Question about Intel Server Board SE7501BR2 Motherboard
Onboard scsi not working
Onboard scsi not sensing ,while booting ctrl A option is not coming
  • 57 Answers
What controller. The adaptec controllers have displaying ctlA as a controller option and can be turned off.
Posted on Jul 29, 2009
Compaq Evo W6000 will not boot
Old DT PC. Compaq. what OS? why not ask at
SCSI sets up SCSI devices, HDD or TAPE.
it was used mostly on servers.
old desktop,
running what, OS2 (ibm) or running windows.?
if windows ,windows what, you never stated the OS that ran.
it has XP 32 or XP 64 as a 2 and 3rd options
or did you wisely upgrade it? we cant guess any of these facts
my guess is the boot files are messed up or the HDD is dead.
looks to me like 2002 PC full sized desktop (as old as)
it does have SCSI (and
and has this warning on the HP support page for it.
Workstations Fix for "FBISM - ******* Operation" on Restore to SCSI Drives
update this is. sp22541.exe (0.6 MB)
  1. BIOS setup wrong, not booting the correct device (control+A)
  2. HDD startup files missing or corrupted.
  3. HDD bad. (run tests on it?)
if the HDD is ok , reload unstated OS.
this thing ran for 15 years and now only died? today?
it has ,
Ultra160 SCSI (1 (68-pin internal)) with windows 2000 on the first ones.
read page 46
if the scsi Hdd is still the boot drive
then then the ATA drive must be set to last. per page 46 in bios
once the Ultra 160 is the boot device, it too must now
be setup right to boot the correct SCSI drive, (lots of books cover
that great chip, from "Adaptec"
hp usually deletes all files this old but not here,
you are lucky some remain, now.
May 11, 2017 | HP Compaq Evo W6000 PC Desktop
P4c800-e gives error bios not loaded
this motherboard is supposed to have crash free BIOS an overclocking ability and power loss restart
is it happening on boot up the drivers have not been loaded or might not be detecting a bootable device the first things to check are the leads motherboard to your hard drive make sure they are securely seated with no dust built up also the same with computer ram and cmos battery and make sure the sockets are cleanThis message is generated by computers with SCSI / RAID controllers when no bootable drive is detected on the controller. This is not an error message unless you have a bootable drive on the SCSI / RAID or you are wanting to use a SCSI or RAID drive. If you are not using a SCSI or RAID drive and your computer has onboard a SCSI or RAID controller, this message can be disabled by entering the computer CMOS Set up and disabling the onboard SCSI or RAID During the boot process you will see on the screen to press delete to enter setup Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart If your computer is unable to boot or you wish to restore the BIOS back to bootable settings and your computer uses an ACER BIOS, press and hold the F10 key as you turn on the computer. While continuing to hold the F10 key, you should hear two beeps indicating that the settings have been restored. AMI BIOS Older AMI BIOS could be restored back to bootable settings by pressing and holding the Insert key as the computer is booting.
BIOS / CMOS diskettes
Early 486, 386, and 286 computers may have required a floppy disk in order to enter the BIOS setup. These diskettes are known as ICU, BBU, and SCU disks. Because these diskettes are unique to your computer manufacturer, you must obtain the diskettes from them. See the computer manufacturers list for contact information. Early IBM computers Some models of early IBM computers required that the user press and hold both mouse buttons as the computer was booting in order to enter the BIOS setup.
Other suggestions
Finally, if none of the above suggestions help get you into your CMOS setup you can cause a stuck key error, which will usually cause the CMOS setup prompt to appear and remain until you press a key to continue. To do this press and hold any key on the keyboard and do not let go (you may get several beeps as you're doing this). Keep holding the key until the computer stops booting and you're prompted with an option to enter setup or to press another key to continue booting.
hope this helps
Jul 28, 2011 | Intel ASUS P4C800-E Deluxe 875P Socket 478...
The bios is not installed
Go to BIOS, under Advanced > PCI Configuration. Disable Onboard ATA device if you're not using RAID. Also, make sure under Boot Menu that Other boot device do not show SCSI/Onboard ATA.
Hope that helps.
Mar 02, 2009 | ASUS P4P800-E Deluxe Motherboard
I have a compaq proliant 2500 series do i need a scsi adapter card for this or is it onboard
open it up and see. there should be markings showing scsi card etc., if none, then it is not onboard . get one scsi card.
Jan 16, 2009 | HP Compaq ProLiant 800 Server
PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Nov 03, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
IBM IntelliStation Z Pro 6221
Mayeb you need to repair the OS - In which case you will need to have SCSI Controller XP OS floppy driver obtained from IBM website.
Start up the computer booting up from the CD ROM. Then when it comes to "install thrid party devices" - press 'S' and insert the floppy with the SCSI Coontroller on it and follow the on screen instructions.
Jun 18, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
Monitor is at 15% angle downward and refuses to be tilted up?
1.)TRY THIS : press ctrl+alt+ "an arrow key" and see if your screen positioning changes to normal again : Press all keys together : ctrl+alt+ "up arrow+key" could solve this
2.)try f8 option when your machine boots up then select last known good configeration.
3.)uninstall your VGA drivers, restart your machine, then reinstall your VGA drivers.
4.) Try onboard VGA graphics
5.) position your screen -15% angle :P
Apr 16, 2008 | Computers & Internet
SCSI BIOS not installed / ML150G2, exchanged mainboard, RAID
my guess is no but since i haven't dealt with this type of server i'm going to suggest you go to hp.
if you just goto and search on live chat and a link will come up.. they should be able to help unless it's too old since i'm not sure what generation we are on now..
good luck, hope this helps a little..d
Feb 23, 2008 | Adaptec (2120S) SCSI Controller
Software and driver
You should be able to download the proper drivers for your Operating System directly from Microtek:
Since you didn't tell us which country you're located in, or which OS you're using, I can't provide any more specific information for you...
The Download page is located here, for users in the US:
From what I could determine, the X6 model was discontinued some time ago, and there were at least THREE versions of it; you'll have to find it listed under the Product Category in the Discontinued Products section, then choose the version (parallel port / EPP, SCSI, or USB), in order to download the driver you need. Seems that the SCSI version has drivers ONLY for Apple computers; if you're using Windows, you'll need to choose one of the other options...
Jan 27, 2008 | Microtek ScanMaker X6 Flatbed Scanner
Intel Server Board SE7501BR2 Motherboard Logo
66 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
