Question about HP Pavilion 6745C (P1442A) PC Desktop
Error message says cant find operating system
When i start PC after HP invent screen I get error message the it cant find operating system. I have a new window 98 disc which wont be recognized from cd.
any help??
thanks
  • 39 Answers
Windows 98 you ussualy had to boot from a 98 boot disk, which used to be on a stiffy. So, have you tried to boot from an XP cd? Also check to make sure that your boot priority is right so that the pc will try and boot from CD rom first and then HDD. Yiou can change these settings in CMOS setup.
Good Luck
Posted on Jan 07, 2009
    Scholar:
  • 111 Answers
Are you intending on reinstalling windows? If so follow these steps;
YOU WILL LOSE ALL YOUR DATA IF YOU FOLLOW MY METHOD
Enter your BIOS menu - This is generally accessed by tapping F1 or Del when the computer is booting, but it should be displayed on the screen as the computer starts
Find the "Boot Options" menu sometimes it can be a tab or under advanced options each BIOS varies
Set you 1st boot device to CD/DVD
Reboot with the disk in drive
You should be prompted to hit any key to boot from CD - Do so
The CD will begin the installation process
Delete your current partition and reformat the hard drive in the format of your choice then begin the installation process
It is pretty simple from there
I DO NOT advise doing this is you are not confident with your abilities it may be a job for your local technician.
Blazamane
Hp invent repeating startup error
If it is showing a blue scree of death (BSOD) and shuts downbefore you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 keyrepeatedly until you see SAFE MODE. Scroll down below Safe Mode and youwill see an option to Disable Automatic Restart. Select it and rebootyour machine. Next time it boots up you will be able to read the errormessage. You'll probably need a system disc or repair disc to fix theblue screen error message.
Mar 26, 2012 | HP xw4600 Workstation - 1 x Intel Core 2...
System is wont boot
Getting 0x0000008e is surely a signal that your registry is corrupted. What you need to do is to fix 0x0000008e as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don’t fix 0x0000008e, this potential risk will bring you more troubles, Even system crash.
Cause of the problem would be.Mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause 0x0000008e.
Heres how to fix the issue
Download the software fix by clicking here.
Launch it after finishing the installation.
Click “Scan Now” button
Click “Repair Problems” button and fix 0x0000008e.
May 21, 2010 | HP Pavilion dv6000z Notebook
HP Officejet 7410 All-in-One Blue screen error message 00000020
I did everything you said, even the angry part lol and still nothing. Sigh...well, I've been wanting an air printer anyway :D
Oct 05, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Start up problem. model No:a6460a.serialNo:12038 software build No:aud81 108ml: purchase date, 09.07.2008. hard drive takes approx. 4 to 5 attempts to start when switched on.at times will require to be...
your case is common in most hp desktop i believe the bios of your hp has certain problems so what i'll recommend to you is to update the bios of your mainboard you can search it on th einternet or if you can't surf properly repair the operating system by flashing in your bootable disk then restart and boot up the disk and proceed to the setup then repair the os
hope it helped you!:]
Sep 22, 2008 | HP Computers & Internet
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
0xc19ac3ff error code
Same deal. Message "ink system failure". I restarted the printer, it works fine
Mar 07, 2008 | HP Photosmart C7180 All-In-One InkJet...
Ntdlr error messages
If your pc is showing a error before starting windows it means your system is corrupt or damaged. This can be fixed with chkdsk or a repair windows install or a clean windows install.
That is something you cant prevent from showing. It will always come up when there is a problem with the operateing system.
Feb 17, 2008 | Systemax Neotach 3300 Notebook
HP Pavilion 6745C (P1442A) PC Desktop Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
