Question about Home
Grey wire where does it go?
I have a bathroom towel rail with black brown and a grey wire I assumed grey = earth balck =neutral brown= live can you tel me is this right as at the momment I am trying to find out if it worksso temporarily using a plug and it is triping.
many thanks
    Novelist:
  • 152 Answers
Hello, try using a ac voltage meter to make sure of the polaritys some houses or apartment have wrong colored wiring, it is good to have a outlet tester it is inexpensive and it helps.
usually
white/grey is nuetral
black/red is live
brown ground
Posted on Jan 08, 2009
Belling cooker d841 top oven
The US National Electrical Code only mandates white (or grey) for the neutral power conductor and bare copper, green, or green with yellow stripes for the protective ground. Power will generally be black or red. 3 phase power will have three colored lines, the first is generally black or brown, the second red or orange, and the third blue or yellow..
i,e,
Yellow/Green is Earth so 'E'. Brown is live so 'L', and Blue is neutral so 'N'.
May 08, 2012 | Belling XOU174 Electric Single Oven
Wiring honeywell dt92e
Contact Honeywell and request the DT92E wiring diagram that should have been in the package.
Nov 18, 2017 | Heating & Cooling
My terim cooker has 3 wires - black, blue and brown. Do you know which is live, negative and earth?
green or green and yellow is the ground (earth), blue is neutral, black and brown are both lives. this is the standard european wire color code since 2004. If it is older than that, black was used as a neutral, and blue as a live. very confusing.
Jul 21, 2011 | Ovens
How do I know which wire on my new dryer cord goes to the red post on the terminal block and which one goes to the black?
Assuming you live in the U/K, then the new dryer cord should have brown which is live, that goes to red, blue which is neutral, that goes to black, and the remaining wire goes to earth.
Please rate my solution.
Thanks.
Nov 04, 2009 | Dryers
Wiring connections for a Danfos 25T65 thermostat
3 - Live
4 - Neutral
6 - Earth
With the knob pointing up. Earth it the top right. Live is bottom Right and Neutral if left.
Sep 02, 2009 | Refrigerators
Heath-zenith sl-6107 wiring diagram
hi there the wirings colour codes for nz are as follows
OLD WIRING CODE
Green = Earth
Black = Neutral
Red = Phase Or Live
NEW WIRING CODE
Green/Yellow = Earth
Blue = Neutral
Brown = Phase or Live
============DANGER 230VOLT ===============
Electricity can kill.
You should use an Electrical contractor for this repair job,
Caution always turn off power first before touching any wiring,
The Live wires always carry power,from one point to another,
the black neutral is your return path from the live phase wire
the green wire is always the ground ,
In this example
the sensor will have four wires as follows
Green = Earth Wire
Black = Neutral
Brown = Phase (incoming supply) 24 hrs
Red = Phase Load (outgoing supply) from sensor to lights triggered
Notice there are to phases in the circuit.Brown and Red
Always treat them as LIVE or Active Power.
Brown will normally be the Live incoming power and
Red will be the load side of the sensor,
Check the brochure supplied by manufactuers or their website to confirm the wiring order is correct before commencing any installs or repairs,
Always Safety first.
Safe a live today and you'll remembered forever.
Jul 06, 2009 | Heath Zenith Occupancy Motion Sensor Wall...
Wiring a cooker top
Thios induction hob (Electrolux) has 4 wires - Y/G, brown. blue and black.
The Y/G is obviously the Earth conductor, and I would assume normality says that
Brown is the live conductor and Blue the neutral conductor.
The quandry is whether or not to disconnect the black wire completely, as this appears to have no function in a domestic wiring circuit.
Regards, Albert.
Oct 27, 2007 | GE 30 in. JP326 Electric Cooktop
Home Logo
434 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
