When Tray 2 empty draws paper from tray 1, How do I stop this
He hold letterhead paper in tray 2 and plain in tray 1. We continually find that when tray 1 is empty the machine automatically draws from tray 2 meaning all the copying is useless and is waste of letterhead paper.
  • Anonymous Feb 19, 2009
    Ricoh 2228c Articio. Have looked on computer to see if I can change settings via computer but dont seem to have option here. On machine, well, I dont know where to start.
    Thank you for responding to my question.
  • Anonymous May 11, 2010
    not knowing the model makes advice extremely difficult, but somewhere in your printer settings there is the option to turn "automatic tray switching" OFF
5 Suggested Answers
maklean
  • 1665 Answers
SOURCE: Drawing paper from the wrong tray
http://www.smpcshop.com/C5500-C5800-C6100-p-6250.html
Posted on May 06, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Paper Tray Settings
You have Auto Tray Switching acticated (ATS). Unless you specify each tray/paper with different settings it will switch.
Go in to the utility menu and you can find this in the paper tray settings area I believe.
You can turn this off completely to avoid this in the future.
If you look around you can even just tweak the settings for this, but in your case i would just shut it off.
Posted on Jun 06, 2008
leroyal
  • 2120 Answers
SOURCE: HP Laserjet 4250tn - cant print a letterhead invoice
Do a paper path test from each tray in diagnostics on the control paneland check Printer Properties for PAPER HANDLING
Posted on Feb 17, 2009
  • 240 Answers
SOURCE: default paper tray selection for HP LaserJet 4200tn
1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
Paper Handling menu, the printer will always pull paper from tray 1 first.
Posted on Dec 10, 2009
SOURCE: Printing from wrong tray
I have the same problem Peter with my Phaser 8560. Xerox Tech Support has been no help. I've even updated the firmware on the printer and it still won't print to the right tray, even though I have everything setup right on both the client side computer and within the printer itself.
Posted on Dec 08, 2010
Why does my Samsung ML-3712ND printer say "paper empty in MP tray" when it is not empty?
The MP tray is the fold down 50 sheet tray that is built in to the front door of the Samsung ML-3712. It is usually used for thick papers, letterheads and unusual sized paper.
Sometimes people mistake the 250 sheet cassette tray that slides underneath the printer for the MP tray.
If you want to print on plain paper in your cassette tray and you keep getting this message.
1. cancel all print jobs
2. try printing a new document ( you can make a new word document with just one line)
if that works
Usually one of the settings in the print job you are printing will be out of specification ( could be too small margins) and the printer will be trying to feed from the MP tray
If the new print job doesn't work, the problem is likely in your default printer settings/properties
Dec 01, 2014 | Samsung Office Equipment & Supplies
How do you stop the headed paper in the by pass tray being used when the plain paper in the main tray has run out? I have wasted so much headed paper by the machine switching without any warning.
the device is programmed at the factory as a default to switch. try two things,1st function, general, key operator, code 0000, then at number 1(paper size) select bypass and then change media to letterhead or something other than plain.
2nd, function, general, key operator, code 0000, then at number 4 ( special paper tray 1) designate the bypass as a special tray. this should "exclude" the tray from available tray. good luck
Apr 07, 2010 | Panasonic WORKiO DP-C262 Printer
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
Printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
Jun 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Feb 17, 2009 | Office Equipment & Supplies
Paper Tray Settings
May 30, 2008 | Konica Minolta bizhub C250 All-In-One...
When Tray 1 (A4) is empty it is picking up Tray 2 (A4 ? letterhead) and we don?t want that to happen cause we print in bulk! When Tray 1 (A4) is empty it is picking up Tray 2 (A4 ? letterhead) and we don?t...
Hello Uncle123,
I don't have a user manual at my fingers, but you can go into "additional functions". I don't recall if it is within the"common settings" tab or "copy settings" but you can designate any paper tray to be "unique". For example you can designate tray 2 as "colored paper, or recycled paper" .In which case, if you are feeding from tray 1 and it runs out the copier now knows that tray 2 has a type of paper that is different than the current run.Even if the paper size is the same. I hope this helps. Take care. ..............................spinal.........................
Feb 22, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Printing using various trays
Yes
Set tray (3? ) or other non standard paper type trays to type setting of letterhead and set normal paper tray (2) paper type to plain .
You do this on printer keyboad find menu then find paper handling, tray xxx, paper type. xxxx...set or tick
Via operations panel you can also printout current settings too to see if you have done the change if you do one before and after
Then test,
There are other settings on your printer that can effect this and driver configuation and doc type setting on pc that can effect this also but try step above first and report back if still having issues. Is it run by a server? Do you abity to change driver settings on your pc?
Oct 19, 2007 | HP LaserJet 4350 Printer
178 people viewed this question
k24674
