Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Memory card not read
The camera even without memory card can be turned ON and the internal memory can be use, for only 2 pictures. But when a memory car new or old the camera just not turned on. Is there a problem in my camera?
Another nifty tip is try using a regular school eraser on the metal connectors on the memory card there could be a build up of film on it... same thing happened to me ... erasers wont hurt the memory card...(old gamer trick)
Posted on Aug 18, 2007
  • 883 Answers
Try inserting card after camera powered up...same result?
Posted on May 29, 2007
Will not accept memory Card
try a new one and if that doesn't work ask for your money back
Mar 21, 2014 | Kodak C195 Digital Camera
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
How do I copy pictures from the internal memory to the memory card?
Kerrisutton1,
Without knowing the exact Make and Moddel of the camera -- there are often 2 general routes pictures can be obtained from an internal memory.
1. With memory card in camera, go into your camera settings. 2. Within settings there should be a storage reader (which looks at your external card) and should be an additional option to copy files (note that most cameras have little internal memory as external cards are so cheap)
OR
1. Put camera in camera dock / charger with USB connection 2. connect camera with USB connection to computer 3. Go to Start -> My Computer -> [yourcamera] 4. Within your camera folder there will be a picture folder (different based on brands) that should house pictures that reside on internal memory.
Mar 13, 2011 | Cameras
It says that my "Memory Card is full" even though
1. Make sure you are saving all your images to what is called the "external" memory, not the tiny internal memory.
2. Format your memory card using the format feature on your camera.
Mar 08, 2011 | Panasonic Lumix DMC-FX12 Digital Camera
How do i transfer pic from the internal memory to the memory card
www.kodak.com/global/en/service
FOR MANUAL DOW[section title] Choosing Internal Memory or SD/MMCCard
The camera offers two options for storing pictures and videos:
Internal Memory —Store pictures and videos in 16 MB internal
memory.
SD/MMC Card —Store pictures and videos on a card. The number/length
of pictures/videos depends on the size of the card. Purchase accessories at
a
dealer of Kodak products or visit www.kodak.com/go/dx6490accessories. For
storage capacities, see page 114.
Managing Your Storage Location Setting (after inserting the card with power
OFF)
1 Turn on the camera.
2 In any still or video mode, press the Menu button.
3 Press to highlight Image Storage , then press the OK button.
4 Press to highlight an option, then press the OK button:
Auto (default)—the camera uses the card
if one is in the camera. If not, the camera
uses internal memory.
Internal Memory—the camera always
uses internal memory, even if a card is
installed.
5 Highlight Continue, then press the OK button again.
The setting remains until you change it and applies to all camera
functions.
6 Press the Menu button to exit the menu.
NLOAD.
Jul 09, 2009 | Kodak EasyShare C643 Digital Camera
Internal Memory is full??
If you dont put a memory card in your camera it is forced to record on and read from the internal memory (which is pretty small). If you do insert a memory card (is it a memory stick?) you can read the card but not the internal memory. Try it both with and without the memory stick.
Apr 29, 2009 | Cameras
Getting pictures off internal memory
1....put your SD card in the slot...
2...turn cam on and go to playback menu
3....go to MENU/OK option
4...scroll down to COPY select ok
5....Then choose option INTERNAL memory to card and hit ok
Mar 23, 2009 | Fuji FinePix Z10fd Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
How are images stored in the camera?
images are stored in either internal flash memory or optional removable, reusable CompactFlash cards. Providing both internal and removable storage offers users maximum storage flexibility. Internal camera memory ensures that the camera is always ready to capture pictures, even if the optional memory cards have been misplaced, lost or damaged. Optional storage cards enable users to expand storage capacity according to their usage needs. Since the pictures are stored in flash memory chips, pictures can be retained for up to one year without power.
Sep 13, 2005 | Epson PhotoPC 700 Digital Camera
Sep 13, 2005 | Epson PhotoPC 600 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
60 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Steven Wander
Steven Wander
Damen Wong
Damen Wong
Are you a Casio Camera Expert? Answer questions, earn points and help others
