All-in-one center not working
I have a lexmark x1270 and when I go to all in one center I get AIOC exe has stopped working,can you explain
  • dranoelst3 Apr 17, 2009
    Printer works but all other functions result in "AIOC not working..."
  • markbradshaw May 02, 2009
    installed lexmak x1270 series. tried to load the program and it read searching for application, then it reads aoic exe has stop working
  • 95 Answers
SOURCE: lexmark productivity suite won't work with vista
Follow the link below to download vista drivers for your lexmark printer:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=227:5:0:463:0:0&searchLang=en&os_group=Windows%20Vista&target
Posted on Mar 16, 2008
otacon
  • 1944 Answers
SOURCE: aioc.exe
You can download the setup here from Lexmark.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:0:0:0
Just pick your operating system.
Posted on Mar 30, 2008
  • 81 Answers
SOURCE: My Lexmark X1270 all in
it could be software problem. try to reinstall the driver including the utility software. make sure that you install it correctly with no errors.
Posted on Jun 21, 2008
  • 8 Answers
SOURCE: AIOC exe
What you need to change is your screen resolution to either 800 x 600 or to 1024 x 768 (in your desktop settings)
What is happening is that your Lexmark all-in-one center doesn't think your monitor can handle the program (or something to that effect).
You will NOT have to restart your computer either.
Just restart your Lexmark All-In-One program and you can start scanning.
Posted on Jan 07, 2009
  • 8 Answers
SOURCE: aioc.exe
I am trying to set up a home network, between my laptpo, which is running Vista, and my desktpo which is running Windows 7. when I install a driver, I keep getting AIOC.exe has stopped working. Can sombody...
I suggest you use the driver from the Lexmark website. You may need to uninstall the existing Lexmark X1270 driver first before installing the new one (instructions on how to uninstall the Lexmark software available at http://bit.ly/8ZH59T). Then, check if your Vista and Windows 7 are running on 32-bit or 64-bit operating system by going to the Start menu > right click on Computer > Properties. Download the compatible driver for your operating system:
Thank you for choosing Lexmark.
Oct 30, 2010 | Lexmark X1270 All-In-One InkJet Printer
MY LEXMARK X1100 CENTER DOES NOT OPEN.
Hi. The software may not be installed properly. Try running the software again using the installation cd that came with your printer. If you have tried it already. uninstall and reinstall the software to give your computer a fresh start. Also, check your firewall and allow all Lexmark communications to go through. Hope this helps.
Mar 14, 2010 | Lexmark X1270 All-In-One InkJet Printer
My lexmark3030 all in one will not scan. says
First step. Please make sure you are using one of the Vista drivers on the Lexmark website. www.lexmark.com.
Most often the problem is caused by using the driver for XP on a Vista system.
Don
Jun 24, 2009 | Lexmark X1270 All-In-One InkJet Printer
I just tried to scan with my Lexmark X1270 that worked fine the other day now it says AIOC exe has encountered a problem what has happened t change how it works
You need to update the driver for your printer. Using your install disc, just follow the normal install process which will work as an "Update Driver".
If you do not have your original disc, follow the steps below:
  1. Make sure you have the regular printer driver installed. If you don't, you can grab it from the Lexmark website and install it.
  2. Next, keep your USB cords plugged in but turn your printer off.
  3. Download the All-In-One Center Software here.
  4. Unpack the archive, open the "Applications" folder, and double-click Setup. This will install the application - it can take a bit.
  5. Once the application is installed, turn the printer on and try a test scan. If it works, you're good and can quit reading.
  6. If you get an error when running a test scan, don't panic. Reinstall the regular printer driver, using the "Update Driver" option that appears.
  7. Restart your computer.
  8. Do a new test scan. This should bring up the All In One Center's loading screen, which will start searching for programs (this can reallllly take a while). When it's done, everything will be working beautifully again!
Feb 22, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1240 all-in-one not working
Are you downloading the installation program of the printer from your manufactor of your Lexmark X1240 All-In-One Printer
Oct 29, 2008 | Lexmark X1240 All-In-One InkJet Printer
AIOC exe
Sep 26, 2008 | Lexmark X7350 All-In-One InkJet Printer
Aioc.exe
Aug 25, 2008 | Lexmark X7350 All-In-One Printer
Aioc.exe
This is what i did to fix the problem
>I went to Dir "C:\Program Files\Lexmark 1200 Series"
>I then found the file (aioc_app.ini) I cut this out and pasted it to my desktop.
>Then I opened up the lexmark all in one center program and there you go it was working.
> placed the .ini file back in the folder
Tried this twice and got the same results both times.
Mar 27, 2008 | Lexmark X1270 All-In-One InkJet Printer
Windows Vista Compatibility
Mar 16, 2008 | Lexmark X1240 All-In-One InkJet Printer
185 people viewed this question
jasbo
jasbo
