Question about HP iPAQ RX3715 Pocket PC
Ipaq 3715 tapping problem
When i tap and hold it should make copy menu.
Currently when i tap and hold there is nothing hapens.
I made Hard reset to my device.
I pass the calibration level. But at the second stage i cannot copy/past.
Please HELPPPPPP
  • vedran Mar 05, 2009
    on startup my ppc show some charging screenand when come to end of charge noting hapen.
    touch screan not responding, butons not responding and light of display turned off...?
    what I must do?
    Ihave not acabel to conect to PC
Have you downloaded any viruses? if not try another hard reset is the screen cracked?
Posted on Jan 27, 2009
Need to transfer files from the Hx4705 main memory to the installed SD card using only the HX4705
Go to 'Start > Programs > File Explorer'. Chose the directory containing the file you want to copy by tapping the application's top bar. Tap and hold the file to be copied, until a context menu pops up. Select 'Copy'. Now, choose the Storage Card from the top bar. Once there, tap on 'Menu > Edit > Paste'. Your file should be copied.
Hope it works for you.
Cheers! Carlos
Apr 13, 2010 | HP iPAQ HX4705 Pocket PC
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
I´ve a pda hp h5455 that don´t start , i´ve tried to do a hard reset and charge it via USB and nothing hapens
To do the hard reset, while on battery (NOT A/C) power, hold down the two outside front-panel buttons (Calendar and iTask), While holding them, press the reset button with the stylus. Keep these buttons all pressed until the image on the screen begins to fade (about 4 seconds), then you can release the reset and application buttons. To restart your iPAQ, you must then plug the unit into A/C power, or do a Soft Reset by again, pressing the reset button with the stylus.
Nov 21, 2009 | HP iPAQ H5455 Pocket PC
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
How do you reset it to factory settings
To perform a soft-reset (if the device has locked), briefly insert the stylus or a paperclip into the reset hole on the bottom left of the 3715
To perform a hard reset (losing all data!), insert the stylus or a paperclip into the reset hole on the bottom left of the 3715 while holding down the far left and far right of the four main buttons. Information in the iPAQ File Store will not be lost, but data on the Internal memory will be wiped.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 30, 2009 | HP iPAQ RX3715 Pocket PC
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
loaded are stored.
functionality.
Oct 16, 2008 | Computers & Internet
No power to Ipaq 3715
Just did this one, please refer to
http://www.fixya.com/support/t395532-not_turn
For the solution
Jul 29, 2007 | HP iPAQ RX3715 Pocket PC
Hard reset does not wok in my ipaq H3955
The touchscreen may be broken, try hardreset again if it doesn't help contact your dealer or HP for possible repairs.
Sep 14, 2006 | Compaq iPAQ H3955 Pocket PC
HP iPAQ 3715 - screen problems
Return it as faulty. WiFi should not impact your screens ability to stay on.
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
99 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
