Question about Welding Tools
MIG wire is always hot without pulling trigger
I have a Miller 185 MIG welder. Every time I touch the MIG wire at the torch end onto my work surface,  the wire will arch, without pulling the trigger. Any help will be greatly appreciated.
  • 1 more comment
  • Thomas F. Schneider May 11, 2010
    The transformer is partly shorted,or grounded . look for wires toughing the case.
  • vito macchia Aug 16, 2013
    makes a grunting sound and dims the lights in the shop
  • Anonymous Mar 29, 2014
    i have the pulse out set at 0 but the wire still comes out after the trigger is depressed
  • 92 Answers
Check your manual, there are a lot of mig units on the market that are alway "Live" alternatively, the relay has either shorted or you have wirering problem on the switch.
Posted on Jan 23, 2009
My welder won't feed wire it sounds like it's trying to energize but can't. A couple of times it fed through but wouldn't feed to weld so I had stick weld. What happens if the liner has a restriction?
first unscrew the tiny tip at very end of torch (can be hot)!! then try to feed wire thru handle,gently shake cable as you do helps to feed wire thru cable , if successful you have allowed the amps to get too high for the feed rate (slow) and melted the tip closed , these tips are replaceable from miller and are not expensive
Aug 09, 2016 | Miller Multimatic 200 MIG TIG & Stick...
Phase three on cv or cc have current going to mig wire, wire is live without hitten gun trigger. mega arc is hooked up to a Hobart suitcase
May need to take gun apart and see if trigger is sticking or replace lead.
we use Miller at work. The feeder has a switch that makes the trigger turn off and on with quick pull of trigger so you don't have to hold it entire time.
check wiring to make sure it's wired right so your not bypassing the trigger switch.
hope it helps.
Nov 02, 2015 | Hobart Welding Tools
My miller 210 arks when you touch the metal surface before I pull the trigger.Thanks
Hi:
The contact box inside your welder need to be replaced. This problem will create burn backs and probably an accident since the gun it's hot always.
The part number you need to replace is MIL189486. If you don't have a sales rep from a welding store, here's the link to praxair, they will ship direct to your address via USP. Contact them by the 800 number or find your nearest location.
http://www.praxairdirect.com/webapp/wcs/stores/servlet/TopCategories1_10152_10051_-1
Good Luck
Sep 12, 2011 | Miller Welding Tools
216 mig no feed no fire maybe selonoid problem please help seloniod does not click
It could be just the simple problem of the trigger not working. Disconnect the trigger wires from the machine at the plug at the front of the machine. See if you can manually trigger the machine by placing a piece of bent over mig wire onto the contacts. If the machine does trigger from this then your fault is in the torch somewhere. It could be the trigger (which commonly does fault from a dusty environment) which is easily replaced by going into any welding store with the torch model number (magnum 250L), or it could possibly be that a trigger wire has broken from the torch being damaged
May 29, 2011 | Lincoln Electric Lincoln Power MIG 216...
I have a clarke weld 85 en mig welder which starts to weld without having to press the trigger on the gun. what could cause this please
I have a clarke 85en no gas welder. the gun on this particular welder is always live the trigger only feeds the wire
Mar 08, 2011 | Welding Tools
Clicking noise when trigger is pulled
Sounds like a switch problem to me?
Feb 20, 2010 | Welding Tools
Gun trigger no worky
Remove the torch and check for continuety, if it is the switch youcan purchace a new one from the torch manufacturers.
Nov 24, 2009 | Miller Welding Tools
Open circuit??
try blowing out the welder
Mar 19, 2009 | Miller Welding Tools
Spool wire starts to melt while on the spool
1] Switch off the mains power,remove the torch from the machine,ther should be a button or switch on the unit to feed the wire, push or switch these and observe that the wire feeds and dose not heat up, if ok then you have a short in the torch, a new torch assembly is required,if the wire heats up with the torch removed, the wire spool is shorting out, remove the spool and check wiring in and around the feed motor, if you can't see anything check for a voltage from a good earth and on the rollers, if you have a voltage then the motor is faulty.(earthing out) a P.A.T test should show exactly where this is.
Feb 16, 2009 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Renegase 180
This fault is typical in most MIG/MAG Units. the feed roller/s need slackening off, pull the trigger so the rollers spin wire the wire not moving, turn the tensioning 1 turn check to see if the wire feeds, if not give a half turn on the tentioner repeat this half turn untill the wire feeds, bend the wire to the torch and pull the trigger, If the wire feeds then thats the correct setting. be awear of all safety rules. use gloves
Nov 01, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Welding Tools Logo
549 people viewed this question
Top Welding Tools Experts
Lawrence Oravetz
Are you a Welding Tool Expert? Answer questions, earn points and help others
