LG TV LCD 47LF65 makes a strange noise
I have a LG TV LCD 47LF65 for about 2 months and i noticed that when i turn down the brightness from 85 below ( i use 75) it makes a strange noise. not to loud but anoiyng. can someone tell me what to do to solve this problem? or is it supose to do this noise?
thaks in advance
  • sarita37 Apr 26, 2009
    I have a lg3750 it makes a huming noise,why is that. it only happens when i turn the tv on. I have had it since Febuary. Can someone tell me why it does this?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
It should make a little noise, but if it is annoying then it is probably an issue - this is most likely the power being reduced to the inverters when the birightness is turned down. Could be a noisy coil on your power board or a capacitor may be going bad and changing value. I would look for any swollen capacitors (a bump on top, bursted or swollen sides) on the power board.
Posted on Jan 07, 2009
My LG tv model 50LB6300 ( 50 inch ) had 3 months ago 1 bright spot on the screen. After 1 month there came 2 more. And today it is 5. These white spots become very bright at a white background.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 03, 2017 | LG Televison & Video
Sizzling,smoke,sparks ...horray.
Thats the Inverter board. Your model used several different types which are not interchangeable. You can get the correct Inverter Board for your model by contacting the guys over at www.tvrepairworld.com
Mar 13, 2013 | LG 32LD450 32 In. LCD HDTV
Why do bright colors bounce on my lg tv?
I had this issue on a 40" Seiki TV. I turned off the 120hz setting and also the Noise Reduction settings in the Menu and it stopped.
Jan 12, 2013 | LG 47lw5300 47-inch 1080p 120hz Cinema 3d...
Long time to get bright when turning on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.Have a blessed one!
Mar 29, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
My LG washer/dryer started to make a strange noise this morning when I put a few towels in to tumble dry. I put it off immediately, and have just tried again (7.30pm). Still making strange noise, not...
Your michines are still under manofacture waranty call LG customer service at the address below.
LG Support Representative at (800) 243-0000
"Was this helpful?"
May 09, 2009 | Dryers
Strange noise
i had something similar to this awhile ago... check the splash sheilds on the front calipers to see if they are bent in.
Robert
Jan 23, 2009 | 1993 Nissan Sentra 4 Door
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Buzzing noise
This might not work for you, but Syntax LCD tvs have a similar problem straight out of the box. To fix it, I had to turn the backlight brightness to full brightness, at which point, the buzzing went away. You might give that a try!
Feb 17, 2007 | LG 32LX1D 32 in. LCD Television
Televison & Video Logo
1,220 people viewed this question
Top Televison & Video Experts
