Question about Nikon COOLPIX Cameras
"frozen" unless connected to TV
Someone else already has a similar problem but mine is not because of water damage. Like it says the camera is more or less frozen unless its connected to the tv. If not connected it turns on the lens comes out, and the "welcome" screen comes on but with no backlight on the lcd. That is it though, the camera then is useless, it wont even turn off, you have to take the batteries out to shut it off. When connected to the tv though it works fine. Everything works displayed through the tv just fine. Is there any sort of solution for this? Would there be any hope in taking the camera apart and looking around for something and cleaning it? Thanks for reading
  • 1 more comment
  • Jamez Brown May 29, 2007
    The camera will only take pictures when connected via the TV. Otherwise it will not do anything short of just turning on and "freezing"
    As for the Nikon website and "tech" support it's pretty much useless.
    The camera was my moms and she just stopped using it after this problem occurred. I do have a little brother that is now 5 and likes to touch everything so there is a possibility he was playing with it. It has been so long though that it was working correctly that I doubt anyone would remember but I will take a look at all the settings. The camera certainly isn't knew as my mom received it as a gift from someone more than a year ago but we have gotten hardly any use out of it.
    Thanks for the replies I will get back after I take a look at the settings.
    I have went through the settings and gone through anything relevant in the manual and found nothing. Maybe it is just done for.
Battery cover problem
Posted on Jul 30, 2010
    Genius:
  • 2,985 Answers
See if you can take pictures with it- ignore the screen for the moment. The fact that the welcome screen comes on - suggests that the screen itself and its connections are OK. Displaying images on the TV say those parts are OK. Taking it apart to 'clean' is not advised there is nothing there that you or I can fix. With this clarified Go to the Nikon website and check with Technical support team.
Posted on May 29, 2007
  • john ash
    john ash May 29, 2007
    @Camera will only take pictures when connected to TV.
    Sounds ominous
    Connecting the cameras to TV with images on the card and the control set to upload or play will give you pictures on the card.
    This sounds like a control or setting problem
    Is this something 'new' that is it was OK once but started acting up- since when?
    Check that you have all the setting as they should be and check the manual if you have it- or it will be a PDF file on the software disk
    in case this a 'settings malfunction'.
    But from what else you say it does seem as that it has come to the end of its days.
  • john ash
    john ash May 30, 2007
    Looks that way- time for a new one then
The display screen is black and won't show pictures being taken, however it does work in Review mode.
It is possible that your camera's internal computer might be going out. I had similar symptoms on one of my cameras. Have the batteries ever died in the camera? It could be one of the causes.
The cost to have the new computer installed on my camera, was about $230.00. I took mine to the local professional computer repair shop and it was returned to me in less than 24 hours and working great. Your price will vary with the make, model of your camera. Mine was a Canon 5D mk2. Take it there and let them give you the diagnosis and then decide if it's worth it to repair or replace it. Don't use my fee as your guide, unless you have the same camera.
Hope this helps. Mike
Nov 30, 2015 | Kodak EasyShare Z612 Digital Camera
Broken shutter curtain
Fixing this requires a complete new shutter assembly and it's not a DIY job. Spares availability is also now very poor.
You can easily get a complete similar replacement SLR for a lot less than the cost of repair, so your best bet is to harvest every single removable accessory from the body and recycle it. A replacement camera should be dirt cheap or free as this and similar models are effectively worthless these days unless they're known to be collectable models (the F60 definitely isn't collectable). I get all of mine from my local FreeCycle and Freegle groups, some are boxed and virtually unused with all accessories, like the F75 kit and F-801 which I recently obtained.
Sorry that there's no realistic option to fix your camera, but I hope that my answer has given you a realistic alternative means to solve your problem. Please take a moment to rate my free answer.
Oct 07, 2010 | Nikon F60 35mm SLR Camera
Error lens.
I see two options. 1. Buy a new camera. 2. Have a professional camera repair person look at it and suggest repair or replacement. You may have damaged the lens beyond repair. If repairable it may cost less to get a new camera. NEVER let a camera near sand unless it is specifically designed for use under water.
Sep 03, 2009 | Canon PowerShot Pro1 Digital Camera
No Flash
Pull the battery and memory card and keep them out for a while. If you are confident you could successfully open and reassemble your camera you could attempt to open it up to dry it out.
Otherwise, take a can of compressed air and point the nozzle tube in the cracks around the controls/body and attempt to dry it out...
You could shake it a bit like a thermometer... to use centrifugal force to remove water...just don't drop it or bang it..
Your best bet is to open it up or have someone help you with that..
Jun 07, 2009 | Nikon Coolpix S210 Digital Camera
Kodak camera has blurry pink display when taking pictures
mine has the same problem. it's less than a year old. nothing in the manual mentioned these kind of erros.
Apr 25, 2009 | Kodak Easyshare M753 Digital Camera
Winshield wipers not working, due to snow removal
Ok, If wipers were frozen to windshield at one point, it is possible to either blow fuse or burn out motor. The motors used on Jeeps are pathetic... sometimes unable to run on a dry windshield unless water is sprayed on it! Same goes for wiper transmission... If you moved it by hand, you can bend or otherwise damage it, but that is less frequent! Check fuse, relay and motor for power (in that order) and you will likely find the problem.if you haven't already!!!
Dec 20, 2008 | 1998 Jeep Grand Cherokee
Sony FX1 water damamged
Did you find a fix for your FX-1? I think mine got wet as well.
May 01, 2008 | Sony Handycam HDR-FX1E Camcorder
My youngest kid put my daughters DS down the toilet, she is very upset as she got it for Christmas. I dried it out in the airing cupboard and it now won't work unless you plug in the charger. After a...
obviously you know its water damaged, you can get a replacement, or get it sent off for repairs for free, *** long as you bought it less than 12months ago, you shouldnt have a problem, dont tell them what happened, just say it stopped working otherwise they wont replace it, similar thing happened to a mate of mine, he dropped it in the pool, trust me get replacement
Apr 22, 2008 | Nintendo DS Console
Kodak easyshare cx7530 digital camera
This is rarely less than $150 up. If the camera is still under warranty, and no evidence of damage is there, Kodak may fix it for you. If you want to find out, take it to a local camera store that sells Kodak and have them send it away for you. If there is no evidence of dropping or water damage etc, say it just stopped working. An estimate and shipping is probably about $20 bucks. I wouldn't really suggest paying $150 for a new one, but you can get a hell of a lot for $300 (Canadian) this year. I also don't suggest that you look for the highest megapixel or highes zoom in that price range. 6-8MP max, with good build quality, sharpness and features. This photorapher suggests Kodak, Pentax, Canon. Don't buy a $300 12MP, or 30X zoom unless you've got a thing for disappointment. These cameras cannot perform.
Jun 19, 2007 | Kodak EasyShare CX7530 Digital Camera
Rave mp mp3 player ---- frozen
Try a separate SD memory card (no bigger than 512mb). Also try replacing the battery if you haven't already. Mine has done this intermittantly since it was about a year old.
Jun 28, 2006 | GoVideo Rave-MP AMP512 MP3 Player
Cameras Logo
87 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
