Question about HP Office Equipment & Supplies
Ink cartridge what is the number of the black ink cartridge i need for the hp psc2355 all-in one printer and scanner
    Scholar:
  • 82 Answers
For HP PSC 2355 Black Ink Cartridge Number is
C8765ZZ
HP 852 Black Inkjet Print Cartridge
Cost around : 1100 Rs.
C8766ZZ
HP 855 Tri-color Inkjet Print Cartridge Order HP 855 Tri-color
Cost
cost around Rs. 1300
I hope this resolves your query
Do rate the Solution, so we cna help others accordingly
Thank you in advance
Posted on Jan 07, 2009
    President:
  • 2,692 Answers
I get different ink cartridge numbers for my hp2575, which one will work?
HP 98 black cartridge, HP 95 Colored cartridge are the standard ink for Hp 2575.
press the helpful button
Jan 05, 2016 | HP Photosmart 2575 All-In-One Printer,...
What ink is used in an hp q1660a printer?
Here is the Information that you are looking for.
Ref Link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00691&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=90764#jumptocontent
Inkjet print cartridge part numbers
Inkjet print cartridges Part numberHP 56 Black Inkjet Print Cartridge C6656A HP 57 Tri-color Inkjet Print Cartridge C6657A HP 28 Tri-color Inkjet Print Cartridge C8728A
Feb 18, 2013 | HP Q1660A PSC 1210 All-In-One Printer...
Does not print dark enough to read. Changed toner and adjusted print darkness feature. Still does not work. Any idea what to do?
Hi
When printing, just adjust the PRINT QUALITY to PHOTO because I believe your print quality is set to TEXT. I am sure it will print move darker than before.
I hope it helps you solve your problem.
Regards
Feb 15, 2011 | HP LaserJet 3030 All-In-One Printer
HP 7310 black cartridge keep getting error
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
http://h30434.www3.hp.com/t5/Other-printing-questions/HP-K5300-not-printing-black/m-p/376191#M26084
Dec 01, 2010 | HP OfficeJet 7310 All-In-One InkJet...
My printer is printing but the black ink is very faint. I get a message ink system failure
Nov 29, 2010 | HP Photosmart D7560 InkJet Printer
I have a HP 7580 printer/fax/scanner which will not print in black even though i have installed a new black ink cartridge
I had this same problem, replaced all ink cartridges and problem still remained. The fix for this is actually to replace the print heads not the cartridges. There is a black/yellow and Magenta/Cyan print head in the printer itself under the scanner on the right hand side. Rpelace as needed.
Nov 02, 2009 | HP Office Equipment & Supplies
HP C7280 BLACK INK WON'T PRINT
That printer doesn't have printheads that get replaced with the cartridges. Here's a page on HP's site that describes what to do if one of your colors doesn't work. Give it a try and let me know how it works. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01078810&cc=us&lc=en&dlc=en&product=3204785
Jun 09, 2009 | HP Photosmart C7280 Printer
Photo ink cartridge
remove the black ink cartridge and insert the PHOTO cartrdige to the black ink slot and im pretty sure that it will perfectly work...
Aug 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP PSC 2355 Won't accept refilled ink cartridges
If problem is what I think it is (that is if you cleaned whole thing and it is connected proprely), you have only one option. To buy at least three cartridges...problem is due a small trick made by HP. Printer remembers at least two cartridge serial numbers, and then wont accept refilled ones. But if you first stick one, then the other, and on the end the third one(only this one should be really full) it should reset printer and it should foul it to accept it. But on some printers it needs up to five cartridges! What a waste of money :( Anyway, hope this helps...
Aug 19, 2007 | HP PSC 2355 All-In-One InkJet Printer
103 people viewed this question
Ben Johnson
