Question about Bugaboo Frog Stroller
Bugaboo Frog Handle Bars Not Locking into place
I have a bugaboo frog and the handle bars do not lock into place on one side. Does anyone know how or where i could go to fix this? I live in Parramatta NSW
    Problem Solver:
  • 5 Answers
We had a similar problem with our Bugaboo Cameleon. The right-hand hinge of the frame would not lock and the button was permanently down. What had happened was the handle extension switch housing had come unscrewed and slipped up the frame, causing a small spring to fall out. The lock switches each have a spring which pushes down on a rod inside the frame to lock the hinge. To access the spring, unscrew the handle extension housing and slide it up the aluminum frame. I replaced the missing spring and the frame works perfectly. If the problem is with the spring, this should work. Alternatively the problem may lie inside the lock switch housing, which contains a very simple mechanism which slides the lock rod up and down. This can be unscrewed as well. As far as I can tell, the actual hinge assembly itself is a sealed unit and can't be opened, but hopefully, you won't have to.
Good luck,
Posted on Jun 25, 2009
    Problem Solver:
  • 3 Answers
Try to contact Bugaboo Service 1-800-460-2922 or
Posted on Jan 08, 2009
That handle on my bugaboo frog doesn't click into
The Cameleon, Frog and Gecko all use the same parts inside the hubs. Most common problem is the locking rods fail (little aluminum dog leg shaped thingies). The full story is in the following link complete with where to buy stainless steel replacements for $15 each. If you reuse the dome you can fix it for $30 but I recommend you replace the dome if you can source one, full story here...
Sep 23, 2011 | Bugaboo Baby Gear
Can I modify the handle bars on a Frog? I need to lower them for Mum under 5ft tall? Take then off and replace with adjustable handlebar? Which part would I need to purchase? Is it in stock? price?
The Cameleon has the adjustable handle it is not available as a part only as a complete chassis for around $400 Your Frog wheels, seat etc would fit. If you found a broken Cam frame on eBay you could swap the handles. Your Frog would have the parts required to fix the Cam. Click on this link to my tips section Note as you don't need the old Frog handle you could try prizing off and reusing the domes but I don't recommend that. Brake cable is compatible.
Aug 05, 2011 | Bugaboo Frog - Black Stroller
Bugaboo Frog Handle Won't Lock in Place
Visit they can help
May 05, 2010 | Bugaboo Cameleon Jogger
Bugaboo Frog has a loose handle
Theres a company that repairs bugaboo chassis their web site
Apr 08, 2010 | Bugaboo Frog Stroller
What is the swivel hub locking switch on the bugaboo frog?
There are two white buttons on the handle near the top. Pulling them upward releases the handle so you can fold down or reverse handle postion.
Jan 28, 2010 | Bugaboo Frog Stroller
Faulty handle
bugaboo have a 2 year warranty you can't fix that problem you will need to replace the handle go to they may have second hand handles.
Aug 24, 2009 | Bugaboo Frog Stroller
How do I collapse bugaboo stroller
take off the basinette or seat
then, there are 2 knob, sticking out of the sides of the frame, about 6 inches below the handle, from the normal pushing position, hook yr fingers round them and slide them up the frame towards the handle
the handle will drop, then just up the frame from the cross bar under where the set is.
easy once you know how
if it still don't work, go to your local park and accost the nearest person with a bugaboo and ask for some help - there'll be hundreds of them!
Jun 21, 2009 | Bugaboo Frog Stroller
3 year old bugaboo frog stroller chassis on right hand side not locking in one place
yes there is an answer now are the only company that does repairs to bugaboo handles at fraction of the price of a replacement handle
Jun 25, 2008 | Bugaboo Frog - Blue Stroller
Bugaboo Frog Foam Handle ripped
On Ebay, if you type in Bugaboo on the search field, there is an item called Stroll-air that covers the handle bar. I think it's made of neoprene (like wetsuits) or something that looks like it.
Jun 24, 2008 | Bugaboo Frog Stroller
Handle bar issue...
PHONE: 1-800-460-2922
Aug 13, 2007 | Bugaboo Frog - Aubergine Stroller
Bugaboo Frog Stroller Logo
712 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
