Question about Sony Playstation 3 (PS3) Console
Cant to get a friend to join online playing Smackdown vs Raw 2008
Hiya
I was playing for the first time smackdown vs raw 2008 on ps3 online and tried to invite one of my friends - it sent a message to him, but the message didnt say anywhere that he could join my game, how do i get my friend into my online session so i can play him - hope someone can help
    Problem Solver:
  • 10 Answers
There is usually two reasons for this.
The first one is the game is just having server problems.
The second one is usually the problem and that has to do with your router settings causing you to have a 'NAT Type 3' connection which can cause connection issues with other players.
Having a closed or limited NAT on your gaming console will cause a variety of issues. Similar to strict, moderate or open on an Xbox 360, the PS3 offers Type 3, Type 2 and Type 1 NAT results. These break down as follows:
Type 1 - Connected directly to the internet (no router/firewall). Should have no issues.Type 2 - Connected through a router properly. Should have no issues.Type 3 - Connected through a router without open ports or DMZ setup for PS3. Everything should function properly, but you may have connection, voice chat or other issues.While most everything will function properly regardless of what your NAT setting is, your best bet is to set up your PS3 so that you can obtain a Type 1 or Type 2 NAT. Since most of us have routers at home for connecting multiple computers or devices to the internet, chances are the best we will get will be Type 2. Thankfully that's fine and everything will work properly.
If you have not adjusted your settings on your PS3 or router, chances are you have a Type 3 NAT and probably never knew it. With a few simple changes you too can have a Type 2 NAT. Order now for just $19.99. But wait, there's more. Cant to get a friend to join online playing Smackd - joker.gif
The first thing you will want to do is check your network connection. Head on over to the Network Settings tab on the XMB. It looks like this:
Once there choose the Internet Connection Test item. It looks like this:
You will receive a warning letting you know that you will be signed out in order to perform the test. Choose okay. If you have not made any setting changes in your PS3 or Router, chances are you will receive the following message:
The warning reads: "When the NAT type is type 3, chat or the communication features of games may be restricted. For more information, refer to the online instruction manual."
If you run the test and have Type 2 or Type 1, stop fooling around and go play some games! If, however, you have Type 3, read on for help on opening up your NAT.
In order to open up your NAT on your PS3 you will need to make an adjustment on your PS3 and on your router. First you will want to set up your PS3 for a static IP address. This means turning off DHCP and assigning your PS3 a single, static IP address. Before you start this process head over to the network tab on the XMB and choose "Internet Connection Status." From here note your current IP address, your subnet mask, your default router and primary and secondary DNS settings. Write these down, you will need them in the following steps.
To do this, visit the Internet Connection Cant to get a friend to join online playing Smackd - da972233d5644141a5c5e1ede940d352.jpgks like this:
From here most of the settings can simply be passed through with default settings. There are two areas, howevCant to get a friend to join online playing Smackd - ef168db6a4de4bf2b898c79a0eee6b9e.jpgrst is choosing a Custom address setting (instead of Easy).
From here, you will want to choose Manual IP Address Setting:
Remember the settings you wrote down from your status page? You will need them here. You will have to enter in the static IP Address you want to assign to your PS3, the Subnet Mask (which is usually 255.255.255.0), the default router (the IP address of your router, most often 192.168.1.1 or 192.168.100.1), and the Primary and Secondary DNS settings. You will have to input all of these numbers. This is made much easier with a DVD Remote or keyboard.
Please NOTE - You will want to set the last number of your IP address high enough that other wireless or wired items on your network will not be assigned the same number through DHCP. While DHCP had chosen .3 as an IP address for my PS3 initially, I bumped it up to .23 because I have less than 23 items in my network. If yoCant to get a friend to join online playing Smackd - 83f1d6dec23e4658a9870e9262728bb0.jpgrouter, you do not need to worry about this and can simply choose an IP address that does not conflict with your other devices and which is available through your router.
Once you have all of the settings input, press X to save them. Your settings will change and the PS3 will offer to perform an Internet Connection Test for you. If you let it do the test now chances are you will still get a Type 3 NAT connection. Don't fret little bear, we still have one more step.
In addition to making the necessary changes on your PS3Cant to get a friend to join online playing Smackd - 59c653fed8fa4b6d97dc2d0b7b7f0d13.jpge ports on your router. The ports you need to open are:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
I have a Linksys Router and my port forward settings page looks like this:
Depending on what type of router you have, your settings page may look different. In order to obtain an open or Type 2 NAT, you will need to open those ports listed above.
You can see in my screen capture that my PS3 is listed with its static IP address that I set above (.23) and that all of the necessary ports are forwarded to that IP address. The X listed items above (.24) are for my Xbox 360 so you don't have to worry about those.
Once you have forwarded theCant to get a friend to join online playing Smackd - ed44497e4808423ea9cdf6a8ea35fd96.jpg a good idea to unplug and plug back in your router. This will refresh everything on your network connected to your router. Once done head back to your PS3 and perform an Internet Connection Test. If you did everything correctly you should receive the following page:
Congratulations, your NAT is now setup and working properly!
Posted on Jan 09, 2009
  • 53 Answers
Usually you don't look at that message in the XMB, The invites are usually in the game under community or a friends selection screen. I haven't played that game so i am not sure where you accept the request but it is there somewhere
I want passcode of wwe smackdown vs raw 2008
i want passcode of wwe smackdown vs raw 2008 plz give me the passcode
Nov 15, 2010 | THQ WWE Smackdown vs Raw 2008 for Nintendo...
Passcode for WWE Smackdown VS. Raw 2008.PC.Game-FLT
Here is your pass code PCX9K283... well its for PC
Mar 22, 2010 | THQ WWE SmackDown! vs. RAW 2008
Passcode of WWE Smackdown VS. Raw 2008.PC.Game-FLT
what isa passcodeof the wwe smackdown vs raw 08
May 30, 2009 | Video Game Consoles & Games
I need the Manual for wwe smackdown vs. raw 2008 for the PS2
for wwe smackdown manual go here
/downloadanystuff.org/
put your query here and search
Apr 24, 2009 | THQ WWE SmackDown! vs. Raw 2008
How come i cant use my created character on smackdown vs raw 2009 online but i can offline
From what I have seen, people have had problems with either DLC or something simple as your character having symbols or tattoos. Apparently, if you and the person you are playing don't have all of the same DLC, you won't be able to play that person online. I hope this helps.
Apr 15, 2009 | THQ WWE Smackdown Vs Raw 2009
I cant use my created characters moves and entrance online
ok go to ur move set list and go down to tha bottom of ur move list and click on save that mite be ur problem tell me if it works
Jan 18, 2009 | THQ WWE Smackdown Vs Raw 2009
Download instruction manual for smackdown v.s. raw 2008?
go to google type in instruction manual 4 smackdown vs raw 2008
Dec 25, 2008 | THQ WWE Smackdown vs Raw 2008 for Nintendo...
Playing and inviting friend online with Playstation 3
Try finding a patch online I do think I had seen something on the ps3 forums.. should be taken care of rather soon its not just you with this issue! but its not everyone!
May 23, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
397 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
