I need Windows 98SE Driver to use my Flash Drive for 1 GB blue color transcend.
    Genius:
  • 1,061 Answers
DOWNLOAD THE DRIVER FROM MICROSOFT . COM RICHARDM69
Posted on Mar 10, 2009
Hello, I'm trying to track down a USB driver for a Freecom FHD-1 external drive to run under Windows 98se (for the moment). Have checked freecom.com for drivers but am a bit dizzy after...
http://support.microsoft.com/kb/263218
Some info on 98se and USB issues. You should not need a usb driver if the usb port in your computer is already functioning properly. The only inconvenience you will have is your drive will work at the slower speed provided by the usb 1.1 standard.
The link below describes step by step installation of your drive in 98se
http://www.viking-direct.co.uk/speciallinks/gb/vkg/source/FHD1.pdf
Apr 05, 2011 | EliteGroup P4VMM2 Motherboard
Driver Transcend v85 for Windows 98SE
http://ec.transcendusa.com/product/ItemDetail.asp?ItemID=TS4GJFV85
or try http://www.softpedia.com/
Thanks Alot,
Sanjeev Kumar,
Cell.No.+919876388918
Feb 01, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pendrive Shows Write Protected
These are the tech specifications of your pen drive which includes write protection micro S/D switch. So search it and make it read and write
USB 1.1 compliant and 2.0 compatible,
True Plug and Play for hot swap function
Maximum Transfer speed of 1.5MB (12M bit) per second at full speed
Powered directly via the USB port.
No external power or battery needed.
Operating Systems Supported: No driver required for Windows Me/2000/XP, Mac OS 9.0 or later, or Linux kernel 2.4 or later.Only Windows 98SE needs the provided drive
Write-Protect Function: Write-protect switch Security Function: Password protection available via supplied software (Windows environment only) Boot-Up
Function: Makes JetFlash a MS-DOS Boot Disk LED: Flashing LED indicates
Data Traffic Specifications : Size: 75mm X 11mm X 25mm (L x W x H)
Weight: 15g Data Retention: Up to 10 years Shock Resistance: 1000G (maximum) Erase Cycles: 1,000,000 times Speed: Read 9.0 Mbyte/s, Write 8.0 Mbyte/s (Max.) Certificate: FCC, CE,
BSMI System Requirements: Win 98/98SE/ME/2000/XP, Linux Kernel 2.4 and above, Mac OS 8.6 or later
Aug 12, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
I want driver for win 98se for pen drive transcend jf v 30 / gb
go to micosoft.com you shoud be abol to find it in the prodocs tab
May 02, 2009 | Microsoft Windows 98 for PC
Is there a driver to allow sony micro vault 2.0gb on win 98?
Specs say it is compatible with Windows 98 SE. Also says no drivers are needed for it. Make sure your plug 'n play is enabled on your computer. Once it is enabled just plug the drive in & Win 98SE should install it. If it does not work then try a different usb port as maybe a port is bad. Hope this helps.
Jan 26, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
My Pen drive is 1 Gb Transcend,When i format it show 4 Gb & Error
its probably a virus trying formating on windows 98 or on linux based system may work for u also check when the pen drive isnt connected properly or the usb port or connection is loose it may say a read only pen drive due to slow speed connection of pen drive to computer
Jan 19, 2009 | Transcend (589307) Media
Windows 98 SE Driver for Transcend Jet Flash V60 8GB #TS8GJFV60
hi, i srinivas, i am using dual booting of win 98 & windows xp operating systems. when i am using my transcend pendrive in win xp which is easily working, but in win 98, how can we install perpect drivers for my transcend pendrive.
so please give the solution to solve my problem.
Jul 13, 2008 | Electronics - Others
Transcend jet flash
it might b due to problem in your  flash drive... anyway  go on www.transcend.uk      select ur device... then there will b a software ...u also can get firmware..
Jul 03, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Flash Drives
Try to use a new Computer having Windows Vista, Dual core, 2 Gb RAM, and at least 160 Gb Hardware.
Your problem is solved.
He! Ha Ha Haa Haaa!
Jan 25, 2008 | Electronics - Others
Computers & Internet Logo
206 people viewed this question
David Payne
David Payne
