Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
Refigerator wont cool or freeze
We left our refrigater door wide open for over 14 hours when we had to go out of town, now it wont freeze or make ice and the other side is not getting cold please help!!!!!!!!!!!!!!!
My Frigidaire Gallery side by side, occassionally leaks water from the bottom, it seems to happen when the ice gets too high...can you help......there doesnt seem to be a leak in the tubing.....whatelse could only sometime cause this???
Posted on Jun 28, 2008
  • 883 Answers
Unplug it for 30 minutes and try again...same problem? if yes, then recharge freon
Posted on May 29, 2007
Why no frost refrigerator ( LG,Express cool) suction line freezing ?
HI THERE.well its quite long winded and complicated but try this first.defrost the whole lot for 24 to 48 hours first.doors opened lots of heat (mind the water leak) then try.if ok it could because the door was left opened accidentally .good luck ALI
Aug 20, 2013 | Amana 22.6 cu. ft. Side-By-Side...
Refigerator not getting cold freezer seems to be freezing
Its defrost problem.---------- The unit is not defrosting on time.--------. First try manual defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. -------------
If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site.-------------
This will help.Thanks.Helpmech.
Jul 21, 2011 | Whirlpool Refrigerators
FREEZER FREEZERS BUT THE REFIGERATOR WONT GET COLD
Check the air return on the bottom left wall of the refrigerator side. Check for cold air flow at the top of the refrigerator when the compressor is running. If you feel no air flow, open the freezer door and see if you detect significantly more air flow after opening the freezer door. This could indicate a return air flow restriction and make sure that there no blocking of air vent at the top of refrigerator section that supplies the cold air from the freezer.Check the door seal gasket on the refrigerator for leaks.
If the vents and air flow paths in the refrigerator are proper, then check the back wall of the freezer for excessive frost. A defrost system problem could be preventing the refrigerator from cooling properly. If you do see excessive frost on the evaporator in the freezer, you may be able to restore proper cooling in the refrigerator by storing your food in an ice chest and then shutting off the refrigerator/freezer and letting the unit completely defrost for about 24 hours. Leave the doors open for air circulation. After the frost on the evaporator has defrosted, plug the unit back in and see if the refrigerator and freezer will cool properly.
If there is still same problem then you need to replace evaporator fan.
Hope this helps.
Shane
Mar 01, 2011 | Whirlpool Refrigerators
Freezer is cool but ice is melting. fridge is starting to warm up. we adjusted the temp controls but did not help.
Somewow the door was left slightly open. Do a total 12 hour defrost and once all ice has gone, restart. (Remember 12 hours.ice sits in the insulation and problem wont go if not properly defrosted.
Aug 23, 2010 | Whirlpool ED2FHSS Side by Side...
Refigerator is not cooling but the bottom freezer is working fan is running in frig are there 2 compressors? door was left open on the frig for several hours by a kid before problem started pls...
if the freezer is working fine - and the fan is running in the refrigerator I would give it a little time (24 hours) to catch up (from the door being left open).
hope this helps
Jun 14, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE refrig Model # GSS25WGMD WW freezer is cool, compressor is running, but food is thawing out, ice has melted...not sure if I left door open ovenight, should I call repair..show long does it take to...
I pulled the refrig out from the wall, turned it off, took off the back panel (that covers the compressor fan and motor) and used the attachment on my vacuum to remove the dust from the area. Then I closed the flapper that allows the ice to release from the ice maker compartment to the dispenser, so no warm air would get into the freezer area. I plugged the refrigerator back in and within an hour it was freezing again! So far this week, I have had to repair the garbage disposal and the refrigerator.....I saved some nice $$$ by figuring this out by myself!
Jun 25, 2009 | GE Refrigerators
Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
First, are you noticing any frost build up inside the rear freezer panel?
Are the fans and the compressor running?
Please let me know so I can assist you through this.
Vic
May 27, 2009 | Refrigerators
Left ge stainless steel fridge and freezer door open acciently
youll need to unplug and defrost all the ice from hte back panel, leave unplugged for a min of 24, hours, then plug back in you should be fine. way too much ice has built up behind hte inner panel ,cutting of all air flow to both compartments.you did no real harm( other then losing your food
Nov 28, 2008 | GE Refrigerators
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
175 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
