Question about HP PSC 1401 All-In-One Printer
My HP PSC 1402 won't print!
I have the printer installed properly but it won't print! it worked fine last time i used it. on the printer pop up it says paper jam but there isnt a paper jam! i need stuff printed off for an exam 2mo PLEASE help!!
many thanks =]
  • 2WSxcvb Jan 09, 2009
    The printer will only print one page and then stops .I have a hp psc 1401 all in one printer .
My system ever thing is ok,but once i put paper displaying a out of paper,how 2 resolve this problem
Posted on Aug 16, 2009
    Scholar:
  • 82 Answers
Do not panic
Step 1:
Remove USB cable from the PC and try to print self test page
from the stand alone Printer unit
Step 2:
If it prints OK, half of the problem solved
If it does not
try to remove the cartridges, re install the same
and then try again
Step 3:
If the self test print is ok,
Try printing "Printer Test Page" from the PC
Do not put more than one Papers in the Paper Tray
Try this calmly and i think your problem shall resolved
all the best for ur exams
Do write comments in case you need more help
Do rate solution, so we can help others accordingly
thanks in advance
Posted on Jan 07, 2009
Pick up roller rotates twice even if when gives single page print command and creates paper jam.
I do not know for sure on the Samsung but on HP's this problem is often caused by the pickup solenoid sticking. There is usually a foam bumper on the pickup solenoid which breaks down over time and then the adhesive stops the solenoid from releasing properly. You can clean it off all the old foam and adhesive and run without it, just make printer a little noisier. The solenoid will usually be on the right side.
Aug 30, 2016 | Samsung Ml-1675 Laser Printer 17ppm...
Selphy DS700: False paper jam message and poor print quality
1.Sir Please have a vacuum cleaner with you and clean the area where the paper is being pulled in thus the sensor will be clear 2.if your problem isnt yet resolved please post your Windows here i will assisst you further
Sep 30, 2007 | Canon Selphy DS700 InkJet Photo Printer
My HP PSC 1402 All-In-One printer when plugged in "all lights are on" how do i get it back to normal so i can print again? tnx
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .
Jun 29, 2011 | Office Equipment & Supplies
I've just bought a new kodak printer ESP3250 last week, and installed everything and got it set up fine. It was printing fine after I installed it but suddenly stopped after I had printed a few sheets. The...
Sounds like there is a sheet of paper jammed in it. Try taking off the roller access panel in the back (not the access panel by the cartridges). Make sure to only use clean sheets with proper humidity level to avoid jams. Also fan the sheets before feeding to disperse any static.
Mar 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
My printer isnt feeding paper in straight and it keeps on jamming and saying that there isnt any paper.. is there anything i can do to esay fix it???
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Oct 25, 2010 | Office Equipment & Supplies
1402 Need Reflash
Alot of people are having the same problem with the hp printers i have looked at many printers with this problem and the most i have solved with reinstalling the printer to the computer you can do this by going to tcontroll panel > printers > right click and delete printer
then reinstall the printer using the disk or by clicking add new printer
im sorry but this is all the information i can provide on this problem
Aug 22, 2009 | HP PSC 1210 All-In-One InkJet Printer
Paper jam in my new Lexmark x2600 inkjet printer
Here's how to clear printer paper jam.
  1. Pull the paper out if it is visible. If not, then open the top of the printer so that the jammed piece of paper is visible.
  2. Grasp the paper and pull gently but firmly. If the paper continues to jam in the printer, inspect the rollers to ensure that they are grabbing the paper and pulling it along the paper path properly.
  3. Check the paper path for any obstructions, and clear if found. Also, inspect the other parts that the paper travels through, to ensure that they are not dirty or gummy. If any dirt or other debris is found, clean the parts and try again.
  4. Close the top of the printer.
  5. Place the printer back online. Try the print job again.
Just let me know for further assistant.
pincer
Apr 07, 2009 | Lexmark X2600 InkJet Printer
HP PSC 1401 All-In-One Printer Logo
1,347 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
