Philips 50PF9630A 50 in. Plasma Television Logo
Robbie Carter Posted on May 29, 2007
No channels For some unforeseen reason one day we have lost all channels and i cant even pick any up manually?> now we have been quoted 1000 to fix that, but what would i be paying for that i cant do.....any help please??
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 29, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
595
Points
Have you gone through all the usual checks? Do you have it set on the right channel,usualy channel 3. Is the proper input set for where your signal is coming from, air,componet or cable? Have you tried to have the set do an automatic rescan and setting of the channels? Is the set connected to any other box such as a cable box,HD reciever or Tivo? Could any of these be causing this? Try just the set itself without any other box connected to it.Is there any kind of reset button to clear itself and settings. Sometimes they have to be "unplugged" for a minute or two to reset themselves,not just turned off and on.If nothing works call the manufacturer and ask them for help. Somewhere,probably in the back of your manual you'll find a 800 number you can call and ask for more help.There just might be a solution to this that they can tell you how to do.Hope you get it straightened out.
A
Anonymous
These things are much like computers. Turn it off and let it clear itself -- wait a minute or two -- and turn it on. It might reboot. Don't pay $1000. I saw a comprable 42 inch plasma on "Tiger Direct" yesterday for $699.
1helpful
Ive lost all channels on my lg m227wdp
Have you tried the rear audio/video inputs to see if a DVD etc works via them?
Hi. i cant change the time on my casio g-1000. the reason for this is i have lost my manual. can you help?
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
I have a pro-528triple trunking with 1000 channels.brand radioshack.serial no;74009508.fcc id07a07.can i fix my scanner to pick up scured channeles are modify it to pick up cell phone conversations i can...
Sorry, but the answers to your questions are no and no. Modern scanners are what they are, and they cannot be modified to monitor any secure (encrypted), digital, or cell phone communications. There is no magic fix to convert an analog scanner to digital. If you want to listen in to digital communications you'll need to purchase a digital-capable scanner, but that will still leave you without cell phone coverage or the ability to listen in to whatever secure transmissions you're referring to.
Bill B.
Listening in since the 60's
3helpful
Cant get time/date to adjust, pick up signal
Follow this link:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
Alpine CDA 9886 car stereo with sirius. The Artist and song title does not display even though Sirius signal DOES come in. On the other hand, the name of the channel does correctly display (i.e....
I read the manual and found out that the reason the track title information does not display is because you need to set the text scroll setting to manual.
Go to settings
Display
Text Scroll
set this to manual.
Should be fixed!
Netgear WPNT834 wireless not working
Hi Ashdan
channel 6 is very common with 2.4ghz wireless phones. Try changing the channel to a different one ie. 2 to -5 is rarely used so i suggest one of those. Also WEP is very insecure and easily hacked. If the only risk is people stealing your internet then i suggest you use MAC filter as the most secure way and turn off wep. This will make your router and internet surfing experience even faster.
good luck
smeags.
Cant get local channels
If you can manually tune to the channels with no problem, then I would go in and add then into memory manually. If not then exchange the set as it might have a bad tuner or an AGC (automatic gain control) issue.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
