...
Hi Descaling the Palazzo: The Palazzo is programmed to descale the boilers on its own, when set in the correct mode. You program the machine to descale it's self, do the following. With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next, have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz's. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don't turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water and push the water button on the right. It will light(very dim), then open the steam knob again/ The red light will go out and it will start to heat and your ready to go.
Jul 05, 2011 | Solis Palazzo Espresso Machine
Solis pallazo rapid steam. I can't remember how to clean the system
Descaling the Palazzo: The Palazzo is programmed to descale the boilers on its own, when set in the correct mode. You program the machine to descale it's self, do the following. With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next, have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz's. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don't turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water and your ready to go.
Sep 10, 2010 | Solis Palazzo Espresso Machine
I have a Solis Palazzo machine. My question is:
HI When was the last time you descaled? This can have a temp lowering effect if you don't descale on a regular basis. Program you water hardness so its set on 4. This will tell you when you have to descale. Descals is not the same as cleaning. Its a special acid that disolves the deposits inside the boiler.
Jul 24, 2010 | Solis Palazzo Espresso Machine
Solis palazzo espresso maker / water tank problem
HI
Did you push the water button, before you opened the knob? When you finished descaling did the lights change? On any compact machine you need the let the pump stop on its own. Then go to the next part, rinsing. Again letting the machine stop on its own. Pump will stop and the lights will change. Once the machine has finished rinsing. You will have a steady water light and a blinking green light. Put your tank back on with fresh water, then push the water button(far right), then open the knob for water. The red light should go out, and the machine will heat again.
Dec 22, 2009 | Coffee Makers & Espresso Machines
All leds flashing, after cleaning program
unplug it.... for about ten minutes or so
Mar 18, 2009 | Solis Palazzo Espresso Machine
Hi, cleaning cycle stalled, all lights on, machine stuck
We forced the mechanism!! Works like a charm!  I think we'll get a backup, the french press didn't cut it this AM.......
Feb 14, 2009 | Solis Palazzo Espresso Machine
Solis Palazzo Descaling (?) Problem? Please Help!
Hi
He has the first part correct, but when you rinse the machine with fresh water the machine needs to quit on its own and you will know this when the descale light is off, but you will have a flashing green light and a steady red light over the water drop. Refill the water tank, the close the steam knob and then open it again. This will clear the red light and then the machine will start heating. IMPORTANT on any automatic machine is when the water tank is off the machine don't do anything with the beans. A chip of bean in the water receptacle can be a big problem for the machine.
Jan 28, 2009 | Solis Palazzo Espresso Machine
Solis Palazzo - stuck in descale mode?
Are you refilling the tank during this process? You need to let in run dry, and then the buttons flash. Then, refill the tank with clean water, and let the tank run dry again.
Dec 11, 2007 | Bosch Benvenuto B30 Espresso/Coffee Maker
Solis Palazzo Espresso Machine Logo
276 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
