Question about Sony KP-61V90 61" Rear Projection Television
Where is a good place to search for a circuit board chips
Blew up a chip on a small 2.1ch speaker system from Japan, looking for a replacement chip for some one to fit. can part read the name and numbers on the burnt chip  Tai-1 T421DSE... El02HA Thank you
    Genius:
  • 1,139 Answers
The best way to do this is to get the schematic, lookup the part number and then get the OEM part from the manufacture.
Also you can look the part up at www.electronix.com or any of the other electronics part stores.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jan 15, 2009
I have 2 hs80m speakers, 1 speaker is quieter than the other. It seems like it is an amplification problem, but im not sure what part of the circuit board is causing the problem. I just turn 1 speaker up...
If one of the speakers..barely work ...it means that integrate circuit chip ..its faulty ..These kinda amplifiers..has one for each channel ..and the function is amplification ..when they fail ..it behave like you described....You should get a measurement tool and check the resistance for them ..if you are skilled a little ...and see which one is to blame ..They are usually not that expensive ..and they look like a rectangular spider..(at least 6 legs on each side..)
When you locate the one ..that seam to be the blame ..it is easy to change it using a soldering tool ...Just turn the board upside down ..remove the part ..and insert the other one ..without touching nearby parts or ..circuits...solder it in place with care ..
My advice is to get it to a professional ...and have the circuit replaced....cause these things are sensitive to mess with ..
Mean while ..if you want to use them ..try to get an adapter ..and use both speakers on the same channel in parallel ...It will be better than keeping one at max to compensate ..
Sep 01, 2011 | Yamaha HS80M Powered Monitors
53fdx20b
You can check this link for that convergence that your looking http://www.partstore.com/Search/Model/Hitachi+Ltd/Hitachi.aspx
after you replace thet convergence correctly its should be working fine already..
Good luck.........
Aug 10, 2008 | Hitachi 53FDX20B 53" Rear Projection...
I have a GE 27GT624. The picture is perfect but the sound went out. Both speakers work fine when hooked up to something else. The circuit board looks like a resister and an E-prom chip has tan burn marks...
The epprom chip is most likely the problem, the tuner shield will need to be resolded to the main circuit board because over time it developes hairline cracks causing the epprom to fail in a variety of ways. The chip needs to be replaced and programed along with tuner shield repair, I don't think there is a board option replacement.
Dec 20, 2010 | GE 25GT240 25" TV
SONY KP-65WS510 TV LOOKS LIKE TYPICAL CONVERSION CHIP PROBLEM. SCREEN HAS BOWTIE EFFECT AND CONVERGENCE IS ALL WACKED OUT. CHECKED ALL "D" BOARD FUSES AND REPLACED CONVERGENCE CHIPS. PROBLEM REMAINS THE...
there are fuses on each driver (6 in all) under the heatsinks usually.. make sure these are good. there are also 2 5amp fuses on the g board that supply power to the chips + and - 24volts.. check both of these.. i've seen some check good in circuit and still are bad, check voltage to see for sure. In a rare case, i knocked off a small surface mount resistor when unsoldering the chip, and then the convergence was muted.. make sure no small surface mount parts were moved on the bottom of the board when you soldered. good luck, let me know wif you need futher assistance.
Jun 19, 2010 | Televison & Video
Sound to right speaker goes in and out, mostly out after a few minutes. checked speaker wire connections. they are ok. switched speakers to no avail. Do I have a bad chip or circuit?
there could be a dry soldering joint on the Right Output of the audio chip inside the unit. As the audio chip heats up, it warms the board up aswell and this can warp it causing the sound to cut in and out.
May 24, 2010 | JVC MX-J50 CD Shelf System
I blew out an IC chip of my Monitor Audio ASW 110 Sub_woofer. The chip is in the U6 position it has 8 contacts. How do I figure out what chip to replace this with.
It is marked as U5 on my board but it is a BA4558 dual opamp. Can you take a look at your board and give me the color codes or resistance values for R35 and R36 please? Mine are fried. Thanks!
Oct 29, 2009 | Monitor Audio ASW-110 Subwoofer
Altec Lansing ADA995 does not work
This is my Dell Altec Lansing 5.1 (ADA995) surround sound amplifier for my computer. There is a design flaw where the board gets corroded due to the fact they caulked or glued it togther and left some of the circuit board hanging out. Just thought I would point out my findings in case some of you had the same system. It's a relatively easy fix. I got all the parts from Newark for about $30.00, and it took roughly 2 hours. Original Amplifier Chips below:
Positive Voltage Regulator is blown out:
Notice the traces where corrosion caused a short:
Another view of the burnt traces:
The glue or caulk ran straight across here:
This resistor was blown out.
I pulled it out before I took the picture I went ahead and replaced all of the 4.7 ohm 1/4 watt resistors:8_18_2012_3_31_59_am.jpg
Blown out 4.7ohm 1/4 watt resistor:8_18_2012_3_32_37_am.jpg
Just before surgery on the amp chips:
Re-jumpered the traces:8_18_2012_3_35_55_am.jpg
Re-jumpered the traces:8_18_2012_3_36_44_am.jpg
New amp chips are in! Boy that "Heat Sink Transfer Paste" is really messy!!!:8_18_2012_3_37_26_am.jpg
A peek at the underside:8_18_2012_3_38_11_am.jpg
New L7815CV Positive Voltage Regulator (Shown here):
New L7915CV Negative Voltage Regulator is on the back side:8_18_2012_3_39_35_am.jpg
New amp chips are all nestled down in their new home!:
Boy that's a big heat-sink:
Time to try it out. And it works. Boy, going a week with out 5.1 audio on your computer is terrible! Nobody should have to live that way or be subjected to that kind of torture. I guess this would be considered a "first world problem"!
-Jason-
Aug 20, 2008 | Altec Lansing ADA995 Speaker
No sound
take off bottom cover and see if the speaker wire came off.make sure its on cb and not on pa and make sure its plugged into the right port
Mar 03, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Output board for Altec Lansing ADA995
I had the same problem. One day I heard two pops and the speaker, including the power light, were dead. Neither Dell nor Altec Lansing support them. They're throw-aways, unless you know a genius electronics technician.
Dec 24, 2007 | Audio Players & Recorders
Sony KP-61V90 61" Rear Projection Television Logo
42 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
