Question about RCA LCDX2620W 26 in. HDTV-Ready Television
RCA 26" SRS WOW has a grey shadow display when watching TV
The RCA LCD TV (SRS WOW 26") there is a (excuse me for saying but it kind of looks like a breast pointing to the right on the right side of the TV about 6 inches at the widest point)like dark grey shadow I am not trying to sound funny but it is the best description I have it is always showing when the TV is on. Does anyone else have a shadowing effect showing on there screen and is there any resolution to correcting the display. Thanks Coopertt
Re: RCA 26" SRS WOW has a grey shadow display when...
My grandson jumped on the remote and the sound went out. Checked the mute button and the sound set up but still no sound
Posted on Aug 07, 2010
Yeah, I just got one of those and when the picture is full screen I see that also. I just have the picture set to 14:9 and the pic is crystal clear. any good resources for a wall mount?
Posted on May 13, 2008
0 characters
3 Points
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Flat Panel Televisions
The picture on my tv is completely dark, but the sound is working fine. how can i fix the picture? because it's a fairly new tv
Keep a close look to the screen, and see whether there is any trace of picture on it. If it is there, you can see pale shadow of it moving. If it is there, be sure that the backlight is not there. Thhere is an inverter board to energise the CCFL lamps used as backlight component. If the inverter board got faulty, the CCFL lamps won't light up, and no brightness will be there with LCD TVs. Check it. OK.
Oct 22, 2011 | RCA L26WD12 26 in. LCD TV
Hi, I have an RCA HDTV SRS WOW Model RCA L32WD12YX5, Serial G482CJ060. It powers on and has sound for about 15 minutes then shuts itself off and restarts with no sound. As an experiment, I used the Menu...
The tv main Tuner signal board have problems and the causes.Tries websites like, to buy a whole refurbish tv Tuner signal board for the replacement.
Jun 09, 2011 | RCA L32WD22 32 in. LCD HDTV
RCA SRS Wow problems.
my pic has 1 1/2 in on each side that is black
Sep 07, 2009 | Flat Panel Televisions
RCA LCD TV 26 screen turns white, no sound no nothing
You have a blown fuse in the power supply. It does not look like a fuse.
It is near the top of the board and is labeled as 1.6 amp. It supplies 12
volts to the main board (via q422). A 2 amp fuse should be a fine
Sep 04, 2009 | RCA L26WD26D 26 in. LCD TV
Shadowing on lcd tv when tv camera moves left or right
it could have something to do with the refresh speed of the tv set not sure if you can change it have a look in the menu or manual hope this helps jim
Mar 16, 2009 | Philips 47PFL7403D 47 in. LCD TV
Samsung LN37A550P3F shadow image
It seems new TV.
But that kind of problem is related LCD panel.
If you can replace LCD inverter first.
then not working need to replce LCD panel.
Jul 22, 2008 | Samsung HP-P3761 37 in. HD-Ready Plasma...
RCA LCDX2620W 26 in. HDTV-Ready Television Logo
811 people viewed this question
Top RCA Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Are you a RCA Flat Panel Television Expert? Answer questions, earn points and help others
