Question about Akai CF2791 27" TV
Akai CT 21W9S
This is 7 years old. It switches off frequently and I will have to remove power and switch it on after 30 minutes. Sometimes it runs only for 30 minutes. I don't know what to do
  • 1,694 Answers
PVAT! Pull chassis,solder any/all bad connects. Look for any slightly over-heated areas on PCB. Check caps.Pay attention to horiz drive,ps,etc. Let me know.
Posted on Oct 05, 2007
Honeywell programmable thermostat - was installed per instructions in manual and now the furnace runs non-stop unless I move switch to "off." The old (round mercury switch) thermostat was wired red t
If you are unsure about which wire goes where, that may be the source of your problem. The color coding can be confusing when changing from old to new. I pulled the instructions for my Honeywell CT3400A thermostat and found you can call Honeywell Consumer Services at 1-800-468-1502 M-F 7:30 am to 5 pm CT
Mar 11, 2013 | Heating & Cooling
Air Conditioner
Someone will need to find out if the compressor clutch is failing, or if it is loosing power due to a pressure switch or other problem.
A faulty relay or switch could get hot and switch off power to the compressor.
Aug 03, 2012 | 2006 Nissan Altima
My BenQ FP71G powers on and off, repeatedly, by itself no matter whether connected to computer or not. Everything else is fine. Sometimes it stays on for a minute or so, but usually for just a few...
my BenQ FP71G 17 in goes on after hundreds of times pushing on off switch and when it's on it does not go off, I have checked the on/off switch which is working oke and when the moniter is on the auto adjust message (brightness and contrast)pops up frequently and the screen adjusts itself.
Oct 12, 2010 | BenQ FP71G 17" LCD Monitor
1999 Olds ignition switch problems
In your Intrigue to use the New Passcode sensor .
You need to program the new Passcode to the ECM. of the Vehicle.
This is a prosses that involve around 30 minutes maybe a little more.
Remove the old Ignition switch.
Install the new Ignition switch. with the new Passlock sensor.
Turn the key to on position and try to start a few senconds. them leave the key on run position.
For 10 minutes and NOT more than 11 minutes.
Them turn the key to OFF position for exactly 30 seconds.
Them turn the key to Run position 10 minutes or 11.
them turn back the key to OFF position for 30 seconds.
Them turn the key to Run position 10 minutes or 11,
Turn the key to OFF position and wait 1 minute, them try to start the vehicle.
If the car start you are DONE.
But if Not Letme know to give you more information.
OK I hope this help to try solve your problem.
Thank you for use fixya...
Nov 15, 2008 | 1998 Oldsmobile Intrigue
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
Panasonic CT-32G6E Intermittent single horizontal line
I would suggest to locate a part that looks like the one on this link and re solder all the pins, also check for any high power resistor nearby the IC295890 and put some fresh solder.
Let me know if you need further assistance.
Aug 07, 2008 | Panasonic CT-32G6 32" TV
Probable bad tuner or tuner circuit issue, repair or bypass.....
If you can direct signal to A / V inputs as you are doing with your
DVD, then no repair is necessary.....utilyze cable box or VCR
tuner to change channels.......................T.
Dec 03, 2007 | Televison & Video
Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Nov 04, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Dell E173FP - After sometime the screen switches off
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Aug 06, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Akai CF2791 27" TV Logo
109 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
