Question about Health & Beauty
Nebulizers attachments
Do you need atachements? any medical equipment company will be able to help you
Posted on Feb 10, 2009
Where do you load the inhalation solution?
You may have already figured this out by this time, but figured that others could have the same question. Here's a simplified explanation on how to assemble and use the nebulizer. I apologize if the explanation sounds patronizing. I'm not sure of what you may or may not understand about the nebulizer, so I'm explaining as though you don't understand it. I'd rather someone explain something in a patronizing way, than assume I have knowledge that I actually don't. At least with the former, it's easier for me to ensure my questions are answered. I also apologize for my ADHD. It often cause me to write much more than is necessary or overexplain things.
There should be two pieces that screw together to make the reservoir.
Piece #1 is the male side/bottom side and may or may not have a green cone inside. If not, there are still a plastic piece inside that forms a cone shape. This side should also have a small plastic cylinder shape on the bottom. This is where one side of the supply tube should be attached.
Piece #2 is the female side and has a larger cylinder shape on the top. When the piece is turned on its side, it sort of resembles a flashlight. This is what the breathing apparatus is attached to. You attach the tee adapter to the tube side of it. Then you attach the mouthpiece to whichever of the tee sides it fits best. Once this is all assembled, attach the other end of the supply tube to the nebulizer.
Now, back to your question. Open the reservoir, pour the solution into Piece #1, then screw Piece #2 back on. It should only take a second or two for the steam to begin flowing through the breathing apparatus once you turn the nebulizer on. Also make sure the the supply tube is attached securely to both the nebulizer and the reservoir so it doesn't pop off. Now you're ready to begin.
If you start coughing during treatment, that's fine. Don't remove it from your mouth or stop treatment. My mom was my son's pediatric nurse and trained us on its use. She said that if you start coughing during treatment, that actually helps you to inhale even more of the solution which is beneficial..
Aug 02, 2013 | Salter Labs 8900 Series Small Volume Jet...
Airial nebulizer does not mist
I am very happy to read your articles it's very useful for me, and I am completely satisfied with your website. All comments and articles are very useful and very good. Your blog is very attention-grabbing. I am loving all of the in. turn you are sharing with each one!.... <a href="http://www.easyfit.in" title="Nebulizer" target="_blank">Nebulizer </a>
Apr 02, 2013 | Medline Nebulizer Portable Compressor Sys...
My nebulizer isn't producing steam what is wrong, it was working and then it just stop working in the middle of doing a treatment.
hello
Its due to any hurdle inside the motor. If you know some engineerring then...
1. unscrew the back of the cover
2.there are two pipes attached to the motor. check either there is anything that press the pipe to stop flow or not.
3. if so carefully remove that.
and
if it is in warranty then without opening it take it to the supplier for servicing.
NOTE: never try it to open if it is in warrenty.
regards
Feb 28, 2011 | Mini Plus Nebulizer/Compressor 5 YR...
My devibliss oxygen concentrator machine- model AKS 515- showing low oxygen alarm,periodically.
if you have any idea yo open the machine ,open there will be 6 screws and check there will be fan below the compressor
  1. fan is stopped
  2. leakage from the tube side from the compressor end
  3. crack in muffler attached to the compressor
  4. check removing the humidifier bottle for the same complaint
  5. sieve tank is last
Jan 29, 2011 | DeVilbiss Pulmo Aide Compressor Nebulizer
Respironics Side Stream Nebulizer tubing with condensation
try this...
let the compressor run with only the tubing attached for a few minutes. The warm air
from the compressor will dry the moisture or condensation in the tubing. Use a damp
cloth to wipe the exterior of the tubing.
hope this helps..good luck...
May 02, 2009 | Respironics HS860 Sidestream Reusable...
Sterlize my nebulizer
From Pari.com:
What is the best way to clean and disinfect my PARI Nebulizer?
Cleaning: After every treatment, thoroughly rinse the nebulizer to remove medication. Hand-wash with warm water and dish soap. Rinse thoroughly. OR... Wash in the dishwasher using a dishwasher basket on the top rack.
Disinfecting: (done after cleaning) every 2nd treatment day, mix a solution of 1 part distilled white vinegar and 3 parts warm tap water in a clean bowl. Soak the nebulizer parts (except the tubing and mask) for 60 minutes. Rinse thoroughly. OR... Mix a solution using Control III® Nebulizer Disinfectant and soak for 10 minutes. Rinse thoroughly. OR... Boil the nebulizer parts for 10 minutes.
Source: http://www.pari.com/pdd/pdd-faqs.htm
Apr 20, 2009 | Pari Proneb Ultra II Compressor Nebulizer...
RESPULES Question
No, PULMICORT RESPULES should only be delivered through jet nebulizers. Jet nebulizers are the only effective device for delivery of suspensions such as PULMICORT RESPULES. Because of their physical characteristics, suspended drug particles are generally poorly nebulized in ultrasonic devices.
Aug 27, 2008 | CARE Devilbiss 800C Pediatric Reusable...
Nebulizers question
Nebulizers deliver aerosolized liquid medicine by a facemask or mouthpiece. Successful nebulizer therapy does not depend on significant patient cooperation or coordination. This is useful in the treatment of pediatric asthma, and the NIH recognizes the nebulizer as an effective delivery device for young children.
Aug 27, 2008 | Cardinal Airlife Brand Misty Max 10...
Health & Beauty Logo
250 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
