Question about Yamata FY750
Need manual and coulor threading diagram for YAMATA FY757A
Just brought machine second hand....lost manual..threads keep breaking...tension not tight
SOURCE: thread breaking.
Have you tried to change needle?
Posted on Feb 20, 2008
  • 6 Answers
SOURCE: Thread breaking
have you tried to use a different type of needle such as a metallic ? this type of needle has a larger eye than regular and helps to keep some of my embroidery threads from breaking. also can you sloe the speed of the machine down? i sometimes found this helped me in embroidering. hope this helps.
Posted on May 06, 2008
Mimito7
  • 128 Answers
SOURCE: FREE threading instructions
try this..
www.2instructions.com
Posted on Apr 22, 2009
  • 26 Answers
SOURCE: Tension
I answered this a couple days ago but don't know if it went through. I can sew through 6 or more layers of denim with my 226, no problems at all. In my 30 years in the upholstery business I never had a problem sewing leather, vinyl, canvas or multi-layers of fabric. The 226 Consew, the 111W and 211w Singers I had presented zero problems with heavy fabrics - and I don't consider vinyl "heavy".
You need to first of all check threading. If the machine's threaded wrong you're break thread. Also you need to oil under the bobbin case and the bobbin hook and the rest of the parts as well.
Then, loosen thread tension on top by turning the knurled knob that's on the spring that's holding the tension discs. Also loosen bottom tension on the bobbin case by turning the small, left-most screw on the outside of the bobbin case counter-clockwise. Do both with the presser foot down. Pull the thread(s) out and feel the tension. You should be able to pull the threads out with some little effort. Tighten both a little at a time until you get some tension. Run a couple seams and check where the threads meet in the fabric. They should meet in the center. Also check stitch length. If you're using 92 thread (is should be left twist), you should run the machine at about 6 - 7 stitches/inch. I'm running my machine at 5 - 5 1/2 with #69 nylon bonded, and 6 - 6 1/2 with #11 mono.
One more thing; if tension's too loose at the bobbin or top, the machine will jam in the bobbin and thread will break.
Go to www.consew.com and download a pdf owner's manual for free. You need to click on the 224. That machine, the 225 and 226 are the same.
Posted on Aug 31, 2009
SOURCE: free download of singer overlocker manual
Jag har en industri overlock singer 81k73 Jag kan inte trä den
Har du några förslag
Posted on Oct 20, 2009
I have a YAMATA fy14u4ad, but I don't have the book to tell me the thread setting so what should the thread setting be for all 4 threads
Assuming this is a 4-thread serger. The thread tension setting will depend on which stitch you are making. A standard 4-thread overlock stitch would generally have the tensions set in the middle. FWIW, the tension in this setting is correct when the threads meet in the middle of the fabric. It should neither be off the edge of the fabric or so tight as to create a puckered edge.
Aug 10, 2017 | Yamata Sewing Machines
Model 3434D. Why does lower looper thread keep breaking?
Usually thread breakage is due to incorrect threading or tension set too tight. When thread breaks, the Best Course of Action is to clip all the threads between the thread tree and the tension disks, Raise the presser foot, and pull all the threads down and out. (Never pull threads up through the tension disks.)
RAISE the presser foot, rethread each and every thread in the order specified in the manual and confirm that each thread path is correct. Grasp each thread between the thread tree and the tension disk with one hand and with the other hand grasp the thread below the tension disk and give a little tug to make sure each is seated firmly in the tension disk. Also on most machines, the lower looper thread must drape over the the upper looper before being pulled under the presser foot.
Lower the presser foot and set each tension guide to the midway point (the factory standard) and retest.
Usually, rethreading only the broken thread will fail. (For some reason, sergers are very finicky.) Just bite the bullet and rethread each and every thread.
Feb 22, 2016 | Janome Sewing Machines
I need a diagram of how to thread it or a problem solver the thread eeps breaking at the needle
Search the internet for:
Manufacturer + Model + the word "Manual"
or search YouTube videos for "sewing machine threading." You may not find your exact machine, but many machines have similar threading patterns. Be sure to raise the presser foot before threading the upper thread so it will seat properly in the tension disk.
If the thread is breaking at the needle, it could be several problems:
Threaded incorrectly--#1 cause
Upper tension too tight
Install a brand new needle compatible with the fabric & thread
Make sure the thread is not too large for the needle eye
Avoid old, fuzzy, bargain bin thread
All About Needles
Dec 24, 2015 | Necchi Sewing Machines
Thread keeps breaking when I sew.
one of three issues: top tension too tight, bottom tension too tight, needle timing off.
Oct 21, 2015 | Elna 2005 Mechanical Sewing Machine
The thread keep bursting as soon as i start to sew although machine is thread properly
Check your thread tension isn't too tight, try on a piece of similar fabric that you are going to use, try sewing a line of stitches, if the thread snaps, change your tension number, then sew another line with your different tension number, try this until you can stitch without the thread snapping, it could be that your bobbin tension is too tight. Can you check your machine manual, it could even be the needle or the thread that's wrong for your fabric. But I would say, check your tension.
Hope this helps.
Apr 02, 2014 | Yamata FY811 Mechanical Sewing Machine
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 08, 2013 | Yamata Sewing Machines
When sewing thread keeps breaking and comes out of the needle
keep longer thread tails before you begin to sew and make sure
the thread tails are pulled behind the needle before you start sewing
THE COTTON KEEPS ON BREAKING EACH TIME I WANT O SEW WITH MY YAMATA FY940
8. try a different thread
9. try adjusting the top thread tension--to a lesser number or letter
use your manual to guide you through tension adjusting
Dec 20, 2012 | Sewing Machines
Trying to thread and thread keeps breaking when i try to use i, i am following the guide but cant figure out what i am doing wrong
Hi. Make sure you're not using old thread. Old thread, or thread that has been exposed to sunlight, gets weaker and is more likely to break. When I realized old thread was causing problems, it about broke my heart to throw it all out (I had spools of thread that my momma used.....wooden spools...but out it all went.)
Another thing that could cause your thread to break is if the top tension is too tight. You might try loosening it a bit and see if that helps.
Let me know if this helps, ok?
Happy Sewing!
Robbie
Mar 11, 2010 | Yamata BL4-434D
Yamata FY750 Logo
612 people viewed this question
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Douglas Plant
Douglas Plant
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
