Asus Pc power supply
Hi there. I have an ASus desktop (which runs my cctv network).
This died about 2 weeks ago and it seemed that the power supply unit was the problem. It was a standard n Asus 4s-435 which is a 350w unit i believe.
As it was a 'hurry job' I purchased a stanard 650w power unit the same size and installed it assuming 650w was plenty spare and would not cause any problems.
However the PC now boots up for about a minute , showing the screen and then shuts down again continually.
Am i being stupid? is this because of the oversized power unit 650 vs 350w, or something else?
any help appreciated.
toby
  • 5 more comments
  • tobes
    tobes Jan 07, 2009
    hi there, sorry i'm a bit new to this.
    Nope, no death screen, boot up screen started as normal except it was offering to start in safe mode and then it started to open X start screen and then machine died .
    it does this continually as i get no more than 1minute max of power as it is booting up. I'm assuming power supply is not at fault (!) as it is brand new.
    tob
  • tobes
    tobes Jan 07, 2009
    tob
  • tobes
    tobes Jan 07, 2009
    oops, this to wraiith303, I thinnk i send a reply to the wrong space.
    I'll try that out, as i had cleaned/dusted the inside and the CPU fan when installing this new power supply. Does it heat up that quick?
    Also , just to clarify , it does not try to reboot on it's own, but i have to physically press the 'on' button again.
    tob
  • tobes
    tobes Jan 07, 2009
    Er hi again..rats nope. no access to PSU tester unless i go back the shop..
    I presume if i had it completely out of the machine and not connected to anything, and then plugged in the power cable and switched on it, if it is ok it should just start up the fan and hum away quite happiliy ?? or am i being naive ?
    Eg it will demonstrate it is working fine as a stand alone unit. Hence the problem is likely to be either the CPU cooling fan as per your point or some weird wrong wiring issue (eg me?)
  • tobes
    tobes Jan 08, 2009
    Aloha Wraiith303 you star,
    Well some progress.., as you suggested I removed the heatsink CPU fan and cleaned it again. As i had no thermal paste with me i just refastened it very carefully and securely to the CPU and tried pressing the 'on' button.
    It booted up ok and went on working through WIN XP start and even showed me some of the CCTV app working.. Then.. it stopped dead again and turned off...sob..
    I have to wait about 3 minutes before the on/off button does anything, then it does the same thing after 3-4 minutes running.
    i'd hazard a guess this is an overheating problem, as you indicated, probably on the CPU. Will a generous application of thermal paste fix this? I've not used this stuff before and is there anything else i should look for?
    thanks again
    tob .
  • tobes
    tobes Jan 08, 2009
    Ahem , well i burnt my finger touching the CPU immediately after i removed the fan, so now i've learnt. ouch ouch ouch...take it to a shop..now? ?never. i'll get some paste and try it again..'If at first you don't succeed, ..keep going til you wreck it' as my now dead dad used to say (. he was a bomb disposal expert..lol.)
    Anyway thanks again. if you are ever in London lemme know.
    tob
  • Curtis Tuendemann May 11, 2010
    Are you receiving a "Blue Screen of Death"?
  • 39 Answers
Sounds like heating problems. what i'd recommend is to go buy some thermal paste, remove your heatsink/cpu fan. wipe the bottom of the heatsink clean with a cloth, and do the sam with the top of the cpu. now apply the thermal paste (about 3mm cubic or whatever the packaging says) to the centre of the cpu, and secure the heatsink/fan onto the cpu. make sure your heatsink is on your cpu SECURELY. In my experience a pc that boots up, works a while then reboots out of it's own is having heat problems. especially if the pc wont boot/reboots quickly after the initial reboot.
Posted on Jan 07, 2009
  • Beeuwen Gerryts
    Beeuwen Gerryts Jan 07, 2009
    So it shuts down instead of rebooting? In that case it can still be heat, depending on the motherboard type and the safety measures in place. Otherwise it COULD be a faulty PSU. Its rare, but the do sometimes arrive faulty out of he box. Do you have access to a PSU tester? or a PC repair shop who is willing to test it for you?
