Question about Dell 2600 Notebook
Install os,cd drive not working
How can i install windows, my drives not operational.i try to install os by temporarily hooking the hard disk to my desktop. it boot up on my desktop but when i try it on the laptop it does not work
  • 3 more comments
  • g_pabines Jan 07, 2009
    a buddyjust gave me an inspiron 2600 without hard disk and a broken dvd drive. i just want to install OS on the newly installed hard disk. how can i do it?
    windows XP SP2
  • g_pabines Jan 08, 2009
    the hard disk works fine with windows xp on it when connected to the desktop but when i try it on the laptop......ask me to choose how will it starts(normal/safe mode).if i choose safe mode the screen fills up w/ multi disk partition windows etc. if i choose otherwise it hangs.
    on boot set up: hard drive/floppy/cd-rom/cardbus nic/onboard nic--no USB
  • ramosrich May 11, 2010
    Some questions.
    What windows do you have?
    What model is your laptop? (some models have recovery/some models allow USB boot)
  • 36 Answers
Ok, try to go to the bios. Make sure you have it boot in usb. You have 2 options in usb boot. U can use a flash/thumb drive with windows in it, or you can use external DVD/cd drive.
Other option is to format the HD first then copy windows OS installation in the hard drive.
Make sure when u format this hard drive
Posted on Jan 07, 2009
  • ramosrich Jan 08, 2009
    That wont work actually, if u install it in the desktop then move the hard disk to the laptop, unlike windows 98 that it will work, with xp it wont. Just try the solution i have above.
  • 741 Answers
You can hook two computers together using a crossover cable. They may have them at radio shack, if not you can find one on the web for cheap. Then you can put the install in one cd and have it install in the other computer.
Erased hard drive, how can install os without the disk?
You would require an installation media to re-install OS, So you can't do it without CD or USB thumb drive with installation file.You can call dell @ 8006249896 and ask them for OS disk, If you wouldn't have received with the computer, they will be sending it to you free of cost and it will only take 2 to 3 business days for you to receive those than you can re-install OS.
Dec 28, 2012 | Dell Inspiron 1525 Notebook
My acer aspire one has a hard drive failure on the following disks IDE/SATA.I diagnosed it then got the following report. HDD doesn't respond to system commands Boot sector damaged read time...
You need to format your hard disk. Please note that formatting will erase all you data from the hard disk and all the software including the Operating system.
If you have your OS master CD you can insert it in the cd/dvd drive and restart the laptop. This will detect the OS CD and try to install it. In the installation process there is an option "Format your hard drive". You should select that option. Then it will format, mark the bad sectors, create a new boot sector and install the OS. You will be just fine.
Aug 03, 2011 | Acer Aspire One PC Notebook
I have compaq nx6310, i had issues with the os.once you touch a button it starts open other buttons and pages automatically. i tried restoring the system to earlier dates and the issue reduced. later on it...
Hi das4real! These are the things to consider.
  • Operating system disk - Try to test your Installation CD to other computer. If it doesn't work then you need to replace the disk
  • Optical Drive (CD/DVD Drive) - If Installation disk works then try to clean your Optical drive lens as it may be having a hard time reading the disk. Your Optical drive is working since you're able to format and able to start the installation. Cleaning the drive lens may do the trick.
  • Hard Drive - If Installation CD and Optical drive is clean. Then the last thing you need is to replace the Hard Drive. You Hard Drive might need replacement due to some bad sectors and the installation couldn't write anything on the drive that causes to freeze during installation.
I hope this helps you.
Mar 15, 2011 | Computers & Internet
Help me in formatting my hard disk
Put OS disk in shut off computer
restart computer
push ENTER to boot from cd- this is not happening.
It is possible that your OS disk isn't good
Apr 12, 2010 | Dell Dimension 2400 PC Desktop
How to reformat my MSI notebook?
You need to have an valid Operating System installer CD/DVD. This could be a Windows or Linux installer or whatever Operating System that you prefer.
  1. Turn your laptop on.
  2. Open the CD drive and load the CD Installer.
  3. Reset your laptop to manually reboot it. If you loaded the CD fast, this step is no longer required.
  4. The setup program will then load. Follow the onscreen procedure.
  5. At the point of selecting the hard disk drive, choose "Delete Partitions" to completely remove all data.
  6. After deleting partitions, create new partitions for your hard disk. You can choose to divide your hard disk capacity into 2 or more partitions depending on your requirements.
  7. Format the root partition now (Drive C) to continue the installation.
Mar 03, 2010 | Computers & Internet
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
Attempt to turn on computer, no OS install windows
Marginal hard drive, hard drive cable, or hard drive controller (on motherboard).
Other suspect parts may be the CD ROM drive you're trying to run the OS install from. It may also be flaky, causing you to think you're loading the OS, but not really and not reporting errors until you discover the OS is not completely installed.
First thing to do is pull the HDD and cable out, reseat firmly and try again. May as well do the same for the CD/DVD drive.
Mar 05, 2009 | Toshiba Satellite M45-S165 Notebook
This issue normally means that your hard drive is bad. What the computer is trying to tell you is that it attempted to locate Windows, but it can no longer be found. The Hard drive is normally the case for this message. If you want to be sure its the hard drive I would suggest downloading and boot from this CD try and access the hard drive with this cd, if you cant the Hard Drive is toast. If you can the OS became corrupt and could still mean the Hard Drive is close to being toast. Either way throw the toast in the trash and buy a new Hard drive.
Have a great week,
Feb 24, 2009 | Acer Aspire 3623WXMi Notebook
Having problem installing Windows XP on My Acer Aspire T650 Computer
Before you did the install did you make sure that you set your CMOS setting to check for a cd disk first before booting straight to the hard drive? When you do an install, you must make sure that the computer knows to look for a bootable disk otherwise it will look for an operating system to boot to first. If this is the problem, after you have installed your operating system you must go back and reset your CMOS settings to look for a hard drive or operating system. Hope this help and if it doesn't let me know for further assistance.
Jul 04, 2008 | Acer Aspire T650 (AST650UC3601) PC Desktop
PC halts while formatting hard drive
make sure your hard disk is error free Try formating the disk with FAT first ,if it doesn't work out the try disk utilities .
Nov 29, 2007 | Microsoft Windows XP Professional for PC
Dell 2600 Notebook Logo
43 people viewed this question
Alun Cox
