Fujitsu 36CS Air Conditioner
Problem for Fujitsu 36CS Air Conditioner
My fujitsu inverter does not cool below 18deg C
By markr956 on Jan 07, 2009
Model AR-RY3.
How do I get it to a cooler temperature?
Comments:
Jan 08, 2009
- Hi notsomot,
I
Jan 08, 2009
- Hi notsomot,
I refer it colder. I brought 2 air cons it one and an LG. The LG is set to 18 degrees also but it is defiantly a lot colder. How accruate is the controller?
Thanks in advance
Best Solution
posted on Jan 08, 2009
Helpful)
notsomot
Rank: Guru
Rating: 86%, 41 votes
Heya Mark,
Fujitsu air cons are factory set at 18degs you cannot change it without going through all the controller programs. Normally air cons are serpose to run around the 20deg point, is the air con not running effectually or do you just really like it cold.
I could check with tech help and see if I can send you the derictions of changing the minimum set point but it will not be good in the long run for your unit
Comments:
Jan 08, 2009
- Hey again Mark,
Okay the air cons dont read the temp from the controller they read it from the return air at the unit. 18 is very cold and you should make sure that the unit is sized at the right size. If you give me the room size with the amount of windows and such i will make sure the unit is the right size.
Do you have any type of thermostat in your house that you can read the supply air from the air con?
If you can get me some air measurements I should be able tell if that air con is working, because 18 is very cold :P
Was this helpful?
Yes
No
Popular Solutions for Fujitsu 36CS Air Conditioner
Questions and Unsolved Problems for Fujitsu 36CS Air Conditioner
Do you recommend Fujitsu 36CS Air Conditioner?
Answer
Answer
There was a wreck with a gas truck and a train about 4days ago and it mest up some power lines down... (More)
Answer
Our fujitsu invertor airconditoning unit is making a high pitched sound when operating. We had it... (More)
Answer
the timer light keeps flicking and the air con doesen't work ???
Answer
all the lights keep flashing on & off and absolutely nothing is happening when i try to turn the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu 36CS Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
