Question about iRobot Roomba 4210 Bagless Robotic Vacuum
Battery light goes red after bumping/backing up
This just started. After running just fine, and running completely out of battery "juice", I recharged the battery and set the Roomba down in another room. I started it up, it ran to a wall, bumped and immediately the battery light went red. When I put it back in the charger, it went green in less than 1 minute. I ran it again and it bumped into something, backed up and went red. I took out the battery pack, cleaned the contacts and some dust/lint, popped it back in and the light went green. Restarted and the same result. Any ideas?
  • 5 more comments
  • lynnagriff Sep 01, 2008
    Mine runs in circles backwards after running for just a few seconds normal.
  • matthew21076 Sep 21, 2008
    Same thing here. This vac is 3 years old, has had the firmware upgrade. I've cleaned EVERYTHING on it, and ran the 21 diagonostics, which found only the left tachometer to be in fault mode. But the new firmware is (supposedly) designe to ignore the tachometer reads on this model. In the diagnostic mode, ALL other features work perfectly, backing, RT, LT, brushes, vac, etc. But in normal cleaning mode (SPOT, CLEAN, or MAX) the machine moves about 2 inches, stops and shows a RED power light and orange status. HELP!
  • Anonymous Oct 12, 2008
    I have the same problem. I'm hesitant to throw money at a new battery when I'm not completely sure that is the problem.
  • asknursetiff Oct 23, 2008
    Same problem here. I was going to order a new battery because I read somewhere else that there is a problem with Roomba brand batteries in how they are wired, and after charging and recharging over a year it dies. BUT, I don't want to spend the money unless I know that is the problem...
  • CaseyMarie Oct 27, 2008
    I have the same problem. I discharged the battery fully, then recharged, but when I turn it on it immediately turns red and stops. Is it the battery?
  • Anonymous Nov 22, 2008
    Same problem. Charge. Light Green. Turn it on. Press Clean. Runs several seconds backward and then immediately shuts off, giving the low battery sound.
  • ghyatt7 Feb 11, 2009
    iRobot Roomba 4210 Bagless Robotic Vacuum went under sofa after only 15 minutes and gave a status alarm and power light went red. My machine came with no manual. It's brand new. Guess I'll have to return it for one with paperwork. Can tell it has been used.
  • 883 Answers
Try this: turn it upside down and run it-then bump it to reverse it...same result?
Posted on May 29, 2007
Are those new wireless stick vacuums worth buying? I love the idea but, it seems power must be limited or weak without enough suction.
I retired from fixing battery powered cleaning equipment a few years ago. The problem with wireless is that the batteries don't hold up. They will work fine for a few weeks- then they start to run out of juice after only a few min. On most rechargeables if you don't run them down completely, they only charge to the point you last put it on the charger (It's called battery memory). I personally think the rechargeables are a waist of money, and, when the batteries start to go- are frustrating. Just get an upright, with a side hose. I've got two at home that are over 20 years old. I only had to change the beater bar brush and belt twice in that time. No more than $150 bucks should be your price point for a vacuum used at your own home.
Apr 27, 2017 | Vacuums
Rechargeable vacuum cleaner, 2years old, battery will not charge, when in place for charging the middle light shows red for a while then goes out, filters cleaned all in place, any suggestions please?
When the batteries fail they typically do not accept and hold a charge which is the problem you now have.
If you can purchase a replacement battery, and as long as the batteries are replaceable in the appliance (some are not), you can run the cleaner again..
Dec 02, 2015 | Vacuums
Brand new first charge The green light on the charger plug goes off after a short time. Is the unit still charging?
Once the green light goes off, it's done charging. Since it was first charge I know they say to charge it 8? hours (or 4? don't recall right offhand) but it does come charged (that's part of how they make the batteries). What you do want to do is remember not to always recharge it when your done using it. Use it till the battery goes flat, then recharge it; it will give you a longer battery life that way.
Jan 09, 2015 | Dyson DC34 Bagless Cordless Hand Vac -...
New Roomba Battery Not Holding Charge - charged once then died
It is possible for the charging system inside the roomba to call it quits. What I did to remedy this, since my roomba was out of warranty and I did not want to scrap it, was to buy a charging base on ebay. This charging base accepts different types of roomba batteries and even the scooba battery. The inconvenience is if you have a newer model roomba that has the battery inside, then you will need to remove the screws on the bottom plate to remove the battery. Hope this helps.
new-roomba-battery-not-holding-charge#solution-section-qgwpio3es2ee0iuiltq5rfxr-1-0.jpg
Jan 23, 2014 | Roomba Robotic Floor Bagless Vacuum
Hi, my Dyson DC16 works fine but after removing from charge base following recharge the red and green lights remain lit and the unit will not operate until i remove the battery and reconnect to vacuum,this...
If it is within the warranty period get Dyson to replace it. If not, live with it until it fails completely, then buy a Hoover. Your computer board is starting to fail. That's not repairable.
Aug 06, 2017 | Dyson DC16 Root 6 Bagless Handheld...
UNIT WILL ONLY RUN FOR FEW SECONDS THEN THE BOTTOM OF THE 3 LIGHTS WILL FLASH
I'm sorry to hear you're having difficulties with your DC16. A single flashing red light indicates that the battery needs to be recharged. When fully charged, all 3 LEDs should illuminate without flashing. However, if the red light continues to flash even after at least 3 hours recharging time, there may be a fault with the battery or charger assembly.
Please get in touch with us directly - one of our experts will be happy to run through some troubleshooting over the phone with you to determine whether the battery or the charger requires replacement. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Jul 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
My dc 16 rechargeable vacuum won't work
far as i know the dyson dc 16 root 6 vacuum uses a lithium ion battery with a charge of 21.6 volts. it could be that either your battery isnt storing the right amount of power anymore and you may need to replace it. check on the specifications to confirm how much volts the battery is supposed to have. too little volts may be enough for things like lights to switch on, but not enough for the motor to start up.
Oct 27, 2009 | Vacuums
Backs up spins in circles, then red light flashes and beeps
Sounds like either the battery is bad or not being charged properly with subsequent loss of programming.
Jul 23, 2009 | iRobot Roomba 500 Series Virtual Wall...
iRobot Roomba 4210 Bagless Robotic Vacuum Logo
309 people viewed this question
Top iRobot Vacuums Experts
Oliver Street
Level 1 Expert
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
