Question about Car Audio & Video
My ford ka cd player only plays out of one speaker
My new cd player (actual ford ka player) has been fitted but it only plays the cd out of one speaker. the radio plays fine.
When I first got my Ka, the wiring between the car and the door was snapped. If you open the door there is a rubber tubing, if u assume 2 wires are snapped and try 2 pull them together through the rubber tubing you should hear a crackle if thats the fault. Even if you do not, it will almost certainly be this. To fix it, you need 2 use a stanley knife 2 cut open the rubber tubing then connect the to snapped wires together. I did this by getting a small amount of speaker cable and adding it 2 both ends, using plenty of insulation tape. This is the most common fault for speaker problems in the Ka.
Hope this Helps
Ashley
Posted on Feb 03, 2009
    Scholar:
  • 61 Answers
Some cd players allow you to have different settings between radio and cd..... Just make sure that the balance and fade is all set to the middle (usually done by pushing in the volume button, pls read your car manual)... If this doesnt work take the car to either ford or a car audio place......
Posted on Jan 07, 2009
Ford KA 1996 CD player displays "error 2"
take it to a ford dealer or replace it with a used unit -cheers Denny
Jun 04, 2013 | Vehicle Parts & Accessories
Ford ka roll top glove box
The small clips break on these Ford Ka roller glove boxes and the are only available from ford .
The old one can be taken out with a pliers.
The new part will simply slot into the small rectangulay hole and just clicks into place to fit.
Sometimes the get dislodged and stay attached to the small locking point on the lid.
Apr 07, 2013 | 2001 Ford Ka
My Dual Cd770 will not play any cd's. Whether it be burned cd's, or actual album cd's. It keeps saying error-02 every time i try to play any cd. I tried to read the manual, and it didnt help...
Try to get a CD player eye cleaner and demagnitiser if it is old and that doesnt work the eye is either scratched or the motor that moves it is burned out and its time for a new one.If it is new chances are its defective,return it.
Jul 17, 2011 | Car Audio & Video
Ford KA Right speaker broken
Hello jump_in_the_, You need to determine if the problem is in the speaker, the wiring or the CD player. It appears that you have already eliminated the CD player, so it must be the wiring or the speaker itself. Connect a known good speaker and see if it works. If it does, then the speaker is bad and needs replacement. If it doesn't, then the wiring is faulty. In that case, run a new wire directly from the CD player plug harness. Hope this helps.
Jun 05, 2009 | Car Audio & Video
I burned a cd and it wont play in the cd player i have a 2003 ford focus with a blapunk ford radio the cd is a rw
Most older factory car radios won't play a burned disc. You could try a cd(+ or -) r instead of a rw. But it probably won't work. Some cd players work better with a specific brand of disc too.
Specifications can be found at the radio manufacturers web site.
In 2003 mp3's and burning discs was new to car audio so the radio may not be compatable.
Sep 02, 2008 | Car Audio & Video
Speaker makes a popping sound when car starts
may be the antenna jack such is connected in cassete is n't good
Jul 08, 2007 | Panasonic CQ-C8803U CD Player
Car Audio & Video Logo
1,575 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
