Question about Hotpoint TDC32 Electric Dryer
DRUM NOT SPINNING....and a burning smell
My hotpoint ctd00 tumble dryer drum spins very slowly...or not at all, then you get a electrical burning smell... had the side off, and its not the belt slipping, as the motor fails to turn....but it does turn by hand... its almost like the drum if sticking??
  • Anonymous Mar 28, 2014
    don't want to burn motor out
  • Anonymous Mar 30, 2014
    when machine is turned on the drum will not turn and it smell of burning,black resedue at the back of the machine
    President:
  • 2,692 Answers
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Posted on Jan 07, 2009
My hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Jun 26, 2012 | Hotpoint Aquarius WD63 Front Load...
I have a hotpoint VTD00 tumble dryer and it is heating up but the drum isn't spinning and smells of burning. Thanks, Annmarie
The belt is probably worn out and is slipping,the smell is from the belt slipping on the drum.
Mar 02, 2011 | Hotpoint Dryers
My ctd40g tumble dryer has recently started smoking and the drum is no longer spinning, can you help?
Your dryer motor might been short circuited and the motor needs to be rewind or replaced.
Nov 11, 2010 | Hotpoint TDC32 Electric Dryer
Hi, My Hotpoint CTD00 Condenser Tumble dryer makes a thudding sound with every revolution, sometimes it sounds like a pair of trainers are in there! What could be the problem?
Could be a worn drive belt, or more likely to be a worn rear drum bearing, common prob with dryers, you need to remove top cover, and look for anything obvious.
Please rate my solution.
Thganks.
Nov 02, 2009 | LG DLE2514 Electric Dryer
How do I replace bearing on a CTD00 Hotpoint tumble dryer
front bearing on drum felt bearing the whole front has to be removed from machine .. if felt back bearing same applies .. if the plastic drum bearing guides this can be done by removing side panel .... always disconnect from mains before attempting any repair
Jun 11, 2009 | Hotpoint NWXR473EV Dryer
Replaced belt & pulley, now drum won't spin properly
Belt mounted upside down. Slick side goes to tub on this odd ball machine.
Mar 08, 2009 | Maytag SDE2606 Electric Dryer
Tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint NWXR473EV Dryer
Hotpoint condenser dryer ctd00
change the drive belt. evidently the belt has stretched to the point the belt tensioning device can no longer do its job. when you change the belt make a diagram of which way the belt is reaved through the tensioning device. if you don't you'll be back here asking how to arrange the belt.
Jun 19, 2008 | Hotpoint TDC32 Electric Dryer
Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Feb 16, 2008 | Dryers
Hotpoint TDC32 Electric Dryer Logo
1,213 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
