Question about Black & Decker BR300 3''x18'' Belt Sander
Need belt for black and decker sander 110 xl 031
I cannot find a replacement belt what is up with that ---this is the rubber drive belt ---number 110 xl 031???"?
The belt from Jason 110XL031 is Identical in size and apperance.
Posted on May 12, 2011
    New Friend:
  • 12 Answers
I couldn't wait for the auction site, but I found pretty darn good ones for $2.50 each so I bought a bunch for spares. Shipping was very reasonable and I had them about 2 days. Hope this helps! http://store.beltpalace.com/110xl031.html
Posted on Dec 03, 2012
  • Chad Glover Jul 17, 2013
    thank you Bob James, worked great order some spares
    ty Bob James
  • Black & Decker Master
  • 1,840 Answers
  • 2,176 Answers
If your model number is BR300 the belt number is 429964-32 and lists for 5.59. I don't know what the type number is so I suggets that you go to Dewaltservicenet.com and type in the tool number and they will show you a selection of different type numbers. Click on it and is should be position #144 on the breakdown. Good luck and let me know if you need any more help.
Posted on Jan 07, 2009
  • danny Puckett May 09, 2011
    shows to discontinued, ace tool and repair appears to have some for 6.67.as of 5/11
    How bout that grammar! I just called ace repair they do not have one either, found one on eBay the actual Manufacture is Jason and their part is 110XL 031 same as on my belt. Not sure on direct shipping from manufactur but it will be 10.00 on ebayto my door.
HOW DO I REPLACE A TIMING BELT ON A 3" X 18" BELT SANDER
On the side of the sander there is a black triangle shaped cover with 3 screws holding it in place. Remove the screws and you will see the drive belt and 2 pullies or gears. The belt will be attached to the gears. Remove and replace the belt. Typically the belt is broken so the only thing you will need is to locate a new belt and slip in over the gears with the side with the teeth facing the gears. This keeps the belt from slipping. Reinstall the cover and you are ready to go back to work. The hardest part may be finding a supplier for the belt.
Aug 06, 2011 | Black & Decker BR300 3''x18'' Belt Sander
I have a Black and Decker Sander, model # 5.2 A and I cannot find a motor belt for it. The belt that broke has "made in China" stamped on it and the numbers 110XL 031 stamped on it.
You might try Dewalt. I have a Black & Decker weed eater that had a broken belt and I had to order it from Dewalt. I was told that they had some kind of merger. Ordered it and it worked just fine.
Mar 01, 2011 | Black & Decker BR300 3''x18'' Belt Sander
I have a Porter Cable Model 371 2.5" X 14" Belt Sander. I broke a belt, when I did it jammed and also broke a rubber sleeve that covers the Drive Wheel. I have yet to find this rubber sleeve in any part...
Unfortunatly that sleeve is not available, you will need to purchase a whole new drive wheel. The Drive wheel is $9.66 from DeWalt Service Net. Porter Cable, Delta & DeWalt are all owned by Stanley Black & Decker, you can contact DeWalt Factory Service for all parts. 1-800-4-DeWalt You can order the parts on-line, over the phone or though a local service center. The website is www.dewaltservicenet.com Below is the parts diagram for your sander. The part number for the drive wheel is A16439
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=65594&typeId=15450&documentId=34604
Oct 10, 2010 | Porter Cable 371K Factory Reconditioned...
Black & Decker DS321 - ripped the rubber off the drive roller. Now got it in pieces, all cleaned up, but I dont see how to remove the driver roller from the Drive Shaft and belt guide assembley.
looked at a schematic and the drive roller screws onto the drive shaft, I don't see where is a locknut on the outside but the shaft is threaded, it moght be left hand thread. If there are 2 holes in the gear see if you can find a spanner wrench from a grinder and secure the roller and loosen the gear.
Sep 12, 2010 | Black & Decker 3 x 21 In. Dragster Belt...
My black and Decker dragster has simply stopped turning on. i need to get it dissembled to check the switch
go to Dewaltservicenet.com with your model number and you can download a parts breakdown for the tool for disassembly.
Nov 16, 2009 | Black & Decker 3 x 21 In. Dragster Belt...
My DS321 belt sander had the large drive roller(and belt)came off on the first extended use. Looking at an IPB no thrust washers were found either.
I would recommend going to Dewaltservicenet.com and typing in your model number and on the next page find the type number for the tool. I took a guess and found 2 thrust washers for the DS321. Let me know if you need more assistance and I will try and help
Jul 20, 2009 | Black & Decker 3 x 21 In. Dragster Belt...
Broken drive belt on belt sander
My answer comes almost a year after the original question, but I'll post it anyway for those who end up here after a search.
Black & Decker no longer supplies drive belts for the BR400 sander, but you can get a replacement elsewhere if you know what to ask for.
The belt is a synchronous, single-sided "XL" series belt, and mine had 120XL031 printed on it. The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in.
I found a replacement at sdp-si.com, part number A 6R 3-060031.
Look here for timing belts (inch), then narrow the search for single-sided, .200 (XL) pitch, 60 grooves, 5/16 width.
Jul 15, 2009 | Black & Decker Tools & Hardware - Others
Broken drive belt
Take the broken belt to an industrial supply house or Ball Bearing supply house for a replacement.
Jul 10, 2009 | Black & Decker BR300 3''x18'' Belt Sander
Describe your Black & Decker BR318
This is a good sander but no portable belt sander is really a floor sander.
Jun 13, 2009 | Black & Decker BR318 3" x 18" Belt Sander
Black & Decker BR300 3''x18'' Belt Sander Logo
1,831 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