  • Beeuwen Gerryts
    Beeuwen Gerryts Jan 08, 2009
    WOAH! You ran he CPU without thermal paste?! That was very brave... lol.
    Yeah, i believe thermal paste ought to solve your problem. They go for about R57 retail here, so i guess... roughly $5 for a tube. Also, you'd only be using very little of it. It might be cheaper to take into a shop and let them do it... Up to you! :)
    As for the power supply, no if you just plug it in, it won't start up. Also, even if it starts up you know that the damage isn't severe, but it could still be damaged. As for the wiring issue, i doubt you are at fault. It's rather difficult to wire a pc wrong (from the PSU atleast)
ASUS K54C won't power from battery
Take it back to shop if it's only 2 weeks old
May 06, 2017 | ASUS Computers & Internet
Asus CM5570 Powers on 20sec/off 5sec/on to stay, no video or POST
i think that there is a problem with SMPS ( power supply) try barrow the SMPS from any one for few hrs. it will resolve the issue.
May 13, 2010 | ASUS Essentio Desktop with Intel Core 2...
I can not start my PC. It does have a green
Sounds like a defective power supply. Improper power coming from the supply will cause a unit to fail boot. Power supplies are about 40 bucks.
Oct 01, 2009 | HP Pavilion Media Center a1330n - AMD...
Very slow and intermittent wireless internet connection
I seem to have solved the problem by downloading the driver from Asus directly.
http://support.asus.com/download/download.aspx?SLanguage=en-us
I pulled out my Asus card, looked up the card model and downloaded the correct driver. Looks like the windows update or the Dell update must have caused the driver to get whacked. Hope this fixes your issue as well.
Apr 02, 2009 | ASUS 802.11G WIFI-G 54MBPS WIRELESS LAN...
ASUS Eee PC 4G PC Notebook will not turn on, when i try to turn the pc on the light flash and nothing comes on just BLANK screen. Can you please explain the problem on what caused it. I would really...
not really a solution but I found this on the asus website
Diagnostics:
1. Power On by Battery only? (Y = 2, N = 4)
2. Able to see BIOS (ASUS Logo)? (Y = 3, N = A)
3. Able to load the OS? (Y = B, N = A)
4. Adapter power LED on? (Y = 5, N = C)
5. Power On by Adapter only? (Y = 6, N = A)
6. Able to see BIOS (ASUS Logo)? (Y = 7, N = A)
7. Able to load O/S? (Y = D, N = A)
Symptom & Solutions:
A = Problem may be caused by defective MB/HDD/NB. Please visit local service centre for repair.
B = Problem may be caused by OS, please re-install the system again.
C = Adapter Problem. Please check the power cord connection. Otherwise, visit the local service centre for replacement.
D = Battery problem. Please check the connectivity of the battery. Otherwise, please visit local service centre for repair.
Mar 26, 2009 | Computers & Internet
Asus p5p800 motherboard
seem power supply fault, because some times, it looks that power going on, it is not giving proper voltage to motherboard. check other power supply.
Oct 16, 2008 | ASUS P5P800-VM Motherboard
Asus a8v-vm se fans always run
Hi jderek4, try this. locate the toggle switch on the back of the power supply. Just find it do not flip it.
Plug the PSU's power cord into the PC. Just as you got a good connection & the PC begains to power up move the toggle switch to it's other position. The PC should power off that very second.
If the PC does not shut off than the PSU is bad. If it did shut down wait a few seconds. Press the cases power on button. The PC should start to boot up. Let it finish loading. Click the start button & choose to shut down windows. The PC should shut off.
Yes? If not than your back to (bad power supply). Swap it out.
Mike
Mar 29, 2008 | ASUS A8V-VM Motherboard
Open Questions:
Secure Your Data With Our Online Backup Services ' DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
May 25, 2018 | Quantum Computers & Internet
Computers & Internet Logo
139 people viewed this question
David Payne
David Payne
