Acer 4062LCi Laptop (I'm a Systems Engineer) Fails to boot! Was working earlier today. POST returns 8 flashes on the amber LED battery indicator. Have been doing Windows XP updates. Task Manager shows near to 100% CPU usage with no identifiable program that I can 'End Task' that reduces it. Prior to carking it, was getting these persistently on very slow shutdown: End Program - EXPLORER.EXE End Program - HiddenFaxWindow Also with: ProcMon v1.25 02-Oct-2007 - Process Monitor Usage This program reports high CPU usage with 80% DPC's (Deferred Procedure Calls). I have a feeling these problems have something to do with the battery or with some hardware that is sending massive amounts of IRQ's.
  • Danny Robinson
    Danny Robinson Jan 08, 2009
    Acer 4062LCi Laptop Fails to boot at all! Serious Alzheimers has set in.
    After depressing the Power button, POST returns 8 flashes on the amber LED battery indicator, then goes brain dead.
    I've found various Acer BIOS Post Error codes, but none that relate to the Amber LED battery indicator.
    No point in talking about HiJackThis, as it's not getting past POST.
  • Danny Robinson
    Danny Robinson Jan 10, 2009
    Problem Solved - Battery requires replacement:
    I had that feeling something was wrong with the battery, and I was right!
    Once or twice in the recent past, I removed the battery and attempted to turn the laptop on without the battery, but it wouldn't start, so never re-attempted to try again.
    Well, it got the better of me, so I removed the battery once more, and voila! the laptop sprung back to life, what's more, the high CPU Usage I was getting while the 'dud' battery was in, has now disappeared and everything seems mnormal, so it's off to purchase a replacement battery pack.
  • 111 Answers
As a systems engineer I daresay you did not use any hardware updates from the Microsoft Update page? If so roll back the drivers you downloaded
Alternatively if you identify processes that do not belong use the following program to terminate them
It is a straight-forward program called hijackthis it makes a log of the currently running processes and allows you to terminate ANY of them hence care is advised
I sincerely hope this helped
Posted on Jan 07, 2009
Hp probook 6455b will not turn on why?
Take everything out of it that you can. That would mean the ram and drives, see if it boots. IF it does, then put the ram back and check it again. If it does put the hard drive back etc. If you get to the point that it wont boot with nothing installed then it could be a dead cmos battery or a loose CPU or something like that or a bad mother board.
Apr 04, 2016 | HP Computers & Internet
Using Battery or AC power my Toshiba G30 gives a flashing amber DC IN LED and will not boot up
You have a trouble in the video chip of this main bord must to be reboulding to solution it ! post please
Feb 08, 2014 | Computers & Internet
My Dell 8200 Desktop just stopped working. It turns on but doesn't boot; nothing appears on the screen. I was told this is the motherboard. Does that sound right?
two things
  1. What does the power LED on the tower indicate? Solid Amber? Flashing Amber? Solid Green?
  2. On the back of the Tower are 4 diagnostic LEDs, what do they indicate? Normally they flash thru several sequences and stop ABCD all Green. If the stop in another pattern, post the pattern.
Feb 13, 2010 | Computers & Internet
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Amber light on front of laptop flashes even with the power off
The Battery indicator LED is to the right of the power LED. Flashing AMBER indicates a fault with the Battery. To resolve, replace the system battery.
Apr 13, 2009 | Dell Inspiron 2200 Notebook
Amber light on front of laptop flashes.
Acer Ferrari 3200 won't boot
Try different memory just to be sure its not that and if still no boot then its the motherboard.
Feb 10, 2009 | Dell Inspiron 2200 Notebook
Flashing amber light
Attempt to boot the laptop with the battery removed and the AC plugged in. IF this boots ok it may very well be the battery circuitry which has failed.
Nov 26, 2008 | Acer Aspire 5315 Notebook
Flashing battery power LED
Try this
1. Remove the battery and the AC adapter. Hold down power button for 5 seconds. then insert the AC adapter only and see if you can power up the laptop. if it does power up, dont use the Battery anymore as it might be the cause of the problem
Apr 06, 2008 | HP Compaq nc6220 Notebook
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
