Question about Karcher Quick Connect Nozzle Set
Water gushes out of the inside of my Karcher jet washer.
I have a Karcher K 6.91 jet washer which, when I attach a water source to it the water gushes out from inside the machine.
  • 1 more comment
  • Anonymous Mar 13, 2014
    tried to attache someone elses karcher decking cleaner to ours only to find the plastic sleev screw that join the two toghether did not attache somehow or other it tightened on itself and now won't untighten again
  • Anonymous Mar 22, 2014
    karcher only spits water when I use the patio cleaner all other attachments work perfectly
    all other attachments work perfectly it only spits when using patio cleaner head
    Problem Solver:
  • 10 Answers
You can sometimes seal the water leak from the inside as I think your water inlet case has split
Posted on Jan 07, 2009
  • 21 Answers
The problem is most likely down to either a broken or damaged plastic inlet pipe, or it could be that the pipe has been dislocated. It is retained by a circlip. Both problems are due to abuse, rough or improper treatment of the machine.
Posted on Feb 11, 2009
Water coming out of detergent pipe from top for karcher 3030 B jet wash.When i start using the jet wash there is not enough pressure and water starts coming out of detergent pipe.How can i stop water...
remove deterfent pipe,unscrew detergentnozzle carefully, inside is spring and ball bearing, clean and re-fit, replace if missing. spring on upstream (soap) side
Apr 03, 2014 | Karcher Garden
Water gushing out of gun handle
Looks like the frost has damaged your gun. A new gun is required.
try this link for spare.
http://www.sparesgiant.com/c-19-pressure-washer.aspx
Mar 28, 2011 | Karcher Garden
Faulty
water is pouring out of my 5 year old karcher from the trigger handle WHY???
May 22, 2010 | Karcher PSI Electric Pressure Washer
No pressure but water is gushing out from the inside
You most likely have split the head of the pressure pump. This happens if you use the trigger to stop and start the water flow. My advice is to put a zippy tie around the trigger holding it on all the time and start and stop the machine by the knob on the body.
Apr 12, 2010 | Karcher K2.26 Electric Power Washer
Karcher k3.91 how do i change from just water to soap
Twist the end of the nozzle or jet pipe until you get low pressure. This will **** the soap through
Aug 16, 2009 | Karcher PSI Electric Pressure Washer
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
I have a karcher 411 A jet washer, there doesn't seem to be enough pressure to do the job. I have bought a new wand but it doesn't seem to make any difference, any ideas, what am I doing wrong
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Aug 31, 2008 | Washing Machines
Karcher Quick Connect Nozzle Set Logo
966 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
