Question about JVC GR-DVX400 Mini DV Digital Camcorder
Error displayed I am unable to load a new Mini DV into the camcorder. The camcorder displays 'Condensation. Operation Aborted'. I am unable to close the Mini DV assembly even without a Mini DV put inside. Can you please guide or help? R Deena +91-9900236504
  • 883 Answers
Look for a small pinhole and insert a pin to reset the device. if no success, then slowly heat the device with a hair dyer.
Posted on May 29, 2007
I have a JVC GR-DX97EK digital Mini DV camcorder.I'm getting a error message that says "Please Wait,Condensation Operation Paused".Can someone help with this problem?Possibly how to disconnect...
Condensation Alert is normal behaviour if you have taken the camera, for example, from a warm heated room to an outside cold environment. This is to prevent damage to tape or camera.
Wait until the camera acclimatizes (no moisture in the camera) to the new conditions and try again.
If the above is not the problem, take the camea to an Authorised Dealer for diagnosis.
Al
Feb 07, 2011 | JVC GR-DX97 Mini DV Digital Camcorder
My camera wont work and is displaying; please wait,condensation,operation paused
put it in the sun for a few hours then re try it / let me know how you went
Oct 14, 2010 | JVC GR-D31EK Mini DV Digital Camcorder
Condensation, operation paused
you can try gently drying it with a hairdryer not too close or too hot but try to get the moisture out that is causing your problem. this could have been caused by coming in from the cold to a warmer room. this should fix it.
May 07, 2010 | JVC Cybercam GR-D90 Mini DV Digital...
Lcd screen reads
Either the dew sensor is defective or there is some condensation inside the unit. Try opening up the unit and pointing a hair dryer at it from about 12" away (enough to blow warm air inside the unit, not hot air). Let that run for about 10-15 minutes and try the unit again. If it continues to fail, than the dew sensor needs to be replaced. This repair shoold be done by a repair shop as cameras are not the easiest to work on.
Dan
Nov 13, 2009 | JVC GR-D350 Mini DV Digital Camcorder
Try running a cleaning tape through the JVC 2 or 3 times and also wiping all around the tape compartment with a long cotton bud soaked with isopropyl alcohol. It cured my problem in Singapore.
Oct 30, 2009 | JVC GR-DX97 Mini DV Digital Camcorder
I have a Digital JVC Camcorder with mini DV with failure code...
That come on because of a humid condition or moisture on the head drum of the camcorder. This is usually cause by going fro a hot enviroment to a cold enviroment. This prevents tape damage or destruction as the tape will stick to the head as it spins. You can open the cassette compartment and use a hair dryer on a low setting for a couple of minutes to get rid of the moisture or just leav the cassette door open for about an hour or until the warning clears.
Aug 19, 2009 | JVC GR-D50 Mini DV Digital Camcorder
Help
yes had this on a few JVC it may be that the moisture has corrosded the dew sensor and will need service. When you store it use those crystals that come in packing of some items They are excellent for preventing this in Video cameras
Please rate our help to keep the service online
Aug 17, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Condensation operation of camcorder paused
Condensation problem is a common on newer camcorders. It is the sensor on the board that detects the condition of humidy. If you have not wet the camera or stored it in the humid area, the sensor or components around sensor is faulty. You can try to dry any humidity using hair dryer at medium setting in about 6 inches away for less than 5 minutes toward inside of tape loading area (make sure loading mech is at opened position). If this does not work, take it to recommended local camcorder repair facility for a diagnostics. Good Luck. CRJ
Feb 28, 2009 | JVC Cybercam GR-D93 Mini DV Digital...
Condensation, operation paused, JVC Video Camera model GR-D70AS
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Apr 27, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Open Questions:
JVC GR-DVX400 Mini DV Digital Camcorder Logo
83 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
