Question about Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Help me with my tv
My tv is is brand new i had about six month and the vcr broke that was ok with me but i could not get the tv to stay on you turn it on and in just less than a minute it shuts off. i took it apart and unhooked the vrc that still did not help the dvd does not work either i lost the reciept and the store would not take it back .
My TV did the same thing, as alot of other customers did too. You have to fix the VCR to align right because the on/off switch is connected to it somehow. Apparently this is a common problem with this TV. Now I did fix the on/off problem, but at times my TV will just quit working (can't change channels, turn up volume, or anything). After "messing" with it for about thirty minutes I did get it to work again. By messing with it, I mean hitting it slightly on the side or back. It seems like there may be a loose connection. With all of the problems we have had with this TV I am sure I will not buy this brand again. Our TV was manufactured in 2003 which is not old at all. I had an old Sanyo that lasted for twenty years.
Posted on Aug 18, 2007
Need universal remote code.
Hello
Three digit universal remote codes for konka are:
016/ 047/ 066/ 157/ 158/ 176
Four digit universal remote codes for Konka are:
0053 0011 0016 0047 0066 0103 0412 0413 0029
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Mar 25, 2011 | Konka K2038U TV
How do I program old Samsung to control power and volume on new Samsung TV?
Hello
There are two ways to set a remote with a TV. They are direct Code Entry and Code Search. i'll give here both the proceedings. OK.
Direct Code Entry
Mar 19, 2011 | Samsung TV Remote Control
Need to find code for Jumbo Universal Remote to use with Aiwa S2011 MTS television. Thanks for any help!
Hello
Aiwa TV is not lited on Jumbo Universal Remote codes. Anyway try out with these codes. Sometimes may help you.
Three digit codes for Aiwa TV with universal remote are:
195/ 196
Four digit codes for Aiwa TV with universal remote are:
0195 0196 0227 0269
Direct Code Entry
NOTE: Switch OFF and switch ON your TV with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
OK
Jan 27, 2011 | Aiwa TV-S2011 20"
Universal remote need a code ? or a remote
Hello
Universal remote code for Prima TV are :-
1019 0165 0116 0167
Direct Code Entry
OK
Jan 19, 2011 | Prima C2012 TV
Hello can you gayz tell me how to gat cod for universal remot control my tv is HCT TV/DVD COMBOS
Hello
Three digit universal remote code for Symphonic Tv are:
033/ 053/ 189
Four digit universal remote codes for Syphonic TV are:-
0053 0189 0227 0456 0024
Four digit universal remote code for Symponic tv/vcr combo is
0227
Direct Code Entry
Ok
Jan 15, 2011 | Symphonic SC309C 9 in. TV/VCR Combo
How do i use the code search on the ucr universal remote
Hello
Four digit universal remote code for Sansui TV/VCR/DVD combo are:-
0394 0967
Direct Code Entry
Ok
Jan 07, 2011 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Where can I find a book on the different UVerse Remot tv codes for a new tv?
Hello
Universal remote code for Panasonic TV/VCR/DVD combo is
0437
Direct Code Entry
OK.
Dec 19, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
Need codes to remote to turn on my symphonic tv
Hello
Three Digit Universal Remote codes for Symphonic TV are:-
033/ 053/ 189
Four Digit Universal Remote control coldes for Symphonic Tv are:-
Direct Code Entry
Ok.
Dec 03, 2010 | Televison & Video
Tv cuts off
being it was older and a left over gift....we trashed it and saved my husband's blood pressure.
Aug 06, 2008 | Symphonic Televison & Video
STANDBY BUTTON
call 1-800-256-2487 they will help (maybe)
Dec 10, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Emerson EWC27T3 27 in. TV/VCR/DVD Combo Logo
62 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
