Question about Honeywell Programmable Thermostat Heater
My honey well thermostat keep clicking and I can't program it
The electrical power went out and when it was restored my therostat will not operate ...it keep clicking and I can not program it... and my furnace will not work....
    Scholar:
    New Friend:
  • 70 Answers
If you have a programmable thermostat and it is a couple of years old you will probably have to install a new one. What kind of thermostat do you have? You can turn power off to furnace and then take thermostat off wall and take wires marked r & w and connect them together your heat should come on when you turn power back on. If not you could have blown the 5 amp fuse inside furnace. I would check the fuse inside of furnace. If you take panels off front of furnace you should find a controll board inside that runs furnace.If you have anymore question just reply back to me
Posted on Jan 16, 2009
Electricity went out, when restored remote does not work
One of two options here honey... the battery in the remote is flat and needs replacing or... the remote receiving device in the unit was blown, or now has no power to operate. Change the battery... replace the remote... if the problem remains then the problem lies in the controlled device itself. DO NOT attempt this repair yourself.
Mar 27, 2014 | Universal MX-900 Remote Control
Honey wire
Look for reset button push in and try to Program if this doesn't work time to replace T-Stat.
Jul 05, 2013 | Honeywell Programmable Thermostat Heater
How do I connect the two thermostat wires from a Honeywell R8184G4009 to a programable thermostat. My old thermostat is not marked.
On the Protectorelay Oil Burner Control R8184G4009, you connect the two thermostat wires @ "T" and the other "T". On the ACE Smart Temp Universal programable therostat, connect one wire to "Rh" and the other wire to " "W". Be careful if you are using this thermostat for A/C. In that case, make sure there is no jumper between "Rh" to "Rc".
Feb 02, 2013 | Honeywell Protectorelay Oil Burner Control...
Heating not working and Honeywell Thermostat Heater states that the temperature is 45 degrees celsius.
without seeing it its hard to say, the thermostat controls the boiler and/or diverter valve depending how its been wired, the diverter valve shunts the water to were its needed ie from one circuit to another if you have two therostats there is a conflict somewere, best bet to have an engineer sort the wireing out
Dec 28, 2011 | Honeywell Programmable Thermostat Heater
I have a white-rodgers type #1F86-241 thermostat. Not sure if my problem is thermostat or not but this is what I have. currently have two zones first floor and second floor. Second floor is problem. I...
From what you're saying I would reccomend that you start with a new thermostat. I think that will take care of your problem, but I've always started troubleshooting by doing the easiest and least expensive first. Hope this help. Thanks
Nov 21, 2010 | Heating & Cooling
Honey friedrich replaced with a honeywell RCT 8100
on some of the older models you must go into the installers program to make sure it is set for heating and cooling. also possibly gas or electric heat. and fan on during call for electric heat. these are all sellections in the installers program and usually they have one or more options for each sellection. see the installers guide for your tstat.
Nov 23, 2009 | Honeywell Electronic Programmable...
Heating keeps coming on out of the hours it programmed too
Turn off power to tstat. Go to program and reprogram tstat after power is restored to stat. If problem continues you have a bad tstat. Rus
Nov 06, 2009 | Honeywell Programmable Thermostat Heater
Unti wont keep set temp, it actually keeps changing the temp. itself..either 60 or 90..like it has a mind of its own. Is there a reset option or is it just done
These temperatures are generally associated
with default (factory) values. Programmable
thermostats have batteries/capacitors to retain
program memory during power outages.
Check batteries/power supply. Switch fan on at t-stat to verify control voltage. Program
t-stat and restore operation.
Please also check low voltage connections
for tightness (power off).
Aug 06, 2009 | Heating & Cooling
I have amanual honey well and I want to change it to a programable honeywell but the two wires on the manual thermostat are not labeled, so I don't know where to connect the wires to in the new thermostat
Wires for thermostat control circuits are normally color coded. Check for proper connections at the furnace and connect the same colored wires that you find at the furnace to the like lettered terminals on the new thermostat. R to R, W to W , Y to Y , ans G to G. R is for power to the thermostat, W is for heating, Y is for cooling and G is for furnace fan operation.
Nov 14, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
383 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
