Question about Sony Mavica MVC-CD300 Digital Camera
Can not finalize the camera to transfer photos
When I turn on the camera it says "turn power off and on again" continually, I've tried to remove battery and remove disc!
Hi
which make that camera tell me the brand to easy to solve that ok
any way cheek the battery is full charge or try to put new one.
that time not open your disc drive becoz when ever do like this you are lost
old memories images so be careful handle that
south asia camera man association.
Posted on Jan 07, 2009
Samsung PL50 with Samsung 2GB memory card says 'memory full' even though I've cleared down the memory via my laptop.
Have you actually formatted the card in the camera ? Just copying the photos does not remove them from the card
Jul 15, 2017 | Samsung SL202 / PL50 Digital Camera
My computer doesn't recognize my fujifilm finepix 98100 anymore.
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Nov 23, 2012 | Fuji FinePix Cameras
Transering photos Nikon coolpix S570
Use the "Copy" command in the playback menu. While viewing your pictures, press the MENU button and select "Copy."
Feb 13, 2012 | Nikon COOLPIX S570 Digital Camera
I put newly charged panasonic evolta batteries into my Pentax E10. Took a couple of photos. Then plugged the connector into the computer and managed to transfer one photo into my photos library, but not...
When you reboot the computer, that message should go away. Use an external SD card reader and transfer your photos that way. They are inexpensive and relieves the need to connect the camera to the PC. It will transfer your photos much quicker too
May 15, 2017 | Pentax Optio E10 Digital Camera
Hello, I have a Lumix DMC-FS10, I have found that some of my photos have downloaded to thumbprint size which won't seem to go any bigger without distortion and some are normal I unfortunately deleted...
Actually, you still might be able to get those photos back, even though they've been erased. Try not to take any more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos. This article reviews and outlines several of the better ones.
This sounds like the problem may have occurred because you might not have formatted the card in your camera as recommended by the manufacturer. If true, after you've recovered your photos, format the card in your camera using the camera's format feature. This will prevent this from happening again.
Sep 20, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
I can no longer transfer photos from my Coolpix 4300 to the computer. Is it a camera or lead fault pls?
Problem could be either a lead or might be within the camera. Remove your memory card and insert it in the card reader on your computer. If it reads okay and transfers the photos then take a few more photos and try again using the camera connected to the compter. If it fails again try a new connecting cord. Good luck.
Jan 05, 2010 | Nikon Coolpix 4300 Digital Camera
Some pictures already there
Try using a separate card reader to download your pictures to a folder you create on your desktop.Then you can carefully rename the ones that the computer thinks are duplicates and then move them to their final destination. Your camera is obviously creating new folders but not continuing the sequence of numbers on the photos. You might want to e-mail one of Kodak's tech people with your problem to see if they've come up with a work-around.
Sep 09, 2009 | Kodak EASYSHARE M1063 Digital Camera
It says "turn the power off and on again"..!!
try gently pulling and twisting the end of the lense and i mean gentle dont pull till it pops than switch it off and on again and you problem should be solved
Oct 26, 2007 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Mavica MVC-CD300 Digital Camera Logo
97 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
