Question about Casio EXILIM ZOOM EX-Z850 Digital Camera
Camera does not react
I bought the camera 2 or 3 years ago, and I did not have any problem. A couple of days ago after using it when trying to see the pictures on the camera the LCD did not show anything. The lens reacted and even take pictures but nothing was visible on the LCD screen.
I tried charging the battery and removing it from the camera, now the camera only does a bit sound when switching on but nothing else, the lens does not even come out.
Anyone had the same problem and knows the solution?
  • Casio Master
  • 19,396 Answers
I quote: "A couple of days ago after using it when trying to see the pictures on the camera the LCD did not show anything. The lens reacted and even take pictures but nothing was visible on the LCD screen."
That means that there was a problem either with a LCD display or with ribbon cable.
Now:"I tried charging the battery and removing it from the camera, now the camera only does a bit sound when switching on but nothing else, the lens does not even come out."
That means that the ribbon cable had probably shorted, now the camera may be furtherly damaged.
The camera must be disassembled to access the LCD and fix the problem.
The repair must be done by an experienced technician, as to access the LCD you need to remove both covers.
Posted on Jan 07, 2009
I have had my D3100 for about 2 years and love it. In the past 2 weeks it won't power up. I thought the battery had gone bad so I bought another. It powered up and I took a few pics but then 2 minutes...
are you using Lithium batteries?
cameras are WEIRD!!!! I have watched brand new, regular size personal camera eat regular batteries in just a couple pictures, then work fine with lithium batteries. Also..cheap batteries are just getting cheaper, so as it may of worked fine 2 years ago, could just be not so good batteries. If your not using lithium batteries, id try that first, will run you 10 bucks for 4 AA's, but thats better than the flat rate fee a shop would charge you to look at it first.
an image..just in case
http://www.greatwallforum.com/images/equipment/EnergizerUltimateLithium.jpg
Nov 01, 2013 | Nikon D3100 Digital Camera
Hi, i've bought a new canon camera (powershot
You probably need to move the small switch on the memory card to the open position.
Oct 28, 2013 | Canon PowerShot A810 16MP 5X Optical Zoom...
I have got olympus digital camera model FE-230 purchased in 2007. few days back my camera got switched off while using. till then its not geting switched on. what might be the cause. plz assist me. ...
Have you tried checking the battery? As you mentioned before, the camera was bought 3 years ago. And doesn't specify if you left the batteries inside the camera. Please try replacing the battery, otherwise send the camera to the nearest Olympus for technical check up.
Thank you
Aug 07, 2010 | Cameras
I have a Canon A590 Low Battery even with new batteries installed
Use NMH type batteries standard batteries are not good enough for the write load that this camera draws. I think it recomjmends this in your manual if you still have it.
also dont use rechargables
Please rate my help++++Thyanks for using FIXYA
May 09, 2010 | Canon PowerShot A590 IS Digital Camera
Pink and Black in natural light
It sounds like the light sensor on the camera is malfunctioning. Try cleaning the sensor. If the senor doesn't work at all it will not be able to tell when the camera is operationg in bright light. Kind of like having your eyes dialated and walking outside on a sunny day.
Jun 15, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
Kodak C643..what is wrong?
i bought some nimh rechargeable batteries a couple years ago and they still work to this day. im on my second camera with them and it does that to me when the batteries are dead. try opening the battery door when it does it and then close it and try turning it on again. if it does come on then its the batteries.
Aug 30, 2008 | Kodak EasyShare C643 Digital Camera
Low battery warning
It's something with the camera. I have the same camera and the same problem. I bought 2 brand new batteries, charged them, and the very first thing the camera did when I installed the new batteries was tell me that they were dead!! Grrr....
As a workaround, when it tells you the battery is dead, just open the battery door, close it, and try again. Repeat if necessary. With my camera, doing this lets me use the same battery for days and days. The battery is NOT dead - it's just a faulty warning message.
Apr 18, 2008 | Canon PowerShot SD10 / IXUS I Digital...
C-8080 Turns off/on randomly..
Hi Galaxy,
Try running camera directly on DC from charger and see if it stays functioning.
If it does, they you either have:-
1) a faulty Lion battery
2) the battery detect circuit in the camera is faulty (reporting low battery and forcing shutdown)
3) the power switch on top of the camera may be leaky or partially collapsed
4) internal power supply circuit in camera has developed a fault.
Good luck...hope that the issue is the battery.
Kiwi-Mark
Jun 05, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Camera Error Message #E41
Hello Yami, I suggest you that dont leave any digital camera non-used for a long. your error shows that camera needs service. I think that you can not do it yourself. But try onething, just store your camera in a small corrugated paper box twice bigger than camera and leave it in sunlight for a couple of hour. then take it indoor and leave it for an hour to cooldown at room temperature. Now it is suggested to incert the batteries and try to operate. I hope your problem will be fixed. pls remove the battery when you leave the camera in sunlight. good luck.....
Jul 25, 2006 | Kodak EasyShare DX4530 Digital Camera
Casio EXILIM ZOOM EX-Z850 Digital Camera Logo
225 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
