Question about Panasonic AG-1980 S-VHS VCR
TIMING MARKS ON VCR
HI, I'M IN DESPERATE NEED OF THE LAYOUT OF CASETTE DECK OF A NV-SD250 PANASONIC VCR. I'VE REPLACED THE MOTOR COUPLER AND CLEANED THE SET. NOW I CANT SET THE TIMING CORRECTLY
  • Panasonic Master
  • 5,259 Answers
NV-SD use the K-Mech you can find it here;
http://www.eserviceinfo.com/index.php?what=search2
Posted on Jun 17, 2009
  •  Grubhead
    Grubhead Jun 17, 2009
    Grubhead again! Just enter 'K-Mech' where it says "enter" on the link.
Casette is stuck in my panasonic nv-hd 680 vcr and display shows F4.Could anyone tell me how to solv it -please !!
I believe F4 means the mechanism is locking up when unloading the tape. You should look into the operation of the loading motor.
Jan 01, 2013 | Panasonic NV-HD680 VCR
Panasonic HS900 VCR. Switch on and F03 fault appears.
You have a model that uses the K-Deck look that up using google for further information.
However F03 means locks when unloading. There are several causes of this: The Load motor or drive, timing, or the mode switch.
Aug 17, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
HAVE A PANASONIC NV-HD670BD VCR KEEPS EJECTING TAPES
This could be caused by one of a number of things, but it could be down to the carriage (the thing the cassette fits into being damaged. Another likely cause is the mode switch. Again this could be caused by damage in the mechanism, throwing out the timing. You see the mode switch tells the electronics what position the mechanism is in. Any damage can throw out the timing. But mode switches themselves can go faulty. Sometimes dirt gets in them, which can be cleaned out by Servisol Video 40. Restoring operation. But damage will throw the mode switch out so re-aliment needs to be done. I think your deck might use the K-Deck mechanism. If it does you can find information on it, plus how to set up the mode switch correctly by searching Google for "Panasonic K-Deck".
Mode switches for K-Decks can be found on Curry's Partmaster site if you need a new one.
Mar 18, 2011 | Panasonic NV-HD670BDX VHS VCR
Hi F06 appear on screen;cant eject cassette
You have what's called a Panasonic K-Deck machine. That code means the Mechanism locks after unloading the tape. The cause of this could either be the 'carriage' where the tape fits, or the Load Motor. Plenty of free information on line just type "Panasonic K-Deck" into Google.
Jan 07, 2011 | Panasonic NV-SD235AM VCR
Panasonic VCR model number NV-HD640B comes up with fault code H01 - what is this and how do I fix it?
You have a Panasonic K Deck Mechanism, you can search for more free info on it via Google. Meanwhile H01 means no drum motor or drive, it's to do with the main VCR head not going around.
Dec 04, 2010 | Panasonic NV-HD680 VCR
My Panasonic NV-HD660 VCR is not unloading/ejecting a video cassette, in fact turns off itself and shows error message HO2, please help!
Yes the most likely cause is the mode switch, you can spray it with Servisol Video 40 or replace it. But you will need the service manual for that. The good news I think your model uses a K-Deck, and there is plenty on-line about the Panasonic K-Deck.
Dec 02, 2010 | Panasonic NV-HD635AM VCR
F 04 - Tape stuck in recorder
F04 means that the mechanism locks during unloading. You need to check the Load motor and it's timing.
You have by the way a K Mech model. This will help you find parts and other information on the mechanism.
Dec 18, 2009 | Televison & Video
Hi. the loading motor coupler on my NV-HD675B has broken. Can you tell me where I can source a replacement please.
I think your machine uses the K Deck. This will help you finding the part.
You can try Grandata or Curry's Partmaster, they are both on the web.
Sep 14, 2009 | Panasonic Televison & Video
Panasonic NV HD620 Error F06
You appear to have a model that uses the K Deck Chassis.
F06 in that case stands for: "Mechanism locks after unload". The cause being either the loading motor or the carriage alignment.
May 07, 2009 | Panasonic NV-HD680 VCR
How to time loading arm cogs on VCR?
Most Panasonic VCR use a mechanisms with a letter. For example the NV-HS900 uses a K Deck. What you need to do is type the model number into google and search for which deck it uses. Then with luck you might also find the instructions for setting the deck up correctly. I got the K-Deck one free.
Jan 03, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic AG-1980 S-VHS VCR Logo
178 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
