Question about Panasonic KX-T7630 Corded Phone
How do i redirect calls to another extension?
I have moved my base and calls coming to my phone wont get picked up as it is in a single office and does not ring out anywhere else.i want to divert all my calls to an occupied office extension so that calls can be answered and messages passed on
  • Panasonic Master
  • 2,460 Answers
I missed your mentioning voice mail, so I guess that means you don't have it.
On your phone you have a FWD/DND button. It's programmed by dialing forwarding codes into the intercom, then the button is used to turn the featores on and off.
The code is *710x destination and maybe # where x=2 for all calls, 3 of busy, 4 for no answer and 5 for busy/no answer. When it's set, the light should be on solid. Pressing the button will make it go out and cancel FWD. You can set different forward destinations for busy and no answer.
You can also have different locations for intercom or outside calls. Those codes are in the TDA Users's manual.
Carl
Posted on Jan 10, 2009
When someone in office calls my phone the intercom picks up instead of ringing. How do I turn that off? we use the NEC 80 version 2.25
The phone people in the office should be able to turn off call forwarding and auto answer
Call Forwarding
Call Forwarding - NECDSX.com
www.necdsx.com/dita/features/call_forwarding/call_forwarding_feature.html
  1. Cached
  2. Similar
Call Forwarding permits an extension user to redirect their call to another ... in the Call Forwarding programming mode - the same as pressing INTERCOM and ...
Jul 29, 2016 | NEC Lands Phones
I am wondering how to forward incoming calls to a cell phone number if the person they are calling for is out of the office?
You can use Google Voice to automatically forward calls based on a variety of rules. For example, you can have a call to your GV number automatically forward to both the office and cell phone numbers, or you can have the call forwarded to either of those depending on time of day or based on who is calling. Additionally, when the person leaves the office, he/she can quickly change a setting in GV to change the redirect. So, for example, right before leaving the office he/she can set GV to forward to the cell phone; then when he/she returns, GV can be configured to direct calls back to the office number.
Try it at http://voice.google.com. Note that while the entire feature set is available in the US, some or all features may not be available in other countries.
Mar 07, 2011 | Office Equipment & Supplies
Redirect to another office using norstar telephone
Leave the handset down.
Dial "Feature 4" and the extension number of the phone to receive the calls.
To cancel, dial "Feature # 4" on the forwarded phone.
That's it!
Mar 11, 2010 | NorStar M7310 Phone
I have three questions regarding the Avaya One-X Quick Connect G11 PSTN Gateway. 1. Can it be programmed to ring all phones and if noone answers then go to extension 200 voicemail? 2. Can you get rid of...
1. Can it be programmed to ring2.gif all phones and if noone answers then go to extension 200 voicemail?
Yes, you need to browse to the gateways IP and look at the destination of the lines. If a single extension is the destination, you need to make a group, put all the phones in it, and then point the lines to that group.
2. Can you get rid of the dial 9 to get an outside line and just grab available line when handset is picked up?
No, unfortunately you can not.
3.How do you eliminate noise and echo in the background when on a call?Also has some bleeding over, someone else in the office could hear meon the phone when they were on the phone.
Make sure the gateway is grounded to a good ground. if the problem persists, you can try to upgrade the gateway and phones.
Oct 09, 2009 | Avaya ONE-X QUICK OFFICE EDITION TRUNK...
Nortel M7310 Phone moved to another jack, now no incoming calls
you need to go to your previous location and get the jack number, than go to the new location and get the jack number. now go to the phone system closet and look for these cable numbers on the 66 blocks. Swap the cross connect of the jacks and wallah your phone will be your s again! ldtnsj.com
Jan 20, 2009 | NorStar M7310 Corded Phone
Problem with extension and voicemail
1. Can be done but you have to have installer access to the system. You could also move the extensions at the phone system.
2. Is his call forwarding set (720x 165 #)? 720 sets forwarding for both intercom and outside calls.
Jan 13, 2009 | Panasonic KX-T7431 Corded Phone
I want to pick up incoming calls from another extension
Yours may be different if your TA-308 is not a U.S. version, but the family is generally 40 picks up all calls in your group and 4+the ringing extension will pick it up. Just in case they have call pickup deny set (721) you'd have to cancel it with 720.
Carl
Nov 18, 2008 | Panasonic KX-TA308 Phone
Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
Aug 08, 2008 | Panasonic KX-T7630 Corded Phone
Reset Norstar M7310 System Administration password
This works, i just did it today!!
Press Feature 985
Press the 9 Key
Enter RESETSMPSWD (73738767793) using the dialpad
Press YES
Once you have RESET the password, it reverts to the default.
See Below
If your system uses 2 digit extensions use 120000
If your system uses 3 digit extensions use 1020000
If your system uses 4 digit extensions use 10020000
May 05, 2008 | NorStar M7310 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
315 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
